Huawei General Huawei phones and tablets help |
07-18-2013, 12:09 | #1 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1223271 Status: Offline Thanks Meter: 0 | Huawei B593 - enter unlock code manually [Solved] i got a Huawei B593 and received a NCK Code. Is there a possibility to enter the code manually? http://192.168.1.1/en/cardlock.asp don't work |
07-18-2013, 17:19 | #2 (permalink) | |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | Quote:
You Can Use Hyperterminal For Enter Code | |
07-19-2013, 14:27 | #3 (permalink) |
Member: 1223271 Status: Offline Thanks Meter: 0 | thanks for the advice! i found a solution for myself it's pretty simple * get a sim card from another carrier * put the sim card into the Huawei B593 * turn on the Huawei B593 * open a browser and go to "192.168.1.1" * login your router with the password * go to "internet settings" in the menu * enter the pin of the sim card to enable the sim card * then go to "sim settings" * there should a field for unlock * enter the nck code or unlock code * router should reboot * router should be unlocked i checked the simlock status with the dc unlocker tool -> status: unlocked |
08-23-2013, 06:58 | #4 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2008678 Status: Offline Thanks Meter: 0 | Help This process is not working on me. My modem/ router is branded with personalized interface. My network setting and other options are pre-fixed already. Somebody can help on this? |
09-26-2013, 23:31 | #7 (permalink) | |
Junior Member Join Date: Sep 2013
Member: 2034722 Status: Offline Thanks Meter: 0 | Quote:
01-17-2014, 05:34 | #8 (permalink) |
Junior Member Join Date: Apr 2012 Location: manila
Member: 1745200 Status: Offline Sonork: 12345 Thanks Meter: 1 | didn't work for 192.168.1.1 but 192.168.254.254 was good and continue to admin panel but cant seen the internet setting to input calculated unlock code... any idea masters? thanks |
03-30-2015, 16:40 | #10 (permalink) |
Junior Member Join Date: Mar 2015 Location: alkhobar.ksa
Member: 2366768 Status: Offline Sonork: 100.1594064 Thanks Meter: 0 | help same problem..................i have dc-unlocker..........but how can unlock its ...........before habe new sestem .........setting then go internet.......then want unlock code ..............but nowe not comimg before...........pls helpme any one Last edited by MASUD gsm; 03-30-2015 at 16:42. Reason: model number B593u-91 |
07-28-2015, 22:07 | #11 (permalink) |
Junior Member Join Date: Jul 2015 Location: Caracas - Venezuela
Member: 2435739 Status: Offline Thanks Meter: 0 | Hi good afternoon forum friends ... I join this prestigious forum under which present problems with a modem huawei b593 - s22 I purchased three months ago and I could not run this because I do not accept any SIM card from my country ( Venezuela ) . It always gives me a message that I contact the operator of the Internet as the simcard is blocked ... but this is not .. Can anyone give me some advice on this team ?? I am from Venezuela where three operators work Movistar: GSM 850 - Frequency 3G UMTS / HSDPA 1900 Mhz Movilnet : GSM 850 - Frequency 3G UMTS / HSDPA 1900 Mhz ( and 2100Mhz , unused Digitel 900 - Frequency 3G UMTS / HSDPA 900 MHz - frequency 4G (LTE ) : 1800Mhz and the team is working in the following bands : • G: EDGE / GPRS / GSM 850/900 /1800 / 1900MHz • 3G: HSUPA / HSDPA / UMTS / DC- HSPA + 900 / 2100MHz • 4G ( FDD ) 2600/2100/1800/900 / 800MHz (TDD ) 2600MHz |
08-05-2015, 03:15 | #12 (permalink) |
Insane Poster Join Date: Mar 2007 Location: rosario pasig
Member: 476626 Status: Offline Thanks Meter: 6 | To Debrand your Huawei b593 click http://forum.gsmhosting.com/vbb/f804...nding-1865253/ |
08-05-2015, 03:15 | #13 (permalink) |
08-05-2015, 03:15 | #14 (permalink) | |
Member: 476626 Status: Offline Thanks Meter: 6 | Quote:
08-05-2015, 03:16 | #15 (permalink) | |
