ZTE General ZTE phones discussion, firmwares, solution, help |
04-09-2015, 22:43 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 639798 Status: Offline Thanks Meter: 0 | Digicel DL800 (ZTE Blade G Lux / V830) flash needed i need flash it any help plz Last edited by Brka; 10-15-2015 at 20:37. Reason: added model info in title |
04-09-2015, 23:14 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
Nothing to do with alcatel ..... but - it's MTK CPU inside, MT6572 ... Official SD-Card update rom can be found HERE, look under country SPAIN, and product - blade lux g. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
04-10-2015, 19:26 | #4 (permalink) | |
(ROM is for SPFlashTool, it should remove privacy password after flashing) On that link, you also have modded rom from PHILIPS S308 (in form of update.zip, for custom recovery) HERE is another backup for custom recovery, put it on internal storage or sdcard, path : /clockworkmod/backup Two Custom recoveries with instructions - download HERE warning: READ NVRAM partition first, before playing ! use attached scatter, go to tab READ MEMORY, add, select save location, name file NVRAM.bin, enter start address : 0x1000000 , length : 0x500000 read it ... and after, you can play (FULL FORMAT phone, etc.). b.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
04-14-2015, 14:10 | #5 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | ZTE Blade G Lux Scatter File Help Hi I need to unlock this Blade G Lux The phone have Privacy Protection Password lock But I cant get the solution yet Anyone can help me please ? Many thanks and regards |
04-14-2015, 22:40 | #6 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 183 | Quote:
i use the first file flash with spflashtool now mobile is dead | |
05-05-2015, 17:45 | #7 (permalink) |
Crazy Poster Join Date: Jan 2014
Member: 2109210 Status: Offline Sonork: 100.1668991 Thanks Meter: 3 | Help Firmware Sp flasher For Zte blaze g lux Help Firmware Sp flasher For Zte blaze g lux FCC ID= SQR-ZETV830W the phone is death i need sp flsher firmware asap tanks for help |
06-24-2015, 18:02 | #9 (permalink) |
Member: 1643797 Status: Offline Thanks Meter: 183 | yes i use ******* box and read file from working phone and write to damage phone . only have this backup file Last edited by Brka; 06-24-2015 at 20:29. Reason: no box adverts here, sorry. |
06-24-2015, 18:47 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Jamaica Age: 41
Member: 162707 Status: Offline Thanks Meter: 66 | May i get this backup file? After reading NVRAM and I flash the phone how to put back the NVRAM to the phone? I flash my phone with the sptool flash provided here but now my phone is dead. Please I am awaiting your speedy response. |
06-24-2015, 20:33 | #11 (permalink) | |
After flashing preloader, dsp_bl and uboot, boot, recovery, EBR1 phone should charge on usb cable. Flash file I posted is reported to be working. Of course, user is the one that takes risk when flashing phone. Also, there is option to make full backup from phone, in SPFT. It's the last hope when everything else fails. btw, flashing mentioned boot and other files, can make phone enter recovery, when you have that you can use official update.zip files. b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
06-24-2015, 21:02 | #12 (permalink) | |
Member: 162707 Status: Offline Thanks Meter: 66 | Quote:
my volume down on the phone not working so I can't use official recovery flash to fix the phone. My best hope is thru sptool. PLease can you help me? Why is it stuck at the zte screen now. | |
06-24-2015, 22:39 | #13 (permalink) | |
1st : Did you select (ticked and manually select files which are NOT ticked) from spflashtool, after loading scatter file ? (by default, some files are not selected / loaded by default) See THIS link to know what I talk about, on that link is how manually select just recovery, but it applies to your case, if some files are not ticked. 2nd: Recovery mode is entered by Volume UP + Power on on 90% phones, so try that, if 1st doesn't help. b.r. Alex
06-25-2015, 15:53 | #14 (permalink) |
Member: 162707 Status: Offline Thanks Meter: 66 | Yea two files are not selected by default. (cache and userdata). I flash over and over again. It flash successfully but it always boot and stops at the zte sign. Yea I know it's up and power to go to recovery. But this recovery is funny. I need to press down to go to the section to flash or reset the phone and the down key not working. When you press up that is to select your choice so the cursor is at "reboot phone". | Please can you source another flash file for sptool? |
06-26-2015, 21:04 | #15 (permalink) | |
Cant say for sure if it's software problem or not. It may be hardware problem easily. b.r. Alex
