01-23-2014, 03:03 | #1621 (permalink) |
No Life Poster Join Date: May 2007 Location: Islamic city of Marawi
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Phone imei : 86139202113981 Simlock Info : Sim(1) Block1(N ):Locked (remain:5) Code : 67758028 Block2(NS):Unlocked Code: 56781234 Block3(SP):Unlocked Code: 11112222 Block4(C ):Unlocked Code: 33334444 Block5(SIM):Unlocked Code: 55556666 Start direct unlock... Simlock Info : Sim(2) Block1(N ):Locked (remain:5) Code : 67758028 Block2(NS):Unlocked Code: 56781234 Block3(SP):Unlocked Code: 11112222 Block4(C ):Unlocked Code: 33334444 Block5(SIM):Unlocked Code: 55556666 Start direct unlock... All done. |
The Following User Says Thank You to amyll For This Useful Post: |
01-23-2014, 23:21 | #1622 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,207 | I9300 Upgrade to 4.3 Code: Model Selected: GT-I9300 Start Detect device. Device detected OK: COM4 Downloading.. Get PIT for mapping.. PIT Saved to: backup\samsung_pit\GT-I9300_samsung_pit_1.pit Firmware update start.. Loading: boot.img, wait. Processing: boot.img Loading: cache.img, wait. Processing: cache.img Loading: hidden.img, wait. Processing: hidden.img Loading: modem.bin, wait. Processing: modem.bin Loading: recovery.img, wait. Processing: recovery.img Loading: sboot.bin, wait. Processing: sboot.bin Loading: system.img, wait. Processing: system.img Loading: tz.img, wait. Processing: tz.img Resetting, wait until phone restart. Total Time: 00:05:15 -------------------------- Log saved to: logs\GT-I9300_flash_1.txt |
The Following 2 Users Say Thank You to Fast Unlocking For This Useful Post: |
01-24-2014, 11:05 | #1623 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Alcatel OT 3040G done Code: DA version: 5.1224.04.89 Connect phone in boot mode ... Start detecting port.. Com port ok : COM129 Phone detected...Please wait Download DA now...You can release power on Getting phone info .... BaseBand CPU:MT6250_S0001 BaseBand CPU Secure Version : 5 (Secure baseband) FLASH TYPE : NOR ID: NOR:(128Mb+128Mb) [GigaDevice] GD25Q16 size:0x01000000 INT RAM: 424Kb RAM: 128Mb SRAM BOOT STYLE :S_SF_FLASH_BOOT(1031) Phone Succussfully Unlocked. CLOSING COM PORT HANDLE... ALL DONE. |
01-25-2014, 12:38 | #1624 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 630 | Blackberry 8300 unlock by usb cable Code: PIN: 2592e01e Hardware id: 0x84000F03 Device:RIM 8300 Series Colour GPRS Hand Build date: Nov 8 2007 Imei:358265018333994 PRD-18797-002 MEP-16472-001 -------------------------- MEP1 :9608515018709216 MEP2 :4917362366001428 MEP3 :7248420782336869 MEP4 :2352915185161925 MEP5 :2764948692228605 -------------------------- All done by nckDongle -------------------------- Log saved to: logs\358265018333994_MEP-16472-001.doc |
The Following User Says Thank You to Dilip_Nath For This Useful Post: |
01-25-2014, 16:56 | #1625 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Serbia
Member: 1425628 Status: Offline Thanks Meter: 235 | Alcatel Ot990 flashing Code: Start Detect device. Port : ALCATEL HS-USB Diagnostics 9017 (COM12) Device detected ok... Preparing to send loader,please wait.. Port : ALCATEL HS-USB Diagnostics 9017 (COM12) Version :76XXT-6180-TSNCJOLYM Sending loader,please wait.. DL Port detected. Port : ALCATEL HS-USB Diagnostics 9017 (COM12) DL device : ALCATEL HS-USB Diagnostics 9017 (COM12) Loader started ok, reading data... Version : 990X-2DTNRS3 IMEI : 35576904278xxxx Sending : PARTITION size : 464 bytes Sending partition table ok. Sending image : QCSBL_HD size : 11.39 KB Sending image : QCSBL size : 56.26 KB Sending header : OEMSBL_HD size : 40 bytes Sending image : OEMSBL size : 485.79 KB Sending header : APPSBL_HD size : 40 bytes Sending image : APPSBL size : 94.47 KB Sending header : AMSS_HD size : 40 bytes Sending image : AMSS size : 17.21 MB Sending image : SECURITY size : 1.05 KB Sending image : BOOT size : 3.52 MB Sending image : SYSTEM size : 78.58 MB Sending image : USERDATA size : 2.06 KB Sending image : CUSTPACK size : 92.68 MB Sending image : RECOVERY size : 3.76 MB Sending image : StudyPara size : 161.11 KB All done.. |
The Following User Says Thank You to bratori For This Useful Post: |
01-26-2014, 06:04 | #1626 (permalink) |
No Life Poster Join Date: Jan 2013 Location: NCK Team
