09-16-2014, 15:47 | #2326 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: Macedonia Age: 53
Member: 79576 Status: Offline Thanks Meter: 18 | Quote:
Confirmed working unlock 6037y Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB VCOM (MT6516 Android) (COM217) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6582_S00 EMMC: (58Gb+8192Mb) SAMSUNG 0x4b3758564d42 EMMC FW VERSION: 01:00:00:00:00:00:00:00 BOOT STYLE : EMMC BOOT Detecting high speed port, wait...... If driver not installed, install high speed port driver. Detected : DA USB VCOM Port (COM317) MODEL FW: 6037Y-2BCFMK1 OTP IMEI : 8646940213***** Reading security, wait... ......SIM 1........... Block1(N) : Locked (remain:9) Code : 74143656 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked ......SIM 2........... Block1(N) : Locked (remain:10) Code : 74143656 Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked ............... ............... Unlocking target...please wait. Unlock finished. Wait untill phone will start charging. All done. | |
The Following User Says Thank You to ekvinoks For This Useful Post: |
09-17-2014, 12:44 | #2332 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | alcatel one touch 5020a unlock done by nck dongle Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6575_S01 EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 Detecting high speed port, wait...... Detected : QMobile DA USB VCOM Port (COM37) OTP IMEI : 0135xxxxxxxxxxx MODEL FW: 5020A-2BVDAU1 Reading security, wait... SECRO FW : X2A0OV03AB00 NCK : 20771329 : Locked NSCK : 08317126 : Unlocked SPCK : 15558611 : Unlocked SIM : 26642104 : Unlocked If lock counter is 0, make "RESET PHONE" from exe. Simlock saved to : C:\NCK TEAM\NCK Dongle Android MTK Module\simlock_backup\5020A-2BVDAU1_X2A0OV03AB00_backup.nsb Wait untill phone will start charging. All done. |
The Following User Says Thank You to quasim0438 For This Useful Post: |
09-17-2014, 16:02 | #2333 (permalink) |
No Life Poster Join Date: Nov 2007 Location: UK
Member: 629391 Status: Offline Thanks Meter: 396 | VM575 Unlock done SELECTED : VM575 Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press "*" key while inserting the battery. Detected: SPRD U2S Diag (COM34) Download mode ok. BOOT: SPRD3 Sending loader, wait. BOOT OK: Spreadtrum Boot Block version 1.2 CPU: 6531 Changing Baud. Start UNLOCK, wait. Reading NV. Model: 1060X-2AVGGB3 Backup saved: backup\spd_nvram_backup\VM575_3522730xxxxxxxx_save d_nv_1.bin Simlock exists. Write Done. Job done. |
The Following User Says Thank You to mojee For This Useful Post: |
09-17-2014, 22:34 | #2334 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | Huawei E8338BWs-2 Webcube UNLOCKED with NCK BOX Software: NCK BOX v4.4 Module: Huawei Modems Even though this model is not listed, I selected "Huawei New Secirity" and Models "E353Ws-2" and tried also "B153 WebCube" Result was the same for both models. IMEI checksum seems ok Brand: HUAWEI MODEM Model: B153 WebCube IMEI: 86698601XXXXXXX FLASH CODE(OLD) : 34688402 UNLOCK CODE(OLD) : 63240284 UNLOCK CODE(NEW) : 77624850 So I tried the unlock code that was calculated and it WORKED. Thanks NCk Team! Cheers X4ce |
The Following 3 Users Say Thank You to excessive For This Useful Post: |
09-18-2014, 14:15 | #2337 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | Lg 3600 flash done.... LG show after blue lcd problum solve..... Code: Module Ver. : 1.9 Com Port : COM3 : USB Serial Port (COM3) Baud Rate : 115200 - Auto Device : LG RD3600 Operation : Flash (Emergency) Protect EFS : Enabled Port opened. Detected : RD3600 Preparing phone... Sending Bootloader... Initializing Bootloader, Please wait... Bootloader Running OK. Erasing Flash... Erase finished. Flash File : RD360F05_00.bin File Size : 0x00300000 Writing Flash... Flash write done. Resetting phone... Operation finished. Port closed. Elapsed Time: 06:16 |
09-18-2014, 16:17 | #2340 (permalink) |
Freak Poster Join Date: Aug 2013
Member: 1995502 Status: Offline Thanks Meter: 139 | Blackberry 8900 unlock Reading data, do not disconnect phone, wait..... Connecting, please wait OS NV : 1984-2000 Hardware ID : 0x84001503 FS Nand FAT : 1984-2000 OS Version : 4.2.0.127 Pin :210379b5 Device: BlackBerry 8900 Curve[0x84001503] Trying to connect phone Please wait take a while... MEP : MEP-09292-004 PRD : PRD-19374-031 Backup saved in folder backup... Challenge RTAS Signature... [5]Preparing to process... Processing... Calculating succes... Modifying Phone Data... 0 MEP Unlock Done All Done. -------------------------- Log saved to: logs\0x84001503_210379b5_mep0_1.txt |
