05-25-2016, 14:51 | #46 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 934 | G520-T10 slow when opening solved by flash via nck Action : Firmware update. Selected Model: 0-By CPU: MT6589 Exe version: NCKBox AndroidMTK 1.8.6.7 Scenario: Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM6) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6589_S01 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (28Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 86:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe7000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe7600000 [3.615 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM30) Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. FORMAT EMMC FLASH : BEGIN: 0x50780000 - LEN: 0x7e00000 FORMAT EMMC FLASH : BEGIN: 0x58580000 - LEN: 0x8db80000 Send preloader... Download firmware to flash now... Wait untill phone will start charging. All done. thank u nck team |
The Following 2 Users Say Thank You to dereje For This Useful Post: |
05-25-2016, 15:54 | #47 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | Y520-u22 recovery only solved by nck when power on the set only opens on recovery mode after firmware write phone works perfect thanks nck team |
The Following User Says Thank You to dereje For This Useful Post: |
05-25-2016, 16:09 | #48 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | Wiko LENNY privacy unlock done via nck it is supported by generic Exe version: NCKBox AndroidMTK 1.8.6.7 Selected model: MT6572_EMMC Action: Reset Privacy Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM6) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6572_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 512 MB DRAM ---------------------------------------------------- EMMC: (29Gb+4096Mb) HYNIX 0x483447316404 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48344731 : 000000000000000000 EMMC UA SIZE: 0xe9000000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0xe9c00000 [3.652 GB] Dumping data, wait. Value found, procesing[010c][00460000] Resetting phone. FORMAT EMMC FLASH : BEGIN: 0x44540000 - LEN: 0xa41c0000 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. All done. cheers nck team |
05-26-2016, 10:26 | #49 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | lenevo A316i hung logo done by generic via nck box lenevo A316i hung logo done by generic via nck box Flash files count is :12 Action : Firmware update. Selected Model: 0-By CPU: MT6592 Exe version: NCKBox AndroidMTK 1.8.6.7 Scenario: Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM256) Phone detected...Please wait Sending DA agent, please wait... BaseBand CPU :MT6592_S00 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) HYNIX 0x484147326504 EMMC FW VERSION: 05:00:00:00:00:00:00:00 EMMC CID: 90014A48414732 : 000000000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac400000 [14.691 GB] Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detecting high speed port, wait...... Detected : MediaTek DA USB VCOM Port (COM376) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader saved in firmware directory. Starting flash. Download firmware to flash now... Wait untill phone will start charging. All done. thanks nck team |
