[Guide] All Huawei Mobile phones Root Huawei G600 Root Tutorial is also on this site: Unlock Bootloader & Root Please note that this tutorial was designed for Windows.
ROOT for AT&T Impulse 4G (Huawei u8800-51) ROOT for AT&T Impulse 4G (Huawei u8800-51) NOTE: I take no credit for SuperOneClick, or the actual guide. I simply found it, simplified it, and reposed here. Thanks goes to CLShortFuse for SuperOneClick, and all the members at XDA-Developers, specifically in the Huawei Ideos x5 forum. Also, I am not responsible for any bricked devices, loss of data, zombie infections, Rage fits, or thermonuclear warfare caused by this guide. Oh, and also, if you succeed, your warranty is now void. PLEASE follow the instructions to a T. This guide is for Windows PCs. I don't have any guide for Linux or Mac, sorry. This guide will teach you how to root and install ClockWorkMod Recovery your AT&T Impulse 4G, also known as the Huawei Impulse 4G. PRE-ROOT REQUIREMENTS: Put the device in ADB mode (Settings\Applications\Development\check USB Debugging) STEP 1 Plug device into computer and let the drivers install. CHECK to make sure the ADB driver installed (Right click "Computer" and click Manage, and click Device Manager) If 'Ideos' is in 'Other Devices', you will need to start at Step 2. If 'Android Composite ADB Interface' shows up in 'Android Phone', you are good to go to Step 3) STEP 2 (Ideos in Other Devices) When the device was plugged in, 'CD Drive (E:\) Mobile Partner' should have popped up for AutoPlay. If it did not, check 'Computer' to see if it has. If it hasn't, unplug the device and plug it back in. Once it shows up, go back into Device Manager from Step 1 and right click 'Ideos' in 'Other Devices' and select 'Update Driver'. Click on Install Driver Manually instead of Searh Online and browse to E:\drivers. This will install the ADB drivers needed to root. STEP 3 (ADB Drivers Installed, now to root) Now that your device has ADB drivers installed and working, download SuperOneClick v2.1 from http://forum.xda-developers.com/atta...0&d=1312258565 Extract all the files into a folder, and run SuperOneClick with Admin permissions (right click SuperOneClick, select Run as Administrator) After SuperOneClick opens, simply click the 'Root' button on the top. NOTE: It may freeze up a few times, as if it stopped responding. That is normal. As it goes through its process, it will eventually stop and tell you 'busybox is not installed. Install?' Hit yes, and yes to all the other prompts. At the end, it will tell you that your device is now rooted. TA-DAAAAA. Reboot your device and the root is complete. STEP 4 (CWM Time) Download CWM here http://forum.xda-developers.com/atta...8&d=1317928514 Turn the device off, and press and hold Volume Up, Down and Power buttons simultaneously. The AT&T logo will pop up, and then a pink-purple screen will pop up over it. Plug the device into your computer and let the drivers install. A popup may tell you some drivers didn't install, that's ok. A single, unnamed Removable Storage device will come up; open it. Take the 'recovery.img' file in there and rename it to 'recovery-backup.img', then copy the recovery-clockwork-5.0.2.6-u8800.img' to the storage device. Rename it to 'recovery.img'. IMPORTANT: Make sure to 'Safely Remove Device' before unplugging! After unplugging, remove the battery and reinsert it, and hold Volume Up and Power buttons to boot into CWM. There you have it, Root and CWM. I've begun ****** around with ROMs, I will try to port CM7.1 to this device, along with a customized, clean version of the stock ROM. Enjoy! |
!!!Working root method for Huawei Ascent G312 U8681!!! 1 Attachment(s) How to root the phone: Run Poot. When it first runs it will say it has to install a program it gets from the market called Ministro. Just download and install it. Then re-run Poot. It will then say it needs to download binaries, let it download and install them When it finally gets to the main Poot screen, press the button at the top that says: Press here to poot. It may give you an error in the log, it did to me but still worked. Now REBOOT your phone. Once booted, install Superuser or SuperSU, whichever you want. You should now be rooted. Download Root Validator and test. This root method does not install Busybox, so you'll have to install it yourself. Just use Busybox Installer or something. But there you go! Finally a working root method for this phone! The program will probably give you some kind of error. Aparently this is normal, I got error 64, Jack got error 22. But it still worked. Just download Root Validator to test it. |
q a50 hard rest code |
i need to root U8650 and i got the recovery file for adb via fastboot my problem is : i got win7 32 bit when i connect the phone to pc in fastboot mode my adb not see te phone i need the correct drive plz |
i need root huawei hw-01e |
can it use in Huawei tablet x1 |
Huawei don't seem to provide code for bootloader unlock. |
brother tnanx for help us....now please can help me i have huawei g6-u00 i got unlock code.but i cant enter in fastboot mode i try to press vol.- and power together but its restart please can help me that how ti enter in fastboot mode. |
tnx now i unlock my bootloader but still i need recovery to flash..plz any one can share recovery for g6-u00 |
I can't root Huawei G Play Mini CHC-U01..... Model : Huawei G Play Mini CHC-U01 Version : 5.1.1 EMUI Version : 3.1 Build Number : CHC-U01c636B320 Please give me a solution.....Please I need to root,,,it is very important......Please Help me |
will this unlock my phone from the network? |
Unlocking the bootloader will also sim unlock my phone? |
Thanks for this informative thread |
how about Huawei P8? |
