12-13-2017, 21:40 | #6016 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: Jamaica Age: 38
Member: 441875 Status: Offline Thanks Meter: 24 | FRP Removed with NCKBOX Quote:
12-14-2017, 07:02 | #6017 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Unlock Done............... Selected connection metod: FLASH Mode Exe version: NCKDongle AndroidMTK 2.5.8.2 Selected model: OT-7024W Action: Unlock Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MTK USB Port (COM457) Boot mode: Brom Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6589 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (29Gb+8192Mb) MICRON 0x503058585858 EMMC FW VERSION: 10:00:00:00:00:00:00:00 EMMC CID: FE014E50305858 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9300000 [3.644 GB] Preloader SEC version: 2 Status: USB_FULL_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM262) MODEL FROM PROINFO: 7024W-2BTBUS1 SECRO FROM PROINFO: X1L0UM00AC10 OTP IMEI: 013763005370539 Reading security, wait... SIM[1]: Block1(N): Locked (remain:2) Code : 0251502774 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C): Unlocked Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. |
12-14-2017, 13:00 | #6018 (permalink) |
No Life Poster Join Date: Apr 2008 Location: INSIDE OCLHASHCAT
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | N900P 4.4.2 unlock done Found Device : 8aa060a5 MODEL : SM-N900P BOARD ID : MSM8974 PLATFORM ID : msm8974 OS VERSION : 4.4.2 BUILD ID : KOT49H BUILD DATE : Tue Mar 18 14:18:12 KST 2014 BUILD VERSION : KOT49H.N900PVPUCNC5 SOFTWARE VERSION : N900PVPUCNC5 IMEI : 9900xxxxx (GSM)RIL VERSION : Samsung RIL v3.0 (GSM)BASEBAND : N900PVPUCNC5 (RIL)SERIAL NUMBER : 00xxxx (RIL)SW VERSION : N900PVPUCNC5 (RIL)(RIL)HW VERSION : N900P.12 Found Device : 8aa060a5 Checking Root access: True Unlocking please Wait. Unlock Done, Restarting Phone! Total Time: 00:00:19 |
12-14-2017, 17:10 | #6019 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Philippines
Member: 1813688 Status: Offline Sonork: Davidlab Thanks Meter: 39 | ALLVIEW V2 Viper I FRP Remove Exe version: NCKDongle AndroidMTK 2.5.8.2 Selected model: MT6580 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM10) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+8192Mb) SAMSUNG 0x463832324d42 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 15010046383232 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
12-15-2017, 11:32 | #6020 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Hungary, Gyor Age: 43
Member: 20861 Status: Offline Thanks Meter: 15 | Succesfully unlocked Navon supreme fine micro phone with nck-box sprd module Here is the log: " EXE: NckBox Spreadtrum Module 0.4 SELECTED: SC7720EA_EMMC 5.x ACTION: Unlock Phone Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SCI Anroid USB2Serial (COM8) BOOT: SPRD3 Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. Reading extended info, wait... FileSystem: EMMC Manufacturer: Navon Hardware: SP7731C_V1.0.0 Platform: sc8830 Board: sp7731cea Build Id: NRD90M Model: Supreme_Fine_Micro Android Release: 7.0 Android Version: Supreme_Fine_Micro_V06_20170912_113753 IMEI 1: 86414603******7 IMEI 2: 86740002******0 SIMLOCK USER DATA Simlock Status: LOCKED[1] Simlock Counter:[0] Ex Locks: 0 SIMLOCK USER DATA END Simlock Type: 3 Start write unlock, wait... Total Time: 00:00:20 Done. " |
The Following User Says Thank You to trabyka For This Useful Post: |
12-15-2017, 12:02 | #6021 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Walton R4+ FRP Done Exe version: NCKDongle AndroidMTK 2.5.8.2 Selected model: MT6735 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM156) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 2. ---------------------------------------------------- BaseBand CPU :MT6735 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 3 GB DRAM ---------------------------------------------------- EMMC: (116Gb+24576Mb) SAMSUNG 0x523331424142 EMMC FW VERSION: 06:00:00:00:00:00:00:00 EMMC CID: 15010052333142 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
12-15-2017, 13:43 | #6022 (permalink) |
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | MT6571 user lock remove by reset Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [16]Detected: MediaTek PreLoader USB VCOM (Android) (COM16) \\?\usb#vid_0e8d&pid_2000#6&8ca65f9&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [19]META Port Detected: MediaTek USB VCOM (Android) (COM19) USB\VID_0E8D&PID_2007\6&8CA65F9&0&2 Start sync target, waiting responce..... Resetting phone, wait.... Resetting phone step 2, wait.... Reset to factory default ok. All done. |
12-15-2017, 14:03 | #6023 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Selected connection metod: META Mode Exe version: NCKBox AndroidMTK 1.8.8.3 Selected model: MT6580 Action: Unlock Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [81]Detected: PreLoader USB VCOM Port (COM81) \\?\usb#vid_0e8d&pid_2000#6&310cd63b&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [271]META Port Detected: Gadget CDC VCOM Driver (COM271) USB\VID_0E8D&PID_2007\6&310CD63B&0&2 Start sync target, waiting responce..... [AP]BaseBand CPU : mt6580,S01 [META]BaseBand CPU : MT6580, E01 [META]SW_VER : MOLY.WR8.W1449.MD.WG.MP.V91.5.P15 [META]HW_VER : TINNO6580_WE_N_HSPA_HW Phone imei[1] : 35404009041AAA6 Phone imei[2] : 35404009044AAA7 Start direct unlock[SIM1] Direct unlock done Start direct unlock[SIM2] Direct unlock done Clean Boot flag ok. All done. |