05-28-2016, 16:09 | #50 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | Huawei Ascend Y330-U11 boot loop fixed via nck Flash files count is :14 Action : Firmware update. Selected Model: Huawei: Ascend Y330-U11 Exe version: NCKBox AndroidMTK 1.8.6.7 Scenario: Safe Flash Parsing firmware, wait. [22]Rom Count. Connecting phone. Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM Port (COM6) Phone detected...Please wait Sending DA agent, please wait... BBCHIP MT6572_S00 EMMC FW VERSION: 51:00:00:00:00:00:00:00 EMMC CID: 11010030303447393051CC5C042F1227 EMMC UA SIZE: 0xec000000 BOOT STYLE: EMMC BOOT Partitions count: 22 Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Dumping preloader. Preloader backup already exist, skip saving. Start Flashing. Send preloader... Download firmware to flash now... MBR checksum is executing ... EBR1 checksum is executing ... UBOOT checksum is executing ... BOOTIMG checksum is executing ... RECOVERY checksum is executing ... SEC_RO checksum is executing ... LOGO checksum is executing ... EBR2 checksum is executing ... ANDROID checksum is executing ... CUST checksum is executing ... CACHE checksum is executing ... USRDATA checksum is executing ... Wait untill phone start charging. All done. nck box |
05-30-2016, 09:28 | #51 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | SM-G361H frp fast in a second unlock done via nck sam tool Device detected OK. Bypassing data, wait.... Bypass ok. Reading Data,wait.... Done Chipset: SPRD8735 Data Found, processing... Resetting FRP, wait.. FRP OFF... Done Now you can wipe phone to remove remaining data... Restarting Phone Restart Ok All Done Done. -------------------------- Log saved to: C:\Users\dereje\Documents\nck_samsung\logs\SM-G361H_frp_reset__1.txt thanks nck team |
05-30-2016, 12:21 | #52 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | samsung SM-J100H original simlock unlock done via nck sam tool unlocking log yes it is fast unlo king Detecting phone, wait.. Detected: Modem (COM76) Port: Modem (COM76) Phone Detected. SM-J100H Model: SM-J100H Base: SM-N900 Version: J100HXCU0AOD1/J100HSWR0AOD1/J100HXCU0AOD1/J100HXCU0AOD1 PRD: SM2J100HZKASWR SN: RV1G822AWFY IMEI: 353010075141103 SIMLOCK:LOCKED Unlocking, wait. Unlock Done. If Phone Ask For Code, Enter 00000000. For check lock use: *#7465625# -------------------------- Log saved to: C:\Users\dereje\Documents\nck_samsung\logs\SM-J100H__unlock__1.txt Done. thanks to nck team |
05-30-2016, 13:49 | #53 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | SM-G531F frp unlocked as SM-G531H suported SM-G531F frp unlocked as SM-G531H supported Device detected OK. Bypassing data, wait.... Bypass ok. Reading Data,wait.... Done Chipset: PXA1L88 Data Found, processing... Resetting FRP, wait.. FRP OFF... Done Now you can wipe phone to remove remaining data... Restarting Phone Restart Ok All Done Done. -------------------------- Log saved to: C:\Users\dereje\Documents\nck_samsung\logs\SM-G531H_frp_reset__1.txt |
06-01-2016, 06:46 | #54 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | SAMSUNG SM-E700F boot loop fixed by nck sam tool 0.8.3 flash log Model Selected: SM-E700F Device detected OK: Modem (COM8) Downloading.. Total Size: 2035153108 Get PIT for mapping.. Chipset: MSM8916 Firmware update start.. Loading: aboot.mbn, wait. Processing: aboot.mbn Size: [1.11 MB] [1160604] Loading: sbl1.mbn, wait. Processing: sbl1.mbn Size: [271.24 KB] [277748] Loading: rpm.mbn, wait. Processing: rpm.mbn Size: [179.7 KB] [184008] Loading: tz.mbn, wait. Processing: tz.mbn Size: [390.04 KB] [399400] Loading: hyp.mbn, wait. Processing: hyp.mbn Size: [52.32 KB] [53576] Loading: NON-HLOS.bin, wait. Processing: NON-HLOS.bin Size: [9.83 MB] [10307328] Loading: sec.dat, wait. Processing: sec.dat Size: [684 bytes] [684] Loading: boot.img, wait. Processing: boot.img Size: [10.07 MB] [10559760] Loading: recovery.img, wait. Processing: recovery.img Size: [11.38 MB] [11927824] Loading: