02-08-2019, 20:10 | #16 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Without this is very hard to make some | |
02-10-2019, 10:31 | #18 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Download area is just ok, i'am tested right now. First way: Download support acces from first tab, start it and download installer. Second way Start main module/settings tab/download installers button and download installer. If procedure is complicate for you, just explain it here, why you consider complicate this procedur ?. |
The Following User Says Thank You to orbita For This Useful Post: |
02-13-2019, 07:15 | #19 (permalink) |
No Life Poster Join Date: Sep 2013 Location: Mongolia
Member: 2022955 Status: Offline Sonork: 100.1646687 Thanks Meter: 418 | ZTE Q Pro ( P731A10 / ZTE T320 ) Code: ACTION: Read Simlock Info. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 2 Making 10 sec timeout.. Detected: SPRD U2S Diag (COM16) Platform Version MOCORTM_W15.22_DebugProject Version sc7731g_CP0_modemBASE Version TM_BASE_MP_II_W15.22HW Version sc7731g_CP0_modem05-26-2015 141212 Build number: P731A10-user 5.0.1 LRX21M eng.chenhua.20151021.172443 release-keys Serial number: MPGFB05N6C06323 IMEI 1: 867754024439345 IMEI 2: 867754024559340 BT: 4C16F19B2A48 WIFI: D05BA8865975 Reading simlock, wait.... [334528135:176660221][USER]Simlock Status: LOCKED[1] Simlock Counter:[7/10] [2]Simlock Type: 334528135 176660221 Sim 1 Unlock Code: 01938277 Sim 2 Unlock Code: 35740177 Warning, this is factory key, some opperators can modify factory key. Done. Firmware: ZTE_T320_RUV1.0.0B06.RUS_CHA_P731A10V1.0.0B16.2016 1122.101126.zip ZTE Blade L111 ( P731A70 ) Code: ACTION: Read Simlock Info. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Making 10 sec timeout.. Detected: SPRD U2S Diag (COM43) Platform Version MOCORTM_14B_TShark_OC_W16.27_DebugProject Version sc7731g_CP0_modemBASE Version TM_BASE_15A_W16.27HW Version sc7731g_CP0_modem06-29-2016 204651 Build number: LIF_BY_QB18D_P731A70V1.0.1B01 Serial number: 900642255047 IMEI 1: 861281030397933 IMEI 2: 861281030468239 BT: 18686AE6EE4D WIFI: 8C7967FF3923 Reading simlock, wait.... [178:172][USER]Simlock Status: LOCKED[1] Simlock Counter:[9/15] [5]Simlock Type: 178 172 Sim 1 Unlock Code: 7229032556121521 Sim 2 Unlock Code: 9640234808681687 Warning, this is factory key, some opperators can modify factory key. Done. Codes not work, but they are really 15 digits code. I select (Flash) and select (ZTE L110) -> (NV Backup) -> Unlock Direct -> Unlock done and work. NVRAM Lock : ZTE_ZTE_BLADE_L111_861281030397933_NVBACKUP.rar Please fix |
02-13-2019, 09:32 | #20 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | On some phones inside phone is stored hash only and here is nothing to fix, this is why we writed this warning. Send me nvram backup maked untill unlock for this phones, need to check this. On connection mode 1 should work direct unlock directly from diag mode. Not need to use flash mode. Last edited by orbita; 02-13-2019 at 09:42. |
