Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > ZTE
ZTE General ZTE phones discussion, firmwares, solution, help
Old 07-20-2011, 07:41   #1 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Thumbs up ZTE Blade Hard Reset.
Tools needed :
Program called fastboot
Extract the files.
Open command prompt -> Go to Start-Run - type : CMD
Use the -w option
Turn on phone holding the volume up button & connect it to PC.
Pics will help you to do the rest .
Hope this help
The Following 3 Users Say Thank You to Rahul_Bhutani For This Useful Post:
Old 07-20-2011, 17:05   #2 (permalink)
wXv
Member: 1483442
this is not work,pleas any solution about zte blade ??
Old 07-23-2011, 11:16   #3 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
Don't work on zte racer and zte link and zte blade. I install zte diagnostic interface DFU driver. Cmd prompt stay on "waiting for device". (on xp)
ANy help pls?
Old 07-23-2011, 11:19   #4 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
ANy help pls?
ok thanks for info now i try to make new hard reset method thread just wait
Old 07-23-2011, 11:27   #5 (permalink)
2net2's Avatar
Member: 418718
Sonork: 100.1589777
Thanks Meter: 360
try this if working
ZTE Blade hard reset
In Idle mode, open the application list and select
Settings → Privacy → Factory data reset → Reset phone
→ Erase everything.
ZTE Blade FTM Mode
ZTE Blade (ZTE San Francisco) hard reset: FTM mode (aka Field Test Mode) With the phone turned off, press VOLUME DOWN + POWER key
zte blade ftm mode
Old 07-23-2011, 11:28   #6 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Originally Posted by 2net2 View Post
try this if working
zte blade ftm mode
you try ?
that's not working.
Old 07-23-2011, 16:26   #7 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
read this topic carefully
ClockworkMod
easy ClockworkMod
Old 07-23-2011, 22:25   #8 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 261
Originally Posted by Rahul-sharma View Post
you try ?
that's not working.
I try, stuck on ftm logo and nothing...
I test and search thanks for help...
Old 09-06-2011, 11:38   #9 (permalink)
Member: 149305
Sonork: 100.1612778
Thanks Meter: 804
this works perfectly I did one set with this method successfully. Pls read carfully and do as described
Old 01-20-2012, 16:01   #10 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,911
ZTE Blade Hard reset
try this:HOME + VOLUME UP + POWER ON ZTE for Hard reset recovery menu.
Old 01-21-2012, 08:24   #11 (permalink)
Member: 194907
Thanks Meter: 114
ZTE San Francisco) my phone this home+volume up+power on not working please help me
Old 03-13-2012, 11:28   #12 (permalink)
Member: 94758
Thanks Meter: 3
these cheap android phones are **** they have little recovery options. Very annoying!!
Old 03-13-2012, 11:29   #13 (permalink)
Member: 94758
Thanks Meter: 3
any one have link for fastboot program?
Old 03-23-2012, 11:09   #14 (permalink)
ghano's Avatar
Member: 1020097
Sonork: 100.1612690
Thanks Meter: 83
Thanks work fine for me ZTE Orange san francisco .... OUK_F927Bv1.0.0B05
stuck in google attempts
Old 03-30-2012, 16:59   #15 (permalink)
Member: 1502160
Thanks Meter: 8
please can you explain
1, extraxt files
then inside same folder how do you do cmd prompt or do you have to start run cmd
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
3110 Need to Unlock & Reset ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-22-2001 08:35
how can you reset the life timer without using a data cable for a 5125 TDMA phone? PiNoY_bOy204 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-23-2001 12:46
HOW TO RESET SECURITY CODE IN NOKIA 6210 ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-26-2001 05:33
5190 patial flashes - why are they so hard to find? Bads Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 04-14-2001 03:18
Page generated in 1.06427 seconds with 9 queries