system.img.ext4, wait. Processing: system.img.ext4 Size: [1.7 GB] [1826687188] lastSequenceBytes: 2164948 Loading: modem.bin, wait. Processing: modem.bin Size: [43.53 MB] [45647616] lastSequenceBytes: 14190336 Loading: cache.img.ext4, wait. Processing: cache.img.ext4 Size: [97.77 MB] [102514896] lastSequenceBytes: 8143056 Loading: hidden.img.ext4, wait. Processing: hidden.img.ext4 Size: [24.25 MB] [25432476] Resetting, wait until phone restart. ************************************* Log saved: C:\Users\dereje\Documents\Avengers\Saved_Logs\SM-E700F_flashing_log_1.txt Total Time: 00:03:02 NCK BOX - Reaching Above & Beyond For YOUR Business Rock N Roll with Hot Summer Update ;-) |
06-03-2016, 09:17 | #55 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | GT-i9100 update to 4.1.2 sucsesfully GT-i9100 update to 4.1.2 sucsesfully Model Selected: GT-I9100 Device detected OK: Modem (COM8) Downloading.. Total Size: 974131296 Get PIT for mapping.. Firmware update start.. Loading: boot.bin, wait. Processing: boot.bin Size: [128 KB] [131072] Loading: data.img, wait. Processing: data.img Size: [34.82 MB] [36512528] lastSequenceBytes: 5055248 Loading: factoryfs.img, wait. Processing: factoryfs.img Size: [462.87 MB] [485352648] lastSequenceBytes: 13493448 Loading: hidden.img, wait. Processing: hidden.img Size: [386.88 MB] [405670364] lastSequenceBytes: 28183004 Loading: param.lfs, wait. Processing: param.lfs Size: [1.22 MB] [1277952] Loading: Sbl.bin, wait. Processing: Sbl.bin Size: [1.25 MB] [1310720] Loading: zImage, wait. Processing: zImage Size: [8 MB] [8387840] Loading: modem.bin, wait. Processing: modem.bin Size: [12 MB] [12583168] Loading: cache.img, wait. Processing: cache.img Size: [21.84 MB] [22905004] Resetting, wait until phone restart. ************************************* |
06-04-2016, 10:18 | #56 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | Samsung Gt-i9300 flash done via nck sam tool Samsung Gt-i9300 flash log Model Selected: GT-I9300 Device detected OK: Modem (COM8) Downloading.. Total Size: 1312883316 Get PIT for mapping.. Chipset: Mx Firmware update start.. Loading: boot.img, wait. Processing: boot.img Size: [5.27 MB] [5525760] Loading: param.bin, wait. Processing: param.bin Size: [760 KB] [778240] Loading: recovery.img, wait. Processing: recovery.img Size: [5.95 MB] [6236416] Loading: sboot.bin, wait. Processing: sboot.bin Size: [866.25 KB] [887040] Loading: system.img, wait. Processing: system.img Size: [1.04 GB] [1120434788] lastSequenceBytes: 19429988 Loading: tz.img, wait. Processing: tz.img Size: [156 KB] [159744] Loading: modem.bin, wait. Processing: modem.bin Size: [12 MB] [12583168] Loading: cache.img, wait. Processing: cache.img Size: [53.67 MB] [56279524] lastSequenceBytes: 24822244 Loading: hidden.img, wait. Processing: hidden.img Size: [104.9 MB] [109998636] lastSequenceBytes: 15626796 Resetting, wait until phone restart. ************************************* |
06-07-2016, 15:45 | #57 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | samsung note 3 SM-G900t unlock in a second in nck sam tool samsung note 3 SM-G900t unlock in a second in nck sam tool Unlock metod[1]. Port: SAMSUNG Mobile USB Serial Port (COM140) Build id: M8974A-AAAANAZM-2.0.10059 Version info: Nov 12 201418:56:26May 09 201420:00:00AAAAANAZ:d IMEI: 358021059455554 Unlocking, wait.... Job done, if phone not restart, restart manually nck sam tool |
06-07-2016, 18:41 | #58 (permalink) | |
Freak Poster Join Date: Dec 2013
Member: 2095587 Status: Offline Thanks Meter: 36 | GiONEE M5_LITE Gionee M5_Lite imei repair Done Quote:
