08-17-2019, 09:52 | #18 (permalink) |
Freak Poster Join Date: Nov 2013 Location: zimbabwe
Member: 2075865 Status: Offline Thanks Meter: 99 | mtn m560m3 network unlock, its a dual sim on diag option it says successifully unlocked but on reality it says insert mtn line on sim one to continue. Does this mean its permanently locked or doesn't supported yet. also does not give an option to insert lock code. its a new chipset sc7732e chip, which is supported in diag mode only |
08-17-2019, 16:04 | #19 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
Post exe log and provide me backup maked in diag mode with latest exe. | |
08-20-2019, 16:43 | #22 (permalink) |
Freak Poster Join Date: Jun 2014 Location: Ghana - Mozano
Member: 2203321 Status: Offline Thanks Meter: 46 | Imo q3 plus unlocked successfully by nck spd Procedure: 1. Connect phone (powered off) 2. Enable Diag 3. Perform unlock (Read code or direct unlock) ACTION: Read Simlock Info. Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SPRD U2S Diag (COM3) Platform Version MOCORTM_17B_Release_W18.31.3_DebugProject Version sharkle_Smart_PhoneBASE Version FM_BASE_17B_Release_W18.31.3HW Version sc9832e_modem08-01-2018 120150 Build number: IMO_Q3_Plus_series-user 8.1.0 O21019 1534316701 release-keys IMEI 1: 35264010012**** IMEI 2: 86740002031**** Serial number: 5007SP18GIM***** BT: 300AC5152160 WIFI: 300AC515545A Reading simlock backup, wait.... Saved to: C:\Users\CHIEF\Documents\spreadtrum_module\backup\ spd_simlock_nvram_backup\352640100125456_5007SP18G IM8012745_diag_simlock_nvram_backup.tar UID: 5431424338325F315F32385F32300A0A000000000000000000 00000000000000 [2]Old simlock detected, processing.... [9:9][USER]Simlock Status: LOCKED[1] Simlock Counter:[10/10] [2]Simlock Type: 9 9 Sim 1 Unlock Code: 05046263 Sim 2 Unlock Code: 22284497 Warning, this is factory key, some opperators can modify factory key. Done. |
08-27-2019, 14:32 | #23 (permalink) |
Member: 2075865 Status: Offline Thanks Meter: 99 | ACTION: Direct Unlock Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SCI USB2Serial (COM6) Platform Version MOCORTM_17C_W18.41.3_P13_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.41.3_P13HW Version sc7731e_modem03-04-2019 141517 Build number: VDC_ZA_P731K30V1.0.0B06 IMEI 1: 861486040325150 IMEI 2: 867400020316620 Serial number: 722585726156 BT: 4859A470A8CD WIFI: 60146694670E Reading simlock backup, wait.... Saved to: C:\Users\Etechnology\Documents\spreadtrum_module\b ackup\spd_simlock_nvram_backup\861486040325150_722 585726156_diag_simlock_nvram_backup_4.tar UID: 5432374134385F365F355F34310A0A00000000000000000000 00000000000000 [4]Unsupported Simlock Type Done. Add zte L130 kicka 4 VE NWK unlock unsuppoted |
09-06-2019, 10:58 | #25 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 99 | Quote:
as i am an old user of nck dongle in new update i did not found sc7731E cpu in flash mode tab and i have tried some qmobile models before for frp operation but not sucessfull.in new update haven't tried so far.so,please add in flash mode tab sc7731e. thanks | |
09-06-2019, 12:46 | #26 (permalink) | |
Here is few reports with this cpu, you can find more. Belive me, search is very usefull function in this forum http://forum.gsmhosting.com/vbb/f805...l#post13674670 http://forum.gsmhosting.com/vbb/f805...l#post13687413 http://forum.gsmhosting.com/vbb/f805...l#post13703982 http://forum.gsmhosting.com/vbb/f805...l#post13706518 http://forum.gsmhosting.com/vbb/f805...l#post13783729 http://forum.gsmhosting.com/vbb/f805...l#post13804258 We maked for our user usefull function called "custom loader" Even if model is not listed, you can make your loader from factory pac firmware and service phone. If you are old user, is really strange how you not know about. | |
10-14-2019, 15:57 | #27 (permalink) |
Member: 2075865 Status: Offline Thanks Meter: 99 | ACTION: Direct Unlock Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SCI USB2Serial (COM6) Platform Version MOCORTM_17C_W18.41.3_P13_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.41.3_P13HW Version sc7731e_modem03-04-2019 141517 Build number: VDC_ZA_P731K30V1.0.0B06 IMEI 1: 861486040463209 IMEI 2: 867400020316620 Serial number: 722585718378 BT: 4859A4732201 WIFI: 60146697ECD8 Reading simlock backup, wait.... Saved to: C:\Users\Etechnology\Documents\spreadtrum_module\b ackup\spd_simlock_nvram_backup\861486040463209_722 585718378_diag_simlock_nvram_backup_1.tar UID: 5432374134385F345F32335F370A0A00000000000000000000 00000000000000 [4]Unsupported Simlock Type Done. zte blade L130 network lock pliz add |
11-14-2019, 08:27 | #29 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Your windows not allow to save this file. Can be multiple reasons. read-only directory, insufficient space on hdd, antivirus or firewall block thisn file. Any from this can cause this problem. |
11-22-2019, 19:51 | #30 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1667553 Status: Offline Thanks Meter: 0 | hi, please add WIKO Y80 ACTION: Direct Unlock Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 1 Detected: SPRD U2S Diag (COM80) Platform Version MOCORTM_18B_W19.08.1_P12_DebugProject Version sharkl3_pubBASE Version FM_BASE_18B_W19.08.1_P12HW Version sc9863A_modem06-04-2019 162426 Build number: v720-user 9 PPR1.180610.011 9 release-keys IMEI 1: 356769103884912 IMEI 2: 356769103924916 Serial number: JAF21934002693 BT: 0CEC847B13E1 WIFI: 0CEC847B0441 Reading simlock backup, wait.... Saved to: C:\Users\Microbot Servis\Documents\spreadtrum_module\backup\spd_siml ock_nvram_backup\356769103884912_JAF21934002693_di ag_simlock_nvram_backup_20.tar UID: 5433364D36375F335F32305F33300A0A000000000000000000 00000000000000 [4]Unsupported Simlock Type Done. |
