07-23-2018, 04:43 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,213 | NCK Box / Pro Android MTK Module v1.8.9.2 Update Released - [23/07/2018] Tecno CA7 OPPO A77 Symphony R30, I90 Wiko Sunny 2 plus.
Bug Fixes & Improvements.
Official Support Website: NCK Box Download Support Access Software Link: DOWNLOAD LINK HERE |
The Following 41 Users Say Thank You to Fast Unlocking For This Useful Post: |
07-24-2018, 10:01 | #5 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
In this case you have posible ways to solve problem. 1.Use "Extract here" instead of open arhive. 2.Use another application, 7z for example. 3.Update your WinRar application. | |
The Following User Says Thank You to orbita For This Useful Post: |
07-25-2018, 10:35 | #7 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2215239 Status: Offline Sonork: [email protected] Thanks Meter: 0 | gsm how to nck box mt6592 frp reset not support your support solution |
08-01-2018, 08:08 | #11 (permalink) |
Freak Poster Join Date: Mar 2013 Location: ACCRA GHANA Age: 27
Member: 1908579 Status: Offline Thanks Meter: 21 | Nice update sir but other CPU s need serious update like Qualcomm and Spd doesn't have frp reset I tipped Nck to be best tool with non stop update |
08-01-2018, 12:23 | #12 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | sprd have frp reset for 7731g, 7731c, 7715, 7720 cpu from very long time and many users reported succes. Indeed, not exists separate button, you must select this function from scroll box, but really not see any problem to do this. Qualcomm support all modern cpu what is supported by other tools and posible more. If some loader is not supported, you can load it manually without problem. Supported EMMC and UFS filesystem(you can use search for logs) With FRP is same like with sprd, not exists separate button, you must scroll from list and select this function. Qualcomm not have on form model selection from very simple reason. Most phones work in autodetect mode and this simplify work, user not care what phone is, what filesystem it have. Usually work autodetection. |
08-04-2018, 19:37 | #13 (permalink) |
Freak Poster Join Date: Jun 2012 Location: united kingdom
Member: 1777637 Status: Offline Sonork: 100.1616860:md Thanks Meter: 45 | Hi, i am trying to repair imei on lenovo a101020 model and its says all done but imei still invalid, qny other option or help . Selected connection metod: Meta Connection Exe version: NCKBox AndroidMTK 1.8.9.1 Selected phone: A1010a20 Action : IMEI REPAIR. IMEI[1] for write : 861021030316529 IMEI[2] for write : 861021030316529 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [60]Detected: MediaTek PreLoader USB VCOM (Android) (COM60) \\?\usb#vid_0e8d&pid_2000#5&20f7cecd&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [356]META Port Detected: MediaTek USB VCOM (Android) (COM356) USB\VID_0E8D&PID_2007\5&20F7CECD&0&2 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6580,S01 [AP]APP_VER: A1010a20_S_USR_S404_1609102200_MP6V2_8G_TESCO_UK [META]BaseBand CPU : MT6580B, E00 [META]SW_VER : MOLY.WR8.W1449.MD.WG.MP.V23.P7 [META]HW_VER : HQ6580_WE_1LA_L_HSPA_HW Meta mode conected ok, start reading phone.... IMEI to repair: [1] 861021030316529 Phone imei[1] : 861021030316529 IMEI to repair: [2] 861021030316529 Phone imei[2] : 861021030316529 Clean Boot flag ok. All done. |
08-04-2018, 20:43 | #14 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Will try to give you sugestion only. Try to read exe help, phones with mediatek chipset can lost imei because of corupted security, because of corupted firmware, because of corupted nvram, because of hardware damage so on, so on so. Write imei will work only if imei is erased, in all other cases you must solve problem what cause this. |
08-07-2018, 14:59 | #15 (permalink) |
Junior Member Join Date: Mar 2017 Location: morocco
Member: 2696135 Status: Offline Sonork: 100.1621065 Thanks Meter: 1 | cant flash infinix x556 please help Flash files count is :13 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKBox AndroidMTK 1.8.8.8 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM8) Boot mode: Brom Using Algo 2. Phone detected...Please wait Sending DA agent, please wait... Scatter file loaded, not need emmi. Second stage DA fail, aborting BBCHIP MT6737M flash id: 150100514536334D42 [S_FT_ENABLE_DRAM_FAIL]Exe not support this emmi settings Please load scatter and preloader from phone fimware Boot Fail.!!!. All done. |
The Following User Says Thank You to anir93 For This Useful Post: |