Member: 1873869 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,333 | Code: Module Ver. : 1.2 Com Port : COM90 Baud Rate : 921600 Device : ZTE S1602 Operation : SP UNLOCK Port opened. Compile : Nov 07 2011 10:16:05 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.S1 ESN : 8085A617 MEID : A0000034DE21CF MemUnlock : Success Build : V.MTS.S1602.B01 Detected : S1602 User Code : 0000 Setting Download mode... Mode change OK. Waiting for reconnect... Init flash protocol... Flash Chip : NUMONYX M36W0R6050U4ZSd Chip Size : 8 MB Patching security area... Patching success. Resetting phone... Phone successfully unlocked. Port closed. Operation finished. Elapsed Time: 00:13 Log saved as \!Log\LOG_14_01_26_10_32_46.log |
01-26-2014, 11:06 | #1627 (permalink) |
No Life Poster Join Date: Nov 2010 Location: THE MOBILE SHOP
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.2 Com Port : COM152 Baud Rate : 115200 Device : ZTE S100 Operation : SP UNLOCK Port opened. Compile : Apr 14 2010 11:36:12 Release : Oct 24 2006 13:00:00 Hw Ver. : MTS_S100 ESN : B2579080 MEID : A000001B566670 MemUnlock : Success Build : QSC6010-SCNRZ-MTS_S100_RBTL40NV1.0.1B02 Detected : S100 User Code : 0000 Switching to Offline... Offline Mode OK. Sending SPC... Executing unlock... Phone successfully unlocked. Resetting phone... Port closed. Operation finished. Elapsed Time: 00:02 |
The Following User Says Thank You to sunilkumar70791 For This Useful Post: |
01-26-2014, 12:13 | #1628 (permalink) |
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.0 Com Port : COM11 Baud Rate : 115200 Device : Huawei C2829 Operation : Read Info Port opened. Reading information.. Compile : Release : 6ÅÇ Hw Ver. : ª ESN : 80085D6C MEID : A1000035ACD3F6 BUILD : QSC6010-SCNRZ-.... SW Ver Boot Reading extended information... User Code : 0000 SPC : 000000 Port closed. Operation finished. Elapsed Time: 00:01 |
01-26-2014, 12:13 | #1629 (permalink) |
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.0 Com Port : COM11 Baud Rate : 115200 Device : Huawei C2856 Operation : Read Info Port opened. Reading information.. Compile : Oct 20 2008 10:47:27 Release : Mar 29 2007 20:00:00 Hw Ver. : SCNRZ... ESN : 80085D6C MEID : A1000035ACD3F6 BUILD : QSC6010-SCNRZ-.... SW Ver Boot Reading extended information... User Code : 0000 SPC : 000000 Port closed. Operation finished. Elapsed Time: 00:01 |
01-26-2014, 12:15 | #1630 (permalink) |
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.1 Com Port : COM125 Baud Rate : 115200 Device : ZTE S165 Operation : SP UNLOCK Port opened. Compile : Jul 19 2012 12:05:47 Release : Apr 24 2009 24:00:00 Hw Ver. : RIC_S165 ESN : 808B06C5 MEID : A100002395B4D6 MemUnlock : Success Build : RIC_S165_RBTL21NV1.0.0B02 Detected : S165 User Code : 0000 Setting Download mode... Mode change OK. Waiting for reconnect... Init flash protocol... Flash Chip : SPANSION S71VS064RB0d Chip Size : 8 MB Patching security area... Patching success. Resetting phone... Phone successfully unlocked. Port closed. Operation finished. Elapsed Time: 00:12 |
01-26-2014, 12:16 | #1631 (permalink) |
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.1 Com Port : COM137 Baud Rate : 115200 Device : Samsung B229 Operation : Read Info Port opened. Reading Information... Compile : Sep 20 2012 02:02:00 Release : Jun 25 2009 B229.0 Hw Ver. : SWNEALZ3 ESN : 80F813DD MEID : A0000044FD8DB9 Executing Security Unlock... Sending SPC (305476)... SPC accepted User Code : 6777 Port closed. Elapsed Time: 00:06 |
01-27-2014, 05:33 | #1633 (permalink) |
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Module Ver. : 1.2 Com Port : COM11 Baud Rate : 9600 (Auto) Device : Samsung S189 Operation : Full Rebuild Setting test mode... Executing full rebuild... Operation finished. Port closed. Elapsed Time: 00:02 samsung s189 Module Ver. : 1.2 Com Port : COM11 Baud Rate : 9600 (Auto) Device : Samsung S189 Operation : Unlock Port opened. Setting test mode... Step 1... Step 2... Resetting phone... Phone must restart if everything OK! Operation finished. Port closed. Elapsed Time: 00:06 |
01-27-2014, 09:08 | #1634 (permalink) |
Member: 502507 Status: Offline Sonork: 100.1648947 Thanks Meter: 154 | Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM81) Phone detected...Please wait Sending DA agent, please wait... OTP IMEI : 013766000661950 MODEL FW: 4033A-2ESAPH1 Reading security, wait... SECRO FW : X2A0SS00AAPH1 NCK : 00073020 NSCK : 21319014 SPCK : 20457587 SPCK : 20546376 Simlock backup already exists, skip save. All done. |
01-27-2014, 09:08 | #1635 (permalink) |
