ZTE General ZTE phones discussion, firmwares, solution, help |
07-04-2009, 16:49 | #76 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1067541 Status: Offline Thanks Meter: 1 | I have a China iphone clone model: Jiaxin V51, very similar to P168. It has only 2 buttons(1st at top to on & off; 2nd centrally below the touch screen). Dual Sim card, with 8GB microSDHC. I was trying to enable com port and accidentally clicke on "High Speed SIM". Now the phone is dead. The phone details i got from factory mode when it was working normal: [Version] E800_XYZ1F11NTV.00.1 [BRANCH]: GEMINI BUILD: BUILD_NO SERIAL#:E80001070106793 [BUILD TIME] 2008/12/03 09:27 IMEI: ***0510******** ***0510******** BB Chip: MT6225, E05 DSP Code: 2006.06.14 DSP Patch:1.0 MS Board: EVEN6225_GEMINI_HW Working shortcuts for my phone: Change languge: *#0044# + dial for English Check Version: *#66*# IMEI number:*#06# Factory settings:*#3646633# auto test:*#87# Password for restore factory settings: 1122 I want to resovle it using my PC and flashing cable. In this context I have these questions: 1. Can any USB A to 9 pin serial cable available at PC Peripherals work as flashing cable? 2. There are many types of flashing cables at ipmart.com. Please suggest me which cable is compatible for my phone? China23 or China8 or anyother? 3. Can you provide me this flash file version? I will be very glad if you can help me with my problem. [email protected] |
08-09-2009, 13:50 | #80 (permalink) |
Freak Poster Join Date: Oct 2008 Location: mumbai
Member: 875607 Status: Offline Sonork: [email protected] Thanks Meter: 10 | can u give me sum idea that i can flash china without the help of infinity and spiderman box i kno to how to make com cable to flash the moble i ll be very thankfull to every body i m online if any body of the member can sent me the solution |
08-09-2009, 13:50 | #81 (permalink) |
Member: 875607 Status: Offline Sonork: [email protected] Thanks Meter: 10 | |
08-09-2009, 17:29 | #82 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1093047 Status: Offline Thanks Meter: 1 | Hi, forgive me. I have a KA08 phone and want to try to flash it. Thank you for this cable. But I don't know how to choose the firmware file for this phone. Can someone guide me how to decide which file I must download and where I can get it ? Thank you all. |
08-30-2009, 14:06 | #85 (permalink) |
Member: 1108074 Status: Offline Sonork: [email protected] Thanks Meter: 0 | رد Thank you free mach |
09-01-2009, 18:04 | #86 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1020890 Status: Offline Thanks Meter: 3 | HOW TO MAKE THE FLASHING CABLE FOR CECT i68+ HOW TO MAKE THE FLASHING CABLE FOR CECT i68+ After reading of the different the materials I decided to make my own cable for CECT i68+. I bought a Data cable for Siemens C55. (I believe it calls Data Cable USB DCA-510) Cut it about in half. Then I opened the USB connector (Connector is made of plastic, you need to gently press on the side that is cracked on the seam) : As we can see all contacts are labled: Blue - Tx Green - Rx The red is connected to the white - GND ( "ground") Close the USB plastic body, fix it with insulating tape. Prepare the wires to be soldered. 2. Now, let's take the cable with connector for i68+. Open the connector, look at the contacts position. Should be - 2, 7, 8, 12. If you have - 2, 3, 4, 12 (as I had) carefully swap the (just move parallel) pins 3 and 4 into the slots 7 and 8. I got this color coding: 2 - GND - black 7 - Tx - green 8 - Rx - White 12 - Vcc - Red. 3. Now we need just to solder the wires: C55.................................. i68 Blue --------------------> 8 - Rx - White Green ------------------> 7 - Tx - green red + white -------------> 2 - GND - black ........................................ 12 - Vcc - Red. (not used) That's how it looks: Here is how the cable itself looks like: When using this cable and the program FlashTool_v4.10 it worked from the very first time. I reflash my i68+ - it works again! Enjoy! |
The Following User Says Thank You to fraser34 For This Useful Post: |
09-15-2009, 22:02 | #89 (permalink) | |
Member: 1099606 Status: Offline Thanks Meter: 1 | So, it is working even the red (power) cable is not connected??? How the phone gets the power then??? Quote:
The Following User Says Thank You to t53864 For This Useful Post: |
Any Body Help me how i make China Mobile Flashing Cable work with UFX3 | tanveeranjum | Chinese Models & Cloned Phones | 0 | 01-27-2010 11:17 |
>> How To Make China Phone travelCharger&handfree See here << | sunon | Chinese Models & Cloned Phones | 1 | 11-06-2009 16:17 |
How to make Chinese Phone cable (anycool T808) | MiXhaRdwArE | Chinese Models & Cloned Phones | 2 | 07-04-2009 12:34 |
how to make china phone cable | ruvanw1979 | Chinese Cocktail | 2 | 11-18-2007 09:29 |
how to make a ic2 bus cable and how to use? | alro | Hardware Repair by brands | 4 | 06-20-2001 11:22 |
