Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei
Huawei General Huawei phones and tablets help
Old 05-24-2013, 05:27   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
[Guide] Unlocking Bootloader officially with the code of Huawei
Seeing that Huawei is already starting to spread the codes, I created two scripts very intuitive to unlock the Bootloader Officially:
The first is called "Unlock-Bootloader.bat" and is used to unlock the bootloader with the code you gave Huawei. The same script asks you to enter the code at some point.
The second is called "Check-Status.bat" and is used to check the status of the bootloader (if it's locked or unlocked) and can be used before and after of the unlock to check that everything went well.
Download:
Official-Unlock-Bootloader-by-Alkalinorap-v4.zip - Solidfiles
I haven't put README or instructions because scripts are integrated fully intuitive and interactive and at all times it will tell you what to do.
NOTE: First of all, you must have installed the drivers for the phone, here you can download: http://www.solidfile...m/d/7318df4f59/
NOTE 2: If you have the bootloader unlocked with an unofficial method, for example with unlockbootloader.exe, or any other unofficial method, WE MUST RETURN TO CLOSE IT BEFORE THE OFFICIAL UNLOCK. To do this, you must install an UPDATE.APP (any of ICS) and then we can officially unlock.
NOTE 3: Is possible that the antivirus will detect it as a virus because scripts are in .bat format. If this happens, you must disable the antivirus temporarily until finish to make the whole process, I guarantee you that there is no virus.
Enjoy it.
The Following 19 Users Say Thank You to Braycel For This Useful Post:
Old 06-14-2013, 18:07   #2 (permalink)
Member: 237670
Sonork: 1604787
Thanks Meter: 13
Download:
Enjoy it.
hi it is work on u8860?Can i unlock my fone via this ?I mean my mobile is locked to operator want to unlock. thnx for answer.
The Following 2 Users Say Thank You to guessgaus For This Useful Post:
Old 06-14-2013, 20:28   #3 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Hello
This Is For Unlock Bootloader If You Need Unlock Your Phone Use Any Tool
The Following User Says Thank You to Braycel For This Useful Post:
Old 01-27-2014, 14:16   #4 (permalink)
Member: 2016506
Sonork: 1647640
Thanks Meter: 4
You can use Huawei All-in-One Bootloader Unlocker to unlock Bootloader & Network Lock of Huawei Android Smart Phones.
Old 02-05-2014, 16:45   #5 (permalink)
Member: 2118278
does this support huawei ascend g610-u20?
Old 09-15-2014, 06:01   #6 (permalink)
Member: 2257835
it work Huawei G6-U00??? Please answer me
Old 04-29-2015, 14:38   #7 (permalink)
Member: 2189180
how to unlock huawei y330-u01 no network.
Old 07-10-2015, 04:10   #8 (permalink)
Member: 2425487
Where i can post new?i cannot find it.i am new plz help me
Old 12-08-2015, 10:21   #9 (permalink)
Member: 1296340
Thanks Meter: 3
How i unlock mate 1 .... thank you
Enviado desde mi SM-G355H mediante Tapatalk
The Following 2 Users Say Thank You to INTERCELULAR For This Useful Post:
Old 01-18-2016, 15:37   #10 (permalink)
Member: 2494523
unlock huawei bootloader
First of all Set up ADB and fastboot drivers in your PC. Find the serial number and IMEI go to Settings>>>About Phone>>>Status. Find the Product ID by entering *#*#1357946#*#* in the call Number dialer. Now Send email to huawei request unlock code with your phone IMEI, Serial number and Product ID at huawei offecial site. In very less time only you will get unlock key then you need enable USB debugging Go to settings>>>Developers Option Enable USB debugging. Now Switch off your phone and then boot in fastboot mode, Press and hold volume up then volume down and power button at the same time and connect your phone with PC. Now open fastboot folder and in the empty space press and hold right click and shift key at the same time, choose Open Command window here. In the command window type fastboot oem unlock (code given by Huawei). Now just go with the on screen instruction. After than type fastboot reboot if your phone will now automatically reboot.
The Following User Says Thank You to vinay1230123 For This Useful Post:
Old 04-06-2016, 16:20   #11 (permalink)
Member: 2556347
Question huawei g525
hello Everyone,
I got a problem here regarding this issue. my phone keeps on turning on and off,a 100x times now and so with that I cant use my phone properly. I'd hard reset it because I can't stay long in my home screen. I did Factory reset first, and reboot, all my files were deleted, Then My phone back to its original setting just like the first time I bought it. but then It turned off again, and when it on, I got the same settings I designed on it and seems like all my files were back on track.. I hard reset again and a purple screen shows up and saying that "emmc is read only, you cant update your system".
So now,as I am searching some solutions over the net, before I visit a Technician(service center), I would like to know if these procedures wont damage my emmc chip? as I have read that once you got it wrong, my emmc chip would definitely be 100%useless and I wont be able to use my phone anymore.
please Help me, Folks!)
Old 05-23-2016, 19:05   #12 (permalink)
Member: 2576723
Pls i need unlock code for my huavei j6 pls .tnx
Old 06-30-2016, 11:13   #13 (permalink)
AHAMEDPONMALA's Avatar
Member: 723178
Thanks Meter: 37
i have huawei honour h60 restart
anyway to update this
fast boot resorce mode phone is locked
Old 08-23-2016, 09:11   #14 (permalink)
Member: 2594381
how to accept bootloader code on my email plz link online bootloader unlock code
Old 08-27-2016, 02:39   #15 (permalink)
Member: 2592198
hi can i unlock huwei y6 SCL-L04 with this?
The Following User Says Thank You to g0DLIKE For This Useful Post:
Page generated in 0.23845 seconds with 8 queries
