Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > ZTE
ZTE General ZTE phones discussion, firmwares, solution, help
Old 02-06-2017, 08:47   #1 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
root for VDF600
Hello
I try root for vdf600 (vodafone / zte) Android 6.0.1, already tried Kingo root, iroot, srsroot but do not work.
I found supersu but I could not find any recovery (TWRP) to flash.
anyone have any idea where to download?
thanks
Old 02-06-2017, 08:51   #2 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
Try kingroot latest apk. It will not succeed for first time but do it again. Make sure you visit ztedevice site for firmware just in case. All is on your risk anyway.
Make sure you enable OEM unlock and keep it unlocked all the time.
The Following User Says Thank You to maremestera For This Useful Post:
Old 02-06-2017, 09:11   #3 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
thanks bro
refresh...my problem is FRP locked ..
already cecked with boxs but it requires root.
Old 02-08-2017, 16:30   #4 (permalink)
Member: 2682503
Thanks Meter: 2
solution found
hi. i've the same problem...frp blocked and after a lot of tests i've find the way to unlock the phone. if u are interested i'll write the guide. but for root i'm still looking forward...
Old 02-09-2017, 10:06   #5 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
Hi
yes thanks , waiting for your guide .
Old 02-09-2017, 16:19   #6 (permalink)
Member: 2682503
Thanks Meter: 2
ok thanks. i'm italian and i've to write the guide (it's a little bit long) and after that translate all in english and be sure that is all right. i'll do this in the weekend when i've spare time because i want make also a video for youtube. be patient please. thanks to all.
FOR ROOT i've make it with THE LAST UPDATE of kingroot app from playstore.
AND ROM UK1B
The Following User Says Thank You to dd87 For This Useful Post:
Old 02-09-2017, 17:09   #7 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
im italian too me ..
my problem is found and make root from recovery so ,i need correct twrp and supersu .
this phone is FRP blocked i don't can go on play store
for firmware already have this version , uk1b.
thanks anyway
Old 02-10-2017, 18:03   #8 (permalink)
Member: 2682503
Thanks Meter: 2
i've also the recovery twrp good for vdf600. if u want i'll send it to you.
i've tried to send u a private message but maybe i don't have a permission to send private message in this forum.
Old 02-13-2017, 22:30   #9 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 874
hi bro
pm received and answered ..mistery
anyway send here your step for root and recovery install it would be useful for all users.
thanks
Old 03-01-2017, 15:57   #10 (permalink)
Member: 2682503
Thanks Meter: 2
sorry for my long delay...but i was out of italy for work. here is the guide:
How to Bypass FRP Lock (Google Account Verification) during device setup
Power On your FRP locked phone and connect it to a WiFi network from one of the setup
screens.
└ Tip: If you can get another Android phone in hand, then creating a WiFi hotspot from it
would be more convenient for you because the trick involves killing off the WiFi network at a
specific time.
Once connected to a WiFi network, hit NEXT, and as soon as it says Checking for updates,
kill off the WiFi network (turn off your WiFi modem or WiFi hotspot). You’ll get to the screen
where you’ve to put in your First and Last name.
└ I may take a couple of tries to get to the “Name” screen. Keep trying..
One the Name screen, hit NEXT. You’ll get to the “Protect your phone” screen, here set up
a PIN, pattern or password.
Now once you’re on the Google services screen, scroll to the bottom of the screen, then
switch ON your WiFi network (or WiFi hotspot), and then select/tap on the “Google Terms of
Service and Privacy Policy” link.
On policies page that opened in a pop-up window, highlight any text/word by holding it, and
then select the Share option from the tooltip.
From the list of sharing options available, press and hold on the Gmail app icon, you’ll get
the Gmail app info page.
On Gmail app info page, select Notifications » App settings » then tap the 3 dots options
menu and select Manage accounts from there.
└ This step might be different for users not running Android 6.0 Marshmallow and above
Android releases.
On the device settings page, select Google » Search & Now » Now cards » toggle Show
cards switch » hit NO THANKS and you’ll get to the Google Search screen.
On the Google search screen, type Chrome and open the Chrome browser app from the
suggested list.
On the Setup Chrome screen, hit NO THANKS, then OK, GOT IT, and the type the
following URL in the browser bar: *******/frplock
From the URL above, you’ll download the Quick Shortcuts app.
Once downloading begins, go back to Now cards screen by hitting the Back button on your
device.
Here again toggle Show cards switch » hit NO THANKS and get to the Google Search
screen » now type Downloads and open the Downloads app.
On the downloads app, your download Quick Shortcuts app .apk file should be available.
Click on the apk » you’ll get Install blocked screen, hit SETTINGS » scroll down a bit and
turn on “Unknown Sources” toggle » hit the back button » open the Quick Shortcuts apk again
from the downloads screen » install the app » and Open it once installation is done.
Once Quick Shortcuts app is opened, search for “Google Account Manager” and tap on it,
you’ll get a dropdown list of activities » select “Type Email and Password” activity (sometimes
is double,so you have do the samething in eachother) » hit Try and you’ll get to the re-type
password screen » here, hit the 3-dot option menu and select “Browser sign-in”, you’ll get a
browser Google sign-in screen.
Login with your preferred Google Account, and once signed-in, you’ll get back to the Quick
Shortcuts app.
Now go all the way back to the device Settings page by hitting the Back button.
On the Settings page, sincronize your google account and in the and reboot your phone.
Now select “Backup & Reset” » select “Factory Data Reset” » select “RESET PHONE” »
Confirm your PIN, Password or Pattern lock » select “ERASE EVERYTHING”. Your device
will now factory reset itself.
Now once your device boots back, set it up and login using the same Google account that
you used in Step 16 above.
That’s all. Hope this guide helps you bypass FRP lock and Google Account Verification on
your Android device.
Page generated in 0.21554 seconds with 9 queries
