Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > ZTE
ZTE General ZTE phones discussion, firmwares, solution, help
Old 08-24-2017, 08:34   #1 (permalink)
Usmonov Rustam's Avatar
Member: 2251886
Thanks Meter: 160
Blade A520 FRP RESET Done !!!
Blade A520 FRP RESET Done TESTED Android 7
1. Download File https://ufile.io/31sa8
2. Run SP_Flash_Tool_exe_Windows_v5.1712.00.000
3. Load the file
4 Go to Format
5. Select manual format flash - and write in begin adress 0x6a80000, and in the second (format length) 0x100000. Press the start button. We connect the switched off device - we wait for green ОК.
The Following 34 Users Say Thank You to Usmonov Rustam For This Useful Post:
Old 09-16-2017, 06:37   #2 (permalink)
Member: 593138
Thanks Meter: 17
everybody try this and sucess?
The Following User Says Thank You to kenjimoh For This Useful Post:
Old 09-26-2017, 08:21   #3 (permalink)
Member: 2251886
Thanks Meter: 160
File For Reset FRP Download New Link 4Shared:
https://www.4shared.com/rar/eOiOdwRj...Reset_FRP.html
The Following 15 Users Say Thank You to Usmonov Rustam For This Useful Post:
Old 09-26-2017, 14:31   #4 (permalink)
Member: 2739449
Thanks Meter: 185
Thank you. Perfect solution!
Old 09-26-2017, 15:13   #5 (permalink)
Member: 614328
I try already but still can’t open FRP lock
Old 10-08-2017, 10:00   #6 (permalink)
siang8788's Avatar
Member: 205283
Thanks Meter: 80
no working...got other solution?
Old 10-08-2017, 10:28   #7 (permalink)
Celmaster2's Avatar
Member: 1526099
Sonork: 100.1579632
Thanks Meter: 84
need conect phone pressing vol-
Enviado desde mi CAM-L03 mediante Tapatalk
The Following 9 Users Say Thank You to Celmaster2 For This Useful Post:
Old 10-24-2017, 13:50   #8 (permalink)
Member: 2724957
Thanks Meter: 2
Thanks , work for my ZTE Blade A520...
The Following 2 Users Say Thank You to Amane Senmatsu For This Useful Post:
Old 11-17-2017, 23:02   #9 (permalink)
Member: 2712067
Someone has the Driver to connect the ZTE Blade A520 to FlashTool ..
Thanks friends.
The Following User Says Thank You to Lruano210 For This Useful Post:
Old 12-03-2017, 16:50   #10 (permalink)
Member: 1280253
Thanks Meter: 142
in my case holding both volume + and volume - together and then connecting the phone worked ...
might help someone ...
br
The Following 4 Users Say Thank You to manbir For This Useful Post:
Old 03-27-2018, 11:19   #11 (permalink)
Crazy Poster
Member: 58939
Thanks Meter: 6
Volume - and insert cable -work
The Following User Says Thank You to stivga1 For This Useful Post:
Old 04-24-2018, 20:54   #12 (permalink)
Member: 168168
Thanks Meter: 6
Thanx, worked with volume down and insert cable...
Old 05-27-2018, 10:22   #13 (permalink)
tatalko's Avatar
Member: 32002
Thanks Meter: 24
I got message "enable dram failed"
Hint: "Please chek your load matches to your target which is to be downloaded"
I'm trying to link files from the link above.
Old 05-28-2018, 21:20   #14 (permalink)
Member: 2110113
x2 help please I got too message "enable dram failed"
Old 06-06-2018, 12:06   #15 (permalink)
Member: 1117809
Sonork: 100.1661551
Thanks Meter: 66
thank you so much for share this file, i tryed with many box,dongle and special frp tool but not success after that search in forum than found your post and work like a boooom thanks again.
Page generated in 0.22781 seconds with 10 queries
