Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > ZTE
ZTE General ZTE phones discussion, firmwares, solution, help
Old 03-13-2017, 22:35   #1 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 10,202
[Guide] ZTE Avid Plus Z828 FRP Removed Solution
Here Video Guide
1. Go through the setup until you get to the google verifying part.
2. Open up your keyboard and hold down the comma to access the gear which will allow you to get into the google keyboard settings.
3. Once you're at the google keyboard settings go to Text Correction.
4. Then go to Personal Dictionary and select English (US) or whatever you have there.
5. Then click on the search button and just type random letters and hit search is what i did to get to this next step.
6. You should be able to type in the letter "g" and you should see something called Google voice typing
7. Click that and go to Text-to-speech.
8. Then click the blue gear next to google text to speech
9. Click install voice data
10. You should see 3 dots on the top right hand corner open that and click open source licenses
11. once you're at this part just simply hold a line down as if you were going to copy it.
12. You should see about 4 options on what you want to do with that line like copy or share it search it on the web.
13. What you want to do is click search, its the fourth option.
14. Delete whatever is on the search and type in settings the option to access the settings should pop up on the bottom as a suggestion.
15. Click that and now you're at the settings.
From here on i assume you know how to access the about phone and turn on developer settings but this is the problem you can turn it on but you cant access the developer menu you can just click it and nothing will happen.
Same for trying to reset the phone from the back up and reset menu.
If anybody knows what the case may be please let me know i'm constantly trying to find the solution to this whenever i have the free time but so far no solution has came up.
I'M able to download apks by instead of typing in settings on the google search i type in file manager and simply transfer over the apk through my pc onto the phone.
That i can do without usb debugging because my pc picks the phone up as a portable device.
Credit Goes ==> XDA
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
The Following 11 Users Say Thank You to ...:::::NP™:::::... For This Useful Post:
Old 03-14-2017, 01:24   #2 (permalink)
Member: 2684440
Thanks Meter: 140
Try this First download quick shortcut maker.apk copy to the phone , open the keyboard, go to settings look for text to speech options,Google text to speech engine, click on the settings img, install voice data,open source license press and select one text...click on the lens look for file manager open and install the quickshortcut.apk open and find Google account manager,open the service and look where says error,open the service click on the 3 points menu and go to browser signing use your account and restart...is done
The Following 4 Users Say Thank You to GSM_FIX For This Useful Post:
Old 02-09-2018, 11:02   #3 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 653
ZTE phones FRP bypass
ZTE Maven 2 FRP bypass | ZTE Z831 Google account bypass | AT&T FRP bypass
http://www.youtube.com/watch?v=jssy1VOAfEg
The Following 4 Users Say Thank You to Mobile-Lab For This Useful Post:
Old 02-09-2018, 11:04   #4 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 653
ZTE ZMAX PRO FRP bypass | ZTE Z981 Google account bypass | ZTE MetroPCS and T-Mobile FRP bypass
http://www.youtube.com/watch?v=eOKGSEYDkh4
The Following 2 Users Say Thank You to Mobile-Lab For This Useful Post:
Old 02-09-2018, 11:05   #5 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 653
ZTE Grand X3 FRP bypass | ZTE Z959 Google account bypass | ZTE Cricket FRP bypass
http://www.youtube.com/watch?v=JBFZ89iFhjU
Old 02-12-2018, 11:03   #6 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 653
ZTE Avid Plus FRP bypass | ZTE Z828 Google account bypass | ZTE MetroPCS/TMobile FRP
http://www.youtube.com/watch?v=m780-pSqOoA
The Following 3 Users Say Thank You to Mobile-Lab For This Useful Post:
Old 03-07-2018, 13:30   #7 (permalink)
Member: 2421974
Hai friends
Zte maven 3 7.0 (Z 835) at&t frp solution pls help
Old 04-04-2018, 23:56   #8 (permalink)
Member: 2591842
Sonork: 1674297
Thanks Meter: 39
i need help bypass frp zte z852
thanks in advance
Old 04-08-2018, 16:05   #9 (permalink)
Member: 351660
Thanks Meter: 5
i need heip a320 frp
Old 05-09-2018, 01:51   #10 (permalink)
Member: 2835747
How to frp lock on cricket overture 3
I needs help. Trying to remove frp locked phone
Old 05-20-2018, 20:00   #11 (permalink)
Member: 2704703
Help need remove frp zte z855 maven 4 metropcs
I have one Zte Z855 Maven 4 Metropcs i try remove frp or google account but no possible is Qualcomm Chip MSM 8909 i try remove with xxxxxxx but fail
The Method Try is:
1.- Put in FTM mode Open xxxxx
2.- FTM to edl mode with in menu zte
3.- go to menu Qualcomm and select internal Loader msm8909 or msm8909 2 gen.
Old 06-14-2018, 21:35   #12 (permalink)
Member: 2844284
Question Frp bypass zte blade X
Hi can anyone help me bypass frp zte blade x from cricket
Old 08-16-2018, 22:25   #13 (permalink)
Mobile-Lab's Avatar
Member: 10028
Sonork: n/a
Thanks Meter: 653
ZTE Maven FRP/Google account bypass | ZTE Z812 AT&T USA FRP/Google ID bypass
http://www.youtube.com/watch?v=DRV09Xh9Ozw
Old 09-09-2018, 07:04   #14 (permalink)
Member: 2364256
Sonork: 100.1676491
Thanks Meter: 15
HI guys i need solutions for the ZTE .....Z799VL frp.
Old 10-04-2018, 14:16   #15 (permalink)
Member: 2779485
Zte n9560 frp ????????????
Page generated in 0.40361 seconds with 7 queries
