ZTE General ZTE phones discussion, firmwares, solution, help |
01-10-2016, 21:34 | #1 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2512844 Status: Offline Thanks Meter: 0 | Zte blade s6 help needed I recently tried to upgrade the firmware on my ZTE Blade S6. I used the option to upgrade on the phone from SD CARD. However, I used the wrong upgrade file - used the UK version instead of China version and now the phone is unusable. Stuck in power off mode - just blank screen. The blue light on the home button comes on when plugged into the charger. Cannot access download mode by holding power and volume up button. Is there anyway to fix this? Can anyone help? Please post here or send me a message ZTE Customer Services are a waste of time. |
01-10-2016, 21:48 | #3 (permalink) |
Member: 2512844 Status: Offline Thanks Meter: 0 | I don't know what you mean by recovery mode? If you mean the MENU you get into when you hold power button and volume up button then no, that is not working. Can't get phone into that mode. |
01-16-2016, 23:03 | #5 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Phone is Qualcomm MSM8939 Snapdragon 615 cpu, and without factory loaders, hardly that you can recover it. So, visit some zte service centre / customer care, and tell them that phone just powered off itself. p.s. I found on other forum, some info about forced update, if your phone will accept it ... take a try, nothing to loose. Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 01-16-2016 at 23:09. Reason: added info / links | |
