ZTE General ZTE phones discussion, firmwares, solution, help |
08-24-2017, 08:34 | #1 (permalink) |
Freak Poster Join Date: Sep 2014 Location: TASHKENT
Member: 2251886 Status: Offline Thanks Meter: 160 | Blade A520 FRP RESET Done !!! 1. Download File https://ufile.io/31sa8 2. Run SP_Flash_Tool_exe_Windows_v5.1712.00.000 3. Load the file 4 Go to Format 5. Select manual format flash - and write in begin adress 0x6a80000, and in the second (format length) 0x100000. Press the start button. We connect the switched off device - we wait for green ОК. |
The Following 34 Users Say Thank You to Usmonov Rustam For This Useful Post: |
09-26-2017, 08:21 | #3 (permalink) |
Member: 2251886 Status: Offline Thanks Meter: 160 | File For Reset FRP Download New Link 4Shared: https://www.4shared.com/rar/eOiOdwRj...Reset_FRP.html |
The Following 15 Users Say Thank You to Usmonov Rustam For This Useful Post: |
12-03-2017, 16:50 | #10 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Classified
Member: 1280253 Status: Offline Thanks Meter: 142 | in my case holding both volume + and volume - together and then connecting the phone worked ... might help someone ... br |
The Following 4 Users Say Thank You to manbir For This Useful Post: |
05-27-2018, 10:22 | #13 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Serbia Age: 49
Member: 32002 Status: Offline Thanks Meter: 24 | I got message "enable dram failed" Hint: "Please chek your load matches to your target which is to be downloaded" I'm trying to link files from the link above. |
05-28-2018, 21:20 | #14 (permalink) | |
Junior Member Join Date: Jan 2014
Member: 2110113 Status: Offline Thanks Meter: 1 | Quote:
Hint: "Please chek your load matches to your target which is to be downloaded" | |
06-06-2018, 12:06 | #15 (permalink) |
Major Poster Join Date: Sep 2009 Location: BTelecom-Hajigonj,Chandpur,BD Age: 34
Member: 1117809 Status: Offline Sonork: 100.1661551 Thanks Meter: 66 | thank you so much for share this file, i tryed with many box,dongle and special frp tool but not success after that search in forum than found your post and work like a boooom thanks again. |
