08-07-2018, 07:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | TIT-AL00 (Y6 PRO) flasing fail. i have TIT-AL00 for dead repair. i try to flash with reding frimwaer but fail. Flash files count is :16 Action : Firmware update. Selected Model: Huawei: Ascend Y6 Pro[TIT-AL00] ME Exe version: NCKBox AndroidMTK 1.8.9.2 Scenario: [0]Safe Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM148) Boot mode: Preloader Using Algo 2. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6735 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (117Gb+16384Mb) HYNIX 0x484147326505 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 90014A484147326505 : 00000000000000 EMMC UA SIZE: 0x3ab800000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac400000 [14.691 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM70) Warning, flashing preloader disabled! If you change android version, preloader must be flashed. Flash EMMC Algo Start. Preloader backup already exist, skip saving. Starting flash. Send preloader... Error: Is not posible to write readed firmware in this phone. This phone will accept only factory signed firmware. Wait untill phone will start charging. All done. |
08-07-2018, 09:28 | #3 (permalink) |
Member: 757297 Status: Offline Thanks Meter: 36 | Tit-al00 [QUOTE=orbita;13257430]Try to read exe log, if you not understand exactly exe log, you can use any time google translate.[/QUOTENOW PHONE FLASH DONE BUT SHOWING BLUE LIGHT ONLY I HAVE 2 PICE ON SAME PROBLAM. NEED TESTED FRIMWAER. |
08-07-2018, 11:40 | #4 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | If you flashed by other tool what ignore this error and killed completly phone, well ....bad luck. Exe gived you very detailed log, problem was not with exe, problem was with incompatible firmware. Android MTK exit with error on incompatible firmware and not allow to kill phone. To make phone alive try to read posted by you log again. Exe gived you hint where is your problem. |
08-08-2018, 08:35 | #5 (permalink) | |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | Quote:
