Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box
Old 02-08-2019, 19:10   #16 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,245
Originally Posted by basar View Post
Please HELP!
with Read Simlock Info I get this:
ACTION: Read Simlock Info.
Detecting phone, wait...
Phone must be off.
Connect usb cable without pressing any key.
Using connection mode 1
Detected: SCI USB2Serial (COM70)
Platform Version MOCORTM_17C_W18.23.4_P2_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.23.4_P2HW Version sc7731e_modem06-20-2018 111140
Build number: W_K120SUN-user 8.1.0 OPM2.171019.012 1536724428 release-keys
Serial number: LA051843001456
IMEI 1: 358074095529676
IMEI 2: 358074095610476
BT: 44D3AD348517
WIFI: 44D3AD346587
Reading simlock, wait....
[0:0][USER]Simlock Status: LOCKED[1] Simlock Counter:[10/10]
[0]Simlock Type: 0 0
Done.
BUT!!!
When I use Remove Simlock I get this error
ACTION: Unlock Phone.
Phone must be off.
BT: 44D3AD348517
WIFI: 44D3AD346587
[USER]Simlock Status: UNLOCKED
Saved to: C:\Users\GB\Documents\spreadtrum_module\backup\spd _simlock_nvram_backup\358074095529676__W_K120SUN_u ser_8_1_0_OPM2_171019_012_1536724428_release_keys_ LA051843001456\
This simlock type is not supported yet.
Abort opperation.
Done.
Can You do update please for this version??
Thanks in advance
Goran
You must upload backup, and tell exactly model name.
Without this is very hard to make some
Old 02-10-2019, 08:20   #17 (permalink)
abdurrahimsagar's Avatar
Member: 734476
Sonork: 100.1604415
Thanks Meter: 2,481
Download area site in not open but how to download?
Old 02-10-2019, 09:31   #18 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,245
Download area is just ok, i'am tested right now.
First way:
Download support acces from first tab, start it and download installer.
Second way
Start main module/settings tab/download installers button and download installer.
If procedure is complicate for you, just explain it here, why you consider complicate this procedur ?.
The Following User Says Thank You to orbita For This Useful Post:
Old 02-13-2019, 06:15   #19 (permalink)
huaweinckunlock's Avatar
Member: 2022955
Sonork: 100.1646687
Thanks Meter: 267
Wink
ZTE Q Pro ( P731A10 / ZTE T320 )
Phone must be off.
Using connection mode 2
Making 10 sec timeout..
Detected: SPRD U2S Diag (COM16)
Platform Version MOCORTM_W15.22_DebugProject Version
sc7731g_CP0_modemBASE  Version    TM_BASE_MP_II_W15.22HW Version
 sc7731g_CP0_modem05-26-2015 141212
Build number: P731A10-user 5.0.1 LRX21M eng.chenhua.20151021.172443 release-keys
Serial number: MPGFB05N6C06323
IMEI 1: 867754024439345
IMEI 2: 867754024559340
BT: 4C16F19B2A48
WIFI: D05BA8865975
[334528135:176660221][USER]Simlock Status: LOCKED[1] Simlock Counter:[7/10]
[2]Simlock Type: 334528135  176660221
Sim 1 Unlock Code: 01938277
Sim 2 Unlock Code: 35740177
Warning, this is factory key, some opperators can modify factory key.
Done.
Code not work, zte factory database code work 56276216.
Firmware: ZTE_T320_RUV1.0.0B06.RUS_CHA_P731A10V1.0.0B16.2016 1122.101126.zip
ZTE Blade L111 ( P731A70 )
Phone must be off.
Detected: SPRD U2S Diag (COM43)
Platform Version MOCORTM_14B_TShark_OC_W16.27_DebugProject Version
sc7731g_CP0_modemBASE  Version    TM_BASE_15A_W16.27HW Version
sc7731g_CP0_modem06-29-2016 204651
Build number: LIF_BY_QB18D_P731A70V1.0.1B01
Serial number: 900642255047
IMEI 1: 861281030397933
IMEI 2: 861281030468239
BT: 18686AE6EE4D
WIFI: 8C7967FF3923
[178:172][USER]Simlock Status: LOCKED[1] Simlock Counter:[9/15]
[5]Simlock Type: 178  172
Sim 1 Unlock Code: 7229032556121521
Sim 2 Unlock Code: 9640234808681687
Done.
Firmware: ZTE L111 GEN EG P731A70V1.0.0 B02 DownLoad Update AndroidHost.RU Build 05-05-17
Codes not work, but they are really 15 digits code.
I select (Flash) and select (ZTE L110) -> (NV Backup) -> Unlock Direct -> Unlock done and work.
NVRAM Lock : ZTE_ZTE_BLADE_L111_861281030397933_NVBACKUP.rar
Please fix
Old 02-13-2019, 08:32   #20 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,245
On some phones inside phone is stored hash only and here is nothing to fix, this is why we writed this warning.
Send me nvram backup maked untill unlock for this phones, need to check this.
On connection mode 1 should work direct unlock directly from diag mode.
Not need to use flash mode.
Old 02-13-2019, 09:01   #21 (permalink)
Member: 2022955
Sonork: 100.1646687
Thanks Meter: 267
This is no work. I test 4 phone. When will there be new phones I’ll drop NVRAM
Old 02-13-2019, 09:48   #22 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 5,245
Originally Posted by huaweinckunlock View Post
This is no work. I test 4 phone. When will there be new phones Iíll drop NVRAM
What you meen , not work?
Can you explain?
Old 02-21-2019, 19:42   #23 (permalink)
Yong Vannak's Avatar
Member: 770210
Thanks Meter: 44
thank you so much NCK PRO
Old 04-02-2019, 15:21   #24 (permalink)
Member: 1390266
Sonork: 100.1668465
Thanks Meter: 3
please add spd sc9820 cpu
Page generated in 0.27227 seconds with 7 queries
