06-28-2018, 08:02 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: <...< Egypt >...>
Member: 2821459 Status: Offline Thanks Meter: 806 | Oppo Neo5 1201 Repair Boot Done By Flash On NCK Box.. Oppo Neo5 1201 Repair Boot Done By Flash On NCK Box.. ... Read Info ... Code: Action : Boot Info. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 1.8.9.1 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB VCOM (Android) (COM5) Boot mode: Brom Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... [emmi]EMMC CID: 460001154d3231335a ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+8192Mb) SAMSUNG 0x463331324d42 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 150100463331324D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM7) This phone have FRP partition. Model: 1201 Brand: OPPO Device: 1201 Display ID: 1201EX-A_11_160412 Mediatek Version Release: 1201EX-A_11_A.05_160412 Build ID: LMY47I Version: 5.1 Build Date: Tue Apr 12 18:28:30 CST 2016 Region: US Mediatek Version Release: 1201EX-A_11_A.05_160412 IMEI[1]: 861537037xxxxxx IMEI[2]: 861537037xxxxxx Wait untill phone will start charging. All done. ـــــــــــــــــــــــــــــ ... Flash Done Log Is Here ... Code: Flash files count is :12 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKBox AndroidMTK 1.8.9.1 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB VCOM (Android) (COM5) Boot mode: Brom Using Algo 1. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6582 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+8192Mb) SAMSUNG 0x463331324d42 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 150100463331324D42 : 00000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM7) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. ... Thanks NCK Team ... |
The Following User Says Thank You to Elgendi For This Useful Post: |
