ZTE General ZTE phones discussion, firmwares, solution, help |
02-14-2017, 06:17 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,787 | Dead boot recovery : Download THIS - run First.bat , if everything went as it should in the folder should modem.img file appears - Run Second.bat , after done remove usb cable and pull out the battery , and then insert the battery and turn on normally. if modem.img do not work or have already produced format of all sections in the folder nvflash modem_null.img find the file and change its name to modem.img, and then run second.bat b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
05-11-2017, 19:43 | #4 (permalink) | |
Freak Poster Join Date: Feb 2011 Location: cuba Age: 53
Member: 1524998 Status: Offline Thanks Meter: 76 | ayuda Quote:
