Huawei General Huawei phones and tablets help |
05-20-2013, 05:12 | #1 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,910 | [Guide] All Huawei Mobile phones Hard Reset Procedures Huawei Um840 Hard Reset Volume UP+Send+Power For Enter To Recovery Mode Select Wipe Data/Factory Reset Delete Alll User Data Waiting And Select Reboot Phone Last edited by moulnisky; 06-05-2013 at 14:22. |
The Following 6 Users Say Thank You to Braycel For This Useful Post: |
05-20-2013, 05:18 | #2 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U9508 Honor2 Hard Reset Volume up+Power 5 Seconds Select Wipe Data/Factory Reset Deleted All User Data Waiting And Select Reboot |
The Following User Says Thank You to Braycel For This Useful Post: |
05-20-2013, 05:29 | #3 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U8220 Hard Reset Menu+End+Volume Up+Power 2 Seconds For Enter To Recovery Menu Select Wipe Data/Factory Reset Deleted All User Data Waiting And Select Reboot |
05-24-2013, 02:37 | #4 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei Ascend G300 Hard Reset Step 1 Hold down the Volume Up and Power buttons simultaneously. When you see the Huawei logo appear, release the power button but continue to hold the Volume Up button until your see the Android logo, then release. This will access the blue unlock/reset menu. Step 2 Once you've reached the unlock/reset menu, scroll down, using the volume buttons, and select ‘wipe data/factory reset’ by pushing the power button. Step 3 When prompted, scroll down and select ‘Yes -- delete all user data’. This may take a few moments Step 4 When prompted select ‘reboot system now’. |
The Following 2 Users Say Thank You to Braycel For This Useful Post: |
05-24-2013, 02:52 | #5 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Hard Reset Huawei Ideos S7 Slim Turn off the Huawei Ideos S7 Slim Hold together button : Power + Volume Down for several second until the Ideos logo appear in the LCD. After that than suddenly release both button. The Ideos S7 Slim will running it self and without any asking or without notice the tablet will be reset to factory default. |
05-24-2013, 02:58 | #6 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | How to Hard Reset Huawei U8300 2.Press Volume UP Call Button then press Power To Reset from Menu 1.Press menu Key 2.Select Privacy 3.Select Factory Date Reset 4.Select Reset Phone 5.Select Erase eVERYTHING |
05-24-2013, 03:06 | #7 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Hard Reset Huawei u8500 Ideos X2 press the "volume button" , the "call button" and the "power button" at the same time, then wait until you get in the screen where you can select the "reset factory" when you select the factory reset wait for the message "complete" then after that choose the "reboot". |
05-24-2013, 03:12 | #8 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei ideos X3/Blaze U8510 hard reset Turn off phone.Hold down volume up and power button Boot menu will appear.Use volume down to navigate and power button as okay. select wipe data/factory reset. |
05-24-2013, 05:14 | #9 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei Ascend Y201 Pro Hard Reset Here Is Procedure.... Hold Volume Up & Home Button Lower Center Touch Pad & After That Press Power Button.... When Ur Handset Vibrate Release Power Button But Keep Holding Volume Up & Home Button... After 3 To 5 Second Handset Show Recovery Mode.... After That Press Volume Down Button To Wipe Data/Factory Reset... After That Press Power Button To Make Reset... After That Wipe Cache Partition... After That Ur Handset Are In Factory State... |
05-28-2013, 02:49 | #10 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei Ascend D1 1) From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything If the phone is totally unresponsive, even after a reboot, then try the following methods. 2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select. 3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes. 4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone. |
05-28-2013, 03:55 | #11 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U8800 Hard reset Hold Volume up, call button, and power button until phone vibrates , Choose wipe data/factory reset when prompted. Or 1. From the Home screen, press the Menu Key and touch Settings. 2 Touch the Privacy 4 Touch Factory data reset. 5 Touch Reset phone. 6 Touch Erase everythin |
05-29-2013, 05:03 | #12 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Hard Reset Huawei U8860 Start with your Huawei U8860 in powered off state. If you cannot power it off, because it has just freezed up on you, then please take off it’s battery wait a couple of seconds and reinsert it. Press and Hold “Volume UP” and the power buttons Wait unto a boot recovery screen appears Depress the “Volume UP” and power key. Choose the Hard reset / Factory default procedure using the Volume up and down buttons |
05-30-2013, 03:12 | #13 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U8100 Hard Reset Press answer button + volume up button and start the phone. The phone will boot into recovery. Choose factory restore. |
05-30-2013, 15:02 | #14 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U9200 Ascend P1 Hard Reset First Power Off Your Phone Press And Hold Both The Volume Up And Volume Down Keys And The Press The Power Key clockworkmod recovery Volume UP + Send + Power on Huawei Ascend From The Recovery Menu Select Wipe Data/Factory Reset All Data Will Be Lost |
05-30-2013, 22:21 | #15 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U8850 Vision hard reset Press and hold the Power key and Volume up key for 10 seconds. or Press and hold the Power key and Volume down key for 10 seconds. |
