ZTE General ZTE phones discussion, firmwares, solution, help |
09-19-2017, 22:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: SCN Movil Centro
Member: 321176 Status: Offline Sonork: 100.1640958 Thanks Meter: 62 | ZTE ZMAX PRO Z981 Won't Turn On Regards bedel. |
09-22-2017, 16:01 | #2 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Try replacing the battery. A defective battery won't let it charge, therefore not power on either. | |
09-28-2017, 03:02 | #4 (permalink) | |
I've seen batteries with 4.12 volts across (+) and (-), but the the middle BSI pin had 0 volts. You may want to check that out, and it wouldn't hurt trying a new battery anyway. Sometimes the problems come from the least expected sources. | |
The Following User Says Thank You to BillA For This Useful Post: |
09-28-2017, 20:02 | #5 (permalink) |
Insane Poster Join Date: Aug 2013
Member: 1991594 Status: Offline Thanks Meter: 14 | Don't know if it'll work but I came across a few of them doing the same thing. Plug it in and hold power volume down for 2 mins. Switch up buttons if one combination doesn't work. Had seen some just turned off and when turning back on would have a lot of battery life left. Just a defect or something. Good luck |
