Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > ZTE
ZTE General ZTE phones discussion, firmwares, solution, help
Old 12-18-2014, 07:02   #1 (permalink)
Member: 421487
Thanks Meter: 58
zte g2 v880h hang on start up logo need solution
its zte v880h hang on start up logo if any one know abot solution pl give me
Old 02-23-2015, 13:27   #2 (permalink)
Registered User
Member: 149938
Thanks Meter: 47
zte v880h flash file
I need zte v880H/ zte blade g2 flash file and flasher .
br.
Old 02-23-2015, 15:59   #3 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
FIRST ROOT YOUR MOBILE. THEN FOLLOW THESE STEPS...
Rename the cwm recovery.img to recovery.img then put in external sd card.then open mobile uncle app and select update recovery...it will show recovery.img then click On it and wait for second. then it will show reboot in recovery. follow these steps. another link for cwm recovery:
https://yadi.sk/d/y0zBrS-s78e_A
I'm already done with all the above mentioned steps before posting my reply.
1. I used Eroot to root my V880H & rebooted the phone.
2. Copied & renamed your CWM recovery image file to recovery.img in my phone.
3. Installed & ran MobileUncle & gave Superuser access/permissions to it.
4. Selected recovery.img to flash it. Phone rebooted automatically & displayed stock recovery mode.
Old 02-24-2015, 07:02   #4 (permalink)
Registered User
Member: 149938
Thanks Meter: 47
Hangs on logo zte . please guide.
br.
Old 03-14-2015, 07:54   #5 (permalink)
Member: 1505057
Thanks Meter: 38
ZTE V880H/BLADE G2 Flashfile needed
handset problem is hang on zte logo.need flashfile.
Old 03-17-2015, 16:30   #6 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
OS: Android 4.2.1
Chip set: Media tech MT6589 1.2 Ghz
RAM: 512 MB
ROM: 4GB
Camera: 5MP AF with Flash
Display: IPS 4.5“ FWVGA(480*854), 16M color
Battery: 2000mAh
Stock rom (old) Build: DIS-IN-TB18D-P188F03V1.0.0
http://download.ztedevices.com/UpLoa...0611012188.zip
ZTE V880H Custom ROM
https://yadi.sk/d/-4O2sbxf85Juc
1.Download the zip file from the link
2.Extract
3.Copy update.zip to SD card
4.Reboot mobile to recovery mode
5.install update From SD
6.Select Update.zip
7.Success
Old 09-08-2015, 13:01   #7 (permalink)
Member: 2456069
Kindly post the process details step by step after extracting the file (ZTE V880H Custom ROM).
Old 11-07-2015, 11:55   #8 (permalink)
Member: 1478562
Thanks Meter: 54
Originally Posted by gcceleghg View Post
os: Android 4.2.1
chip set: Media tech mt6589 1.2 ghz
ram: 512 mb
rom: 4gb
camera: 5mp af with flash
display: Ips 4.5“ fwvga(480*854), 16m color
battery: 2000mah
stock rom (old) build: Dis-in-tb18d-p188f03v1.0.0
http://download.ztedevices.com/uploa...0611012188.zip
zte v880h custom rom
https://yadi.sk/d/-4o2sbxf85juc
1.download the zip file from the link
2.extract
3.copy update.zip to sd card
4.reboot mobile to recovery mode
5.install update from sd
6.select update.zip
7.success
are you success with this method?
Old 01-28-2016, 20:08   #9 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,269
[FlashTool] Flash Files:
ZTE Blade G2 V880H | ZTE Blade
Stock ROM (old):
Note: If you are coming from newer version (DIS-IND-TB18D-P188F03V1.0.0), then you will have to do firmware update instead of download. So its Recommended that to backup your IMEI/NVRAM using MTK Droid & Root Tools.
Stock ROM (new):
Note: If you are coming from older version (DIS-IN-TB18D-P188F03V1.0.0), then you will have to do firmware update instead of download. So its Recommended that to backup your IMEI/NVRAM using MTK Droid & Root Tools.
Flash Tools:
SP Flash Tool v 3.1312.01 for MT6589T
Note: Recommended for MT6589 devices.
Backup & Restore Tools:
MTK Droid Root & Tools v2.5.3
Drivers:
ZTE Blade G2 V880H Stock Driver Installer
Note: Recommended for ZTE Blade G2 V880H.
MediaTek All USB Drivers v0.9.2
Note: Recommended for MTK devices.
Old 10-08-2016, 20:00   #10 (permalink)
Member: 2540958
Thanks Meter: 71
can any one help me with latest file for these model?
Old 08-10-2019, 07:10   #11 (permalink)
umadineshdas's Avatar
Member: 306096
Sonork: 100.1585877
Thanks Meter: 255
Stock ROM (old):
Stock ROM (new):
Flash Tools:
Drivers:
need this tool
Flash Tools:
Page generated in 0.23734 seconds with 8 queries
