Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > ZTE
ZTE General ZTE phones discussion, firmwares, solution, help
Old 02-18-2013, 07:04   #1 (permalink)
aliarjun's Avatar
Member: 745934
Thanks Meter: 37
Reliance tab v9c stuck on Android Logo after flash
this set is comes with restarting problem, I had solve this type of problem many times by restoring farmware through Sales_single_P729BV1.00.01..
But this time I m not able to clear out, it shows only Android Logo. I try to put in FTM mode again, but no success...
How to put in FTM Mode in this condition? or any other way to flash without FTM Mode?
Please Help.....
Old 02-18-2013, 07:31   #2 (permalink)
Cheater -Don't Deal with him-
Member: 1714311
Sonork: 100.1604096
Thanks Meter: 268
bro remember me???first check ur model v9c or v9a........if v9c then do u have its original file or other version,post here ur version..................
Old 02-18-2013, 09:38   #3 (permalink)
Member: 179026
Sonork: 100.1667796
Thanks Meter: 15
u can try plug usb cable when phone hang on logo.
If computer can find Android adb devices, u can use adb command reboot into bootloader, then use fastboot -w to clean userdata.
maybe works
Old 02-19-2013, 06:06   #4 (permalink)
aliarjun's Avatar
Member: 745934
Thanks Meter: 37
maybe works
I have only one flash file which was working fine berofe, RLNC_V9C1.0.0B03.
@icejack... the tab is not responding to computer... its hang on Green Android Logo..
Old 02-19-2013, 10:33   #5 (permalink)
aliarjun's Avatar
Member: 745934
Thanks Meter: 37
The comm port shows finally, if I press both volume +- buttons...
can U please gude me how to use adb command... I haven't try yet.
Old 02-19-2013, 12:20   #6 (permalink)
aliarjun's Avatar
Member: 745934
Thanks Meter: 37
C:\>fastboot -w
< waiting for device >
I think there is no connection between phone and comp....
Any Idea?
Old 02-19-2013, 15:13   #7 (permalink)
Member: 179026
Sonork: 100.1667796
Thanks Meter: 15
I have one device hang on android too.
when I plug usb to device it always hang on android logo, then computer can find Android adb interface and ZTE handset USB modem.
so I can use "adb reboot bootloader" into bootloader.
then use "fastboot -w" wipe usedata .
point is computer must find adb interface device.
Old 02-19-2013, 15:18   #8 (permalink)
Member: 179026
Sonork: 100.1667796
Thanks Meter: 15
u don't need press any key to boot tab, just power on the tab
Old 02-23-2013, 05:30   #9 (permalink)
aliarjun's Avatar
Member: 745934
Thanks Meter: 37
I can't get any response, on Power-on Mode....
Old 03-02-2013, 18:40   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,891
try if it goes into FTM MODE, vol- + pwr on for 5-10 seconds,
if yes, simply start ZTE factory updater, and wait until it do its job,
it will power on afterwards.
if it doesn't go into ftm, there is a solution also, but requires a bit more skill.
b.r.
Alex
Old 03-10-2013, 17:44   #11 (permalink)
Member: 1714311
Sonork: 100.1604096
Thanks Meter: 268
final solution..............select n600 in infinity cdma and click spunlock done...........now u out from ftm
Old 10-31-2013, 11:34   #12 (permalink)
Member: 2056647
Where i get this software
my Reliance Tab v9c unable to start..........and when i press Vol(-) and power button..........................Tab just start vibrating.................Pls suggest
Old 01-29-2014, 10:57   #13 (permalink)
Member: 2116860
Hi .....I have got the same problem my Reliance Tab doesnt go past the reliance logo....Can anyone guide me what to do step by step...Thanks
Old 06-04-2014, 07:44   #14 (permalink)
Member: 1755052
Failed to Put My Releiance 3G Tab V9c To FTM Mode( Pressing Vol- And Power)
Please Help Me Out, I Will Be Very Thankful
Old 06-04-2014, 08:17   #15 (permalink)
sunil1670's Avatar
Member: 1849215
Thanks Meter: 132
check volume keys are wrking well ??
Page generated in 0.36576 seconds with 7 queries
