05-25-2013, 15:12 | #1201 (permalink) | |
No Life Poster Join Date: May 2012 Location: NCK Team
Member: 1761928 Status: Offline Sonork: 100.1626169 Thanks Meter: 804 | Quote:
05-27-2013, 18:03 | #1204 (permalink) |
No Life Poster Join Date: Apr 2003
Member: 26692 Status: Offline Thanks Meter: 51 | OT871a Att alcatel unlocked ok nck flash tool 1.22 using usb and right drivers its faster than serial Connect phone in boot mode ... Start detecting port.. Com port ok : COM6 Phone detected...Please wait Conected ok with target ... BaseBand CPU : MT6276 SW Version : MAUI.11A.W11.12.SP1.V8.F10 HW Version : JRD76_11A_GEMINI_HW Reopen comport(COM6) Meta mode conected ok, start reading phone.... Phone imei : 01316000100xxxx Unlock OK META END OK. All done. |
05-27-2013, 18:32 | #1205 (permalink) |
No Life Poster Join Date: May 2010 Location: FLAT EARTH
Member: 1295624 Status: Offline Thanks Meter: 152 | COMPORT : COM8 Selected : GT-E1086W: SYSOL Press and keep Power ON!!! Boot OK. Loading Preloader, keep press power on. Send Preloader OK. Flash ID : 0006 Flash Name : K5N3217ATA_TOP Loading Mainloader.. Send Mainloader ok. Reading Eeprom Data.. Analyzing Data.. - Firmware : E1086WBJB1_H - Imei : 351880040689192 Code1 Found: 09891450 Master Unfreeze: 28182390 Done. -------------------------- Log saved to: logs\GT-E1086W_unlock.doc |
05-27-2013, 20:29 | #1206 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | DA version: 5.1224.00.00 Connect phone in boot mode ... Start detecting port.. Com port ok : COM11 Phone detected...Please wait Download DA now...You can release power on DA download finished...Getting phone info BaseBand CPU:MT6235B_S00 BaseBand CPU Secure Version : FF INT RAM: 512Kb EXT RAM: 512Mb DRAM FLASH TYPE : NAND ID: NAND1Gb) [ST] ST01GR3B size:0x08000000 ACTION FORMAT : NAND FLASH : BEGIN(0x04000000) - END(0x04000000). Format done. ALL DONE. |
05-28-2013, 07:43 | #1207 (permalink) |
Freak Poster Join Date: Aug 2005 Location: India
Member: 173081 Status: Offline Thanks Meter: 352 | EC156 Unlocking Success with NCK CDMA 0.7 EC156 Unlocking Success with NCK CDMA 0.7 EC156 Read Info :- After this step, I write Generic firmware provided at NCK Box support for EC156. EC156 Unlocking :- The best part for unlocking with NCK Cdma is, we don't have to write ruim settings, it automatically unlock & set Ruim setting to Ruim Only, This function is not available in other tools. EC156 Read Info after Unlock :- EC156 Ruim if Available :- If u want to use your old tata photon+ connection then use above option (Ruim if Available), Without Sim it use our previous connection & with sim it uses the connection provided by sim operator. This is 100% tested by me, I unlock my working Tata Photon+ EC156 With NCK CDMA 0.7. Thanks for NCKBOX team & Supporters for this big update ...... Regards Ajay Gupta Last edited by ajaystarin; 05-28-2013 at 07:50. |
The Following User Says Thank You to ajaystarin For This Useful Post: |
05-28-2013, 17:19 | #1208 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Romania Age: 46
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | OT-918 flash ok Code: Flash files count is :9 DA version: 3.3001.00.00 Phone must be off with battery inside. Please insert USB cable now... Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6573_S01 BaseBand CPU Secure Version : 05 BaseBand CPU Bootloader Version : FE ---------------------------------------------------- RAM: 2048Mb DRAM ---------------------------------------------------- NAND: (4Gb) [MICRON] MT29F4G16ABD size:0x0020000000 ---------------------------------------------------- Format NAND flash: begin_addr(0x004A0000), length(0x1F160000). Send preloader... Download firmware to flash now... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... ANDROID checksum is executing ... CUSTPACK1 checksum is executing ... All done. |
05-28-2013, 17:25 | #1209 (permalink) |
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | OT-918 nck code read ok Code: Phone must be off with battery inside. Please insert USB cable now... Phone detected, switch to meta mode, wait.... This can take up to 30 sec, do not disconnect phone. Meta mode conected ok, start reading phone.... Phone imei : 860767000XXXXX Simlock Info : Sim(1) Block1(N ):Locked (remain:10) Code : 29780372 Block2(NS):Unlocked Code: 34726498 Block3(SP):Unlocked Code: 33555477 Block4(C ):Unlocked Code: 34158093 Block5(SIM):Unlocked Code: 31393199 1.Power phone with unacepted simcard. 2.Type code code when phone ask about. 3.For advansed info power phone with original card. 4.Type *#*#3646633#*#* and from engeneering menu select SIMMELOCK Simlock saved to : C:\NCK Dongle\NCK Dongle Alcatel Android MTK Tool\simlock_backup\860767000XXXXX_backup.nsb All done. |
05-31-2013, 02:02 | #1212 (permalink) |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | t679 unlock done with nck box t679 unlock done successfully with nck box |
The Following User Says Thank You to headszone1 For This Useful Post: |
05-31-2013, 04:41 | #1215 (permalink) | |
Freak Poster Join Date: Jun 2011 Location: manila/makati city/philippines
Member: 1598381 Status: Offline Sonork: 1595992 Thanks Meter: 20 | u8500 done thanks to nck family,,,,,,,,,,,,,, Quote:
