02-03-2016, 15:22 | #31 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
You disabled this suspected apk from application manager and added it to virus definition database? | |
The Following User Says Thank You to orbita For This Useful Post: |
02-04-2016, 19:20 | #32 (permalink) |
Insane Poster Join Date: Oct 2013 Location: phils
Member: 2047969 Status: Offline Thanks Meter: 9 | nck team pls help..... i have a samsung s6 g9200 mtk6572 clone and there is a monkey virus. ive perform malware remove , select all then delete..... the deleting procedure is on process then it suddenly stop.... and my samsung s6 clone reboot... after rebooting it is now stock on LOGO only... and when i back up , and check in notepad++ my scatterfiles is HW_STORAGE_NAND there is no EMMC storage.... it is possible to revive the file that erase in NCK BOX here is the file that erase Malware_160201_005626 Malware_160201_005755 Malware_160202_144055 Malware_160202_145212 Malware_160202_145633 ive try many different firmware... its all error... im very confuse Team... why its happen???? can anyone help me pls.... here is my scatterfiles ... thanks... |
02-05-2016, 13:34 | #33 (permalink) |
Major Poster Join Date: Jan 2013
Member: 1873465 Status: Offline Sonork: jojo Thanks Meter: 39 | nice update nck team.. but im hoping that your team add virus remover via preloader because most of the phone having a virus is cannot be access because of some error.. thanks team and more power *** bless you all |
02-06-2016, 20:48 | #38 (permalink) |
Member: 2047969 Status: Offline Thanks Meter: 9 | nck team........... do younot have an answer to my question......???? can i revive my phone again....??? whybit is so, .... when you click remove malware , analyzed then remove..... then suddenly when on process removing ... it will say deting failed and reboot ..... and now the status there is no virus completely..... because my unit is LOGO only and Brick...... pls team... give an answer.... and solution to revive......... thanks............................................ .................... |
02-06-2016, 20:52 | #39 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,262 | Quote:
And just for your info if log says deleting failed this means nothing removed and no files deleted, so really strange what you say is like i put phone on charge and it did not charge and in same time the charger is not plugged in electric socket... simple reflash your phone. But i think and you know i m right that you flashed phone with wrong firmware and got it in that stage and thinking if you blame software this will help you? No you are wrong | |
02-06-2016, 23:14 | #40 (permalink) | |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | Quote:
Port: ALCATEL HS-USB Diagnostics 9017 (COM94) Build id: MPSS.TR.2.0.c13-00012-M8610BAAAANAZM-1 Compile Date: Aug 29 2014 Compile time: 11:13:42 Release date: Jun 20 2014 Release time: 00:00:00 IMEI: 014189000XXXXX5 Reading, wait. Simlock Status: SIMLOCK[1] Locked: Counter[10] Code: 4163133731 SIMLOCK[2] Unlocked Code: 0312820198 SIMLOCK[3] Unlocked Code: 4019219834 SIMLOCK[4] Unlocked Code: 0026271353 SIMLOCK[5] Unlocked Code: 1307756342 -------------------------- Log saved to: Sorry not sure when you said make a backup [read info] means what? Last edited by alifauad79; 02-06-2016 at 23:19. | |
02-06-2016, 23:23 | #41 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,262 | Quote: and make security backup |
02-08-2016, 12:03 | #43 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Backup is auto saved to backup directory. You can open manually or from settings push on button. And can be saved also with backup simlock button. It's really so hard this? |
02-08-2016, 12:09 | #44 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | @mhike777 HW_STORAGE_NAND meen phone have NAND flash ic, not EMMC flash ic. Usually clone phones have very unstable firmwares. Main idea when is maked this phone, is to sell, if it will work after also, then is super ok. So here can be lot of explanations, including some missing important system functions. What to do? is to reflash your phone. You maked backup before right? In case of clone or rare phones when is hard to find firmware is somehow logic move before do any. Code: Malware_160201_005626 Malware_160201_005755 Malware_160202_144055 Malware_160202_145212 Malware_160202_145633 |