The Following User Says Thank You to hamim ctg For This Useful Post: |
06-08-2016, 10:09 | #59 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | This is howe the new & fast sp meta mode works SM-J100H MT6572 NAND IMEI REPAIR WITH NEW FAST SP META MODE IMEI 1 REPAIR LOG Selected connection metod: SpMeta Connection Exe version: NCKBox AndroidMTK 1.8.6.9 Selected phone: MT6572_NAND Action : IMEI REPAIR. IMEI for write : 353407100108968 Curent Platform: MT6572 Phone must be off with battery inside. Please insert USB cable now... [46]Detected: MediaTek PreLoader USB VCOM (Android) (COM46) \\?\usb#vid_0e8d&pid_2000#5&f86e282&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [141]META Port Detected: MediaTek USB VCOM (Android) (COM141) USB\VID_0E8D&PID_2007\5&F86E282&0&4 Start sync target, waiting responce..... Starting META using port[COM141], wait... Brand: samsung Board: sc7727s Model: SM-J100H Name: Galaxy J1 Release: ALPS.KK1.MP7.V1 Version: 4.4.2 Platform: MT6572 BUILD_ID: ALPS.KK1.MP7.V1 NVRAM Dumped OK. C:\Users\dereje\Documents\Android_MTK\nvram_backup \META_MODE_NVRAM_MT6572_SM-J100H_06_08_2016_11_55_16.zip IMEI[1] TO UPDATE: 353407100108968 Calculated checksum: d11e1a74 Writing data, wait.... IMEI repair OK. All done. IMEI 2 REPAIR LOG Selected connection metod: SpMeta Connection Exe version: NCKBox AndroidMTK 1.8.6.9 Selected phone: MT6572_NAND Action : IMEI REPAIR. IMEI for write : 355780440214011 Curent Platform: MT6572 Phone must be off with battery inside. Please insert USB cable now... [46]Detected: MediaTek PreLoader USB VCOM (Android) (COM46) \\?\usb#vid_0e8d&pid_2000#5&f86e282&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Starting META mode, wait... Restarting to meta,wait.... If drivers missing, please install CDC drivers. This can take up to 5 min on slow phones. If take too long, check device manager for drivers. [141]META Port Detected: MediaTek USB VCOM (Android) (COM141) USB\VID_0E8D&PID_2007\5&F86E282&0&4 Start sync target, waiting responce..... Starting META using port[COM141], wait... Brand: samsung Board: sc7727s Model: SM-J100H Name: Galaxy J1 Release: ALPS.KK1.MP7.V1 Version: 4.4.2 Platform: MT6572 BUILD_ID: ALPS.KK1.MP7.V1 NVRAM Dumped OK. C:\Users\dereje\Documents\Android_MTK\nvram_backup \META_MODE_NVRAM_MT6572_SM-J100H_06_08_2016_11_58_06.zip IMEI[2] TO UPDATE: 355780440214011 Calculated checksum: bd5b59b7 Writing data, wait.... IMEI repair OK. All done. THANKS TO NCK TEAM |
06-09-2016, 10:12 | #60 (permalink) |
Member: 449991 Status: Offline Thanks Meter: 934 | SAMSUNG GT-I8262 slow when opening fixed by nck sam tool flash log Model Selected: GT-I8262 Device detected OK: Modem (COM8) Downloading.. Total Size: 1266172700 Get PIT for mapping.. Chipset: MSM8x25 Firmware update start.. Loading: appsbl, wait. Processing: appsbl Size: [518.09 KB] [530520] Loading: boot.img, wait. Processing: boot.img Size: [5.02 MB] [5263616] Loading: persist.img.ext4, wait. Processing: persist.img.ext4 Size: [4.18 MB] [4378760] Loading: recovery.img, wait. Processing: recovery.img Size: [5.7 MB] [5980416] Loading: system.img.ext4, wait. Processing: system.img.ext4 Size: [1.01 GB] [1081899884] lastSequenceBytes: 12352364 Loading: userdata.img.ext4, wait. Processing: userdata.img.ext4 Size: [22.7 MB] [23802760] Loading: fat.bin, wait. Processing: fat.bin Size: [19.51 MB] [20452608] Loading: cache.img.ext4, wait. Processing: cache.img.ext4 Size: [71.1 MB] [74551696] lastSequenceBytes: 11637136 Loading: hidden.img.ext4, wait. Processing: hidden.img.ext4 Size: [46.33 MB] [48578864] lastSequenceBytes: 17121584 Resetting, wait until phone restart. |