12-16-2017, 17:44 | #6024 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | INFINIX X557 FRP DONE Action : Boot Info. Code: Selected 0-By CPU:MT6580 Exe version: NCKDongle AndroidMTK 2.5.8.2 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM14) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514531334d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 15010051453133 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED This phone have FRP partition. Build ID: MRA58K Display ID: X557-H807A1D1-M-170424V237 Version: 6.0 Build Date: Mon Apr 24 18:54:22 CST 2017 Model: Infinix HOT 4 Brand: Infinix Device: X557 Mediatek Version Release: X557-H807A1D1-M-170424V237 IMEI[1]: 35840608XXXXXXX IMEI[2]: 35840608XXXXXXX Wait untill phone will start charging. All done. Code: Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM14) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT6580 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x514531334d42 EMMC FW VERSION: 0d:00:00:00:00:00:00:00 EMMC CID: 15010051453133 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
12-16-2017, 18:04 | #6025 (permalink) |
Junior Member Join Date: May 2016 Location: morroco Age: 38
Member: 2580010 Status: Offline Thanks Meter: 0 | vodafone 610 secure 7.0 frp bypassed by the amazing NCKBOX Detected : MediaTek USB Port (COM22) Boot mode: Brom Phone detected...Please wait Sending DA agent, please wait... Using Algo 2. ---------------------------------------------------- BaseBand CPU :MT6737M BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 1 GB DRAM ---------------------------------------------------- EMMC: (116Gb+12288Mb) SAMSUNG 0x513331364242 EMMC FW VERSION: 01:00:00:00:00:00:00:00 EMMC CID: 15010051333136 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. Proud to use this box. |
12-17-2017, 09:25 | #6026 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | HTC 620g Reset done Action : Reset to factory default. Selected Model: HTC:HTC 620 Exe version: NCKDongle AndroidMTK 2.5.8.2 Scanning for presents meta ports... Phone must be off with battery inside. Please insert USB cable now... In some phones need to keep VOL- button untill inserting USB cable. [156]Detected: MediaTek PreLoader USB VCOM (Android) (COM156) \\?\usb#vid_0e8d&pid_2000#6&8ca65f9&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [409]META Port Detected: MediaTek USB VCOM (Android) (COM409) USB\VID_0E8D&PID_2007\6&8CA65F9&0&2 Start sync target, waiting responce..... Resetting phone, wait.... Resetting phone step 2, wait.... Reset to factory default ok. All done. |
12-17-2017, 13:17 | #6027 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Stylus Q60 SPD FRP Done. Android 7.0 EXE: NckDongle Spreadtrum Module 0.5 SELECTED: SC7720EA_EMMC 5.x ACTION: Reset FRP Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM253) BOOT: SPRD3 Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. Reading extended info, wait... FileSystem: EMMC Manufacturer: sprd Hardware: SP7731C_V1.0.0 Platform: sc8830 Board: sp7731cea_fs286 Build Id: NRD90M Model: Q60 Android Release: 7.0 Android Version: 7731C_FS286_SBYH_G505_Q60_STYLUS_V01_20170923_1409 IMEI 1: 352518090001160 IMEI 2: 352518090001178 [USER]Simlock Status: UNLOCKED Simlock Type: 0 Removing frp, wait... Format OK. Total Time: 00:00:21 Done. |
12-17-2017, 14:20 | #6028 (permalink) |
Member: 751235 Status: Offline Sonork: 100.1662008 Thanks Meter: 526 | LG-MS323 AT&T userlock remove Waiting for Phone Ack.. Sending Loader.. Reading Phone Information.. Model : LGMS323 SW Verion : LGMS323AT-00-V10c-MTP-US-AUG-25-2014+0 Android Verion : 4.4.2 IMEI : 01410xxx Product ID : CT65S150225xxx H/W Version : rev_10 Removing Selected Screen Lock(s).. OK Enabling Usb Debug... OK Rebooting to Normal Mode... OK All Done.. |
12-17-2017, 15:08 | #6029 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | tecno c9 copy frp done. EXE: NckBox Spreadtrum Module 0.5 SELECTED: SC7731G_EMMC 5.x ACTION: Reset FRP Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SCI USB2Serial (COM4) BOOT: SPRD3 Sending loader, keep boot key untill loader start. Reconnecting phone... Detected: SCI USB2Serial (COM4) Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. Reading extended info, wait... FileSystem: EMMC Manufacturer: XLL Hardware: SP7731GEA_V1.0.0 Platform: sc8830 Board: s02_q23 Build Id: LMY47D Model: TECNO-J8 Android Release: 5.1 Android Version: C9-H535-A1-M-HiOS-20160601 IMEI 1: 358073070699785 IMEI 2: 358073070699793 [USER]Simlock Status: UNLOCKED Simlock Type: 0 Removing frp, wait... Format OK. Total Time: 00:00:26 Done. |
12-18-2017, 19:23 | #6030 (permalink) |
Member: 1813688 Status: Offline Sonork: Davidlab Thanks Meter: 39 | mobiwire unlock choosing Alcatel 1052D USB Connection selected. EXE VERSION: NCKDongle MTK Tool 1.50 Connect phone in boot mode ... USB\VID_0E8D&PID_0003&REV_0100 Com port ok : COM21 Phone detected...Please wait Conected ok with target ... Starting meta mode..... IMEI[1]: 352441082145996 IMEI[2]: 352441082145996 Start read, wait.... Block1[N]: Locked (remain:0) Code : 12345678 Block2[NS]: Unlocked Block3[SP] Unlocked Block4[C]: Unlocked Unlock file done Unlock file done Processing done. Unlock done. Clean tmp directory....wait. Clean tmp directory....done. META END OK. All done. |
