07-18-2017, 18:38 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Zimbabwe
Member: 2100642 Status: Offline Thanks Meter: 46 | z10 stl 100-1 red light blinking after autoload Reading info, please wait... Connecting to Bootrom: Connected QNX Device Info: PIN: 2b9322f8 BSN: 1142181550 Bootrom Version: 5.33.0.44 Hardware ID: 0x04002607 RIM BlackBerry Device HW ID Override: 0x04002607 (OSTypes: 0x00000010) Hardware OS ID: 0x06001A06 BR ID: 0xFF000072 Metrics Version: 6.43 Build Date: Jan 3 2013 Build Time: 16:55:08 Build User: ec_agent Security: Enabled Supported Options: 0x00002FC9 Drivers: 0x00000010 Processor: 0x00000020 FlashID: 0x00000000 LDR Blocks: 0x800295B4 Bootrom Size: 0x00080000 Persist Data Addr: 0x800F0000 External MCT/HWV: Enabled Boot Mode: Product Trustzone Info: Version: 1.7.2.6 Buildtime: Supported: 4460/4470 - 0x7 Debug type: Off/Secure - 0x2 Traces: Disabled - 0x1 Key Size: 1024 - 0x0 Emif Obf: Off - 0x1 Efuse Lib: CP_PPA_SWRV_ONLY - 0x1 Extra Flags: 0x1 Boot OS Count: 0,0,0 (Region0,Region1,Max) 2,0,0 (Version,Requested Region,Actual Region) JTAG SW Support: Disabled RPMB Support: Enabled WP Mode: Permanent Slack Mode: Disabled OS Blocking by Date: Enabled Oldest Allowed MFI: 12/4/2012 Oldest Allowed SFI: 11/23/2012 Sec BR Flags: 0x00000001 Sec Boot Count: 0x00000000 Sec Retry Count: 0x00000000 HWV: Board Revision 0x01 - 0x14 CPU Version 0x02 - 0x12 SW Compatibility 0x03 - 0x01 POP Revision 0x04 - 0x02 CPU Family 0x05 - 0x01 Power Mgt Hardware 0x07 - 0x46 POP Security 0x0B - 0x01 GPS 0x0C - 0x21 Hearing Aid Compat 0x37 - 0x01 WCDMA Band supported 0x3B - 0x07 BSIS support 0x41 - 0x02 Power Seq Compat 0x44 - 0x00 NFC 0x49 - 0x09 ISP 0x4E - 0x01 Mem Config Table (ver 1.28): Flash Chip: blocks 0-262143, Chip 0, Sub 0 Boot0 MMC: blocks 0-0, total = 1, flags = 0x0001 Boot1 MMC: blocks 1-8, total = 8, flags = 0x0001 User MMC: blocks 9-262143, total = 262135, flags = 0x0003 MCT: block 0 Bootrom 2nd: blocks 1-8 Bootrom: blocks 9-16 OS NV: blocks 2057-2120, total 64 MBR: blocks 2121-2136 OS Fixed: blocks 2137-18504 OS Extended: blocks 18505-18952 Radio Fixed: blocks 18953-21000 FS Fixed: blocks 21001-262143, total = 241143 MMC Enhanced: blocks 9-1928, total 1920 QNX region 0: blocks 2137-10312, total = 8176 QNX region 1: blocks 10329-18504, total = 8176 QNX Partition: type=0x01, flags=0x80, blocks 2121-10312, total = 8192, "os" QNX Partition: type=0x06, flags=0x20, blocks 2121-2121, total = 1, "os_mbr" QNX Partition: type=0x07, flags=0x40, blocks 2136-2136, total = 1, "os_sig" QNX Partition: type=0x89, flags=0x40, blocks 2136-2136, total = 1, "os_sig" QNX Partition: type=0x08, flags=0x40, blocks 2137-2312, total = 176, "system" QNX Partition: type=0x09, flags=0x40, blocks 2313-10312, total = 8000, "os_fsys" QNX Partition: type=0x01, flags=0x80, blocks 10313-18504, total = 8192, "os" QNX Partition: type=0x06, flags=0x20, blocks 10313-10313, total = 1, "os_mbr" QNX Partition: type=0x07, flags=0x00, blocks 10328-10328, total = 1, "os_sig" QNX Partition: type=0x89, flags=0x00, blocks 10328-10328, total = 1, "os_sig" QNX Partition: type=0x08, flags=0x00, blocks 10329-10504, total = 176, "system" QNX Partition: type=0x09, flags=0x00, blocks 10505-18504, total = 8000, "os_fsys" QNX Partition: type=0x11, flags=0x80, blocks 18505-18952, total = 448, "dmi" QNX Partition: type=0x12, flags=0x00, blocks 18505-18505, total = 1, "dmi_mbr" QNX Partition: type=0x93, flags=0x00, blocks 18520-18520, total = 1, "dmi_sig" QNX Partition: type=0x13, flags=0x00, blocks 18521-18952, total = 432, "dmi_fsys" QNX Partition: type=0x02, flags=0x80, blocks 18953-21000, total = 2048, "radio" QNX Partition: type=0x0A, flags=0x20, blocks 18953-18953, total = 1, "radio_mbr" QNX Partition: type=0x0B, flags=0x40, blocks 18968-18968, total = 1, "radio_sig" QNX Partition: type=0x8C, flags=0x40, blocks 18968-18968, total = 1, "radio_sig" QNX Partition: type=0x0C, flags=0x40, blocks 18969-19976, total = 1008, "radio_fsys" QNX Partition: type=0x0A, flags=0x20, blocks 19977-19977, total = 1, "radio_mbr" QNX Partition: type=0x0B, flags=0x00, blocks 19992-19992, total = 1, "radio_sig" QNX Partition: type=0x8C, flags=0x00, blocks 19992-19992, total = 1, "radio_sig" QNX Partition: type=0x0C, flags=0x00, blocks 19993-21000, total = 1008, "radio_fsys" QNX Partition: type=0x05, flags=0x80, blocks 21001-262143, total = 241143, "user" RAM Chip: 0x80000000-9FFFFFFF, Bank Size 536870912 RAM Chip: 0xA0000000-BFFFFFFF, Bank Size 536870912 RAM Chip: 0xC0000000-DFFFFFFF, Bank Size 536870912 RAM Chip: 0xE0000000-FFFFFFFE, Bank Size 536870912 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x17ff0006 0x00ff0015 NAND Config: type 3, data 0x00000140 0x00ff0015 CRC: 0x27AA7C3A Flash: Number of chips: 1 Flash ID: NAND blocks 0-236648 Device ID: 0x10 Vendor ID: 0x15 Manufacturer Name: Samsung OEM/Application ID: 0x100 Product Name: MAG2GA Product Revision: 0x12 Product Serial Number: 0xD912A190 Manufacturing Date: Year 1998, Month 2 MMC Partition Info: Boot0: 2048 KB (enhanced) Boot1: 2048 KB (enhanced) User: 122880 KB (enhanced) User: 15022080 KB Total Size: 14790 MB DRAM: Size: 2048 MB VendorID: 0x1 Vendor Name: Samsung Revision: 0x100 Memory Map: NAND Blocks: 236649 * 64 Kb RAM Base: 0x80000000 IRAM Base: 0x40304000 OS Range: 2137 - 18504 File System: Memory Map: 21001 - 236648 Sectors: 215648 Branding: ECID: 266 OS * Not present * OS Blocklist: range: From 0.0.0.0 DEV To 255.31.31.8191 PROD type: Unsupported,Untrusted range: From 0.0.0.0 DEV To 10.3.2.658 DEV type: SFI range: From 4.0.10.0 DEV To 4.0.10.513 DEV type: MFI range: From 4.0.11.0 DEV To 4.0.11.307 DEV type: MFI range: From 127.0.0.0 DEV To 127.0.1.4892 DEV type: SFI Radio Blocklist: range: From 0.0.0.0 DEV To 0.0.0.0 DEV Done. |
The Following User Says Thank You to 4mula For This Useful Post: |
