Huawei General Huawei phones and tablets help |
05-31-2013, 16:25 | #16 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 54
Member: 109136 Status: Offline Thanks Meter: 17 | Huawei Sonic U8650 hard reset using buttons Remove battery and reinsert it. Press and hold VOLUME UP + POWER ON to get into recovery menu. Select Factory reset with Volume down button. Confirm with power button. All data, apps, etc. will be lost! pink screen issue solved recover your U8650 phone Huawei Sonic U8650 hard reset Restoring Factory Data If you reset your phone to the settings that were configured at the factory, all of your personal data stored on the phone, including information about your Google Account, any other accounts, your system and application settings, and any applications you have downloaded will be erased. Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card, such as music clips or photos. 1. On the Settings screen, touch Privacy > Factory data reset. 2. When prompted, touch Reset phone, and then touch Erase everything. The mobile phone resets the settings to the original factory settings, and then restarts. Unlocking Your Huawei U8650 Huawei Sonic phone if you forget the lock pattern If you have already created a Google account, you can unlock your mobile phone by the following methods. • After you have entered the wrong sequence five times, a Forgot pattern? button will appear. Touch this button to enter the Google account interface. After you have entered your Google account password, you will be able to reset the unlock pattern. • After you have entered the wrong pattern twenty times, you will be taken directly to the Google account interface. After you have entered your Google account password, you will be able to reset the unlock pattern. Backing Up your Data You can use your Google account to back up your mobile phone’s settings to Google servers. If you replace your mobile phone, the settings you have backed up will be transferred to the new mobile phone the first time you sign in to your Google account. 1. On the Settings screen, touch Privacy. 2. Select the Back up my data check box. Last edited by moulnisky; 06-05-2013 at 14:49. |
06-03-2013, 21:15 | #17 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U9000 Hard Reset 1.Turn Ideos X6 off. Press and hold volume up and down. 2. Keep pressing both Volume + press the power button. 3. After the Andorid smartphone vibrates, let go of the power button but keep holding the volume up and down buttons. 4. When you see a yellow exclamation mark with android figure touch home button for the recovery menu. 5. Scroll down to wipe data / Factory reset with Volume button. 6. Use Back button to select. 7. Select delete all user data. Wait for data wipe deletion. 8. Select Reboot system now or reboot phone. |
06-04-2013, 13:19 | #20 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | (Hard Reset) Huawei Ascend W1-U00 It is very important if you know some tips on your device like Huawei Ascend W1. It will help you learn more about your device to make your life much easier in using it. Improving your productivity and fulfilling what you expected on your Huawei Ascend W1. Here are some How To's for your Huawei Ascend W1 These How To's may still not yet complete and I am finding some time to work on the others: How to Factory Reset (Hard Reset) Huawei Ascend W1 We have our own reasons why we factory reset our device. Maybe we want to delete all the files and restore the device to its original state. It could also be the device may be malfunctioning or so slow and it needs to be reset. Restoring the default settings or factory reset your Huawei Ascend W1 will delete all your files. It is recommended to backup your important files on your computer before attempting to reset your device. How to Factory Reset: Go to Start > Application list > Settings. Then scroll to the bottom and choose About. Tap on Reset your phone. To confirm the reset tap Yes. It will take a few minutes to restore the default settings, then your phone will restart. --- Hard Reset --- Option 1: Press and hold the Camera + Volume Down + Power buttons at the same time. Then release the Power button when the phone vibrates. After that, release the Camera button and Volume Down when you are prompted on the Format screen option. Then press Windows button twice to confirm. Option 2: Turn your phone off. Then press and hold the power key and release it when it vibrates. Press and hold the Volume Down button until the exclamation mark is displayed. Then input the follow sequence of keys: Volume Up > Volume Down > Power > Volume Down. |
06-06-2013, 17:08 | #22 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,770 | huawei ascend G510 hard reset 100% tested by me volume up and power together then andorid logo appear click middile of the logo andorid menu appear from the list select wipe data/factory reset by press power key select yes --delete all user data select by press power wait 5 second then see ok then click reboot system now by press power switch wait a long time before power on compeleted set up all required settings |
06-13-2013, 00:09 | #24 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei G5500 hard Reset Take out the SIM card. Be sure to charge your phone. On the dial screen enter this Huawei G5500 hard reset reset code: ##258741 then press CALL button. Warning! All your data including contacts will be lost, so back up all your data before doing a Huawei G5500 hard reset / full reset |
06-18-2013, 02:46 | #25 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | Huawei U8180 Hard Reset Just push together power button and volume up Choose "wipe data" with volume buttons Press power to select Wait till the process ends Press power button to reboot |
08-02-2013, 19:13 | #27 (permalink) |
Member: 813309 Status: Offline Thanks Meter: 1,910 | |
09-30-2013, 09:31 | #30 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 972 | Huawei Ascend G525 hard reset Warning! All data will be lost! 1.Turn off your phone 2.Press together volume up + power button until the android logo appears on display 3.Browse with volume buttons and select "wipe data/factory reset" then press power button 4.Select "yes" and press power button 5.Wait until format is complete 6.Select "reboot" and press power button 7.Wait until the phone restarts |
The Following User Says Thank You to dr_moosavi For This Useful Post: |
