Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei
Huawei General Huawei phones and tablets help
Old 07-18-2013, 12:09   #1 (permalink)
Member: 1223271
Huawei B593 - enter unlock code manually [Solved]
Hello there,
i got a Huawei B593 and received a NCK Code.
Is there a possibility to enter the code manually?
http://192.168.1.1/en/cardlock.asp don't work
Old 07-18-2013, 17:19   #2 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Originally Posted by kiterider View Post
Hello there,
Hello
You Can Use Hyperterminal For Enter Code
Old 07-19-2013, 14:27   #3 (permalink)
Member: 1223271
thanks for the advice!
i found a solution for myself
it's pretty simple
* get a sim card from another carrier
* put the sim card into the Huawei B593
* turn on the Huawei B593
* open a browser and go to "192.168.1.1"
* login your router with the password
* go to "internet settings" in the menu
* enter the pin of the sim card to enable the sim card
* then go to "sim settings"
* there should a field for unlock
* enter the nck code or unlock code
* router should reboot
* router should be unlocked
i checked the simlock status with the dc unlocker tool -> status: unlocked
Old 08-23-2013, 06:58   #4 (permalink)
Member: 2008678
Help
This process is not working on me. My modem/ router is branded with personalized interface. My network setting and other options are pre-fixed already. Somebody can help on this?
Old 08-23-2013, 08:02   #5 (permalink)
Member: 1413531
Sonork: x-men
Thanks Meter: 2
do you have mkey dongle? .....just press unlock modem is done.
Old 08-24-2013, 14:02   #6 (permalink)
Member: 2008678
Sorry but i dont have. Any other options?
Old 09-26-2013, 23:31   #7 (permalink)
Member: 2034722
it's pretty simple
where do i find the pin of my sim card?
Old 01-17-2014, 05:34   #8 (permalink)
Member: 1745200
Sonork: 12345
didn't work for 192.168.1.1 but
192.168.254.254 was good and continue to admin panel
but cant seen the internet setting to input calculated unlock code...
any idea masters? thanks
Old 04-14-2014, 18:39   #9 (permalink)
Member: 1627210
i cant find also the calculated unlock code..please is there any other option? thanks in advance...
Old 03-30-2015, 16:40   #10 (permalink)
Member: 2366768
Sonork: 100.1594064
help same problem..................i have dc-unlocker..........but how can unlock its ...........before habe new sestem .........setting then go internet.......then want unlock code ..............but nowe not comimg before...........pls helpme any one
Old 07-28-2015, 22:07   #11 (permalink)
Member: 2435739
Hi good afternoon forum friends ... I join this prestigious forum under which present problems with a modem huawei b593 - s22 I purchased three months ago and I could not run this because I do not accept any SIM card from my country ( Venezuela ) .
It always gives me a message that I contact the operator of the Internet as the simcard is blocked ... but this is not .. Can anyone give me some advice on this team ??
I am from Venezuela where three operators work
Movistar: GSM 850 - Frequency 3G UMTS / HSDPA 1900 Mhz
Movilnet : GSM 850 - Frequency 3G UMTS / HSDPA 1900 Mhz ( and 2100Mhz , unused
Digitel 900 - Frequency 3G UMTS / HSDPA 900 MHz - frequency 4G (LTE ) : 1800Mhz
and the team is working in the following bands :
• G: EDGE / GPRS / GSM 850/900 /1800 / 1900MHz
• 3G: HSUPA / HSDPA / UMTS / DC- HSPA + 900 / 2100MHz
• 4G ( FDD ) 2600/2100/1800/900 / 800MHz (TDD ) 2600MHz
Old 08-05-2015, 03:15   #12 (permalink)
Member: 476626
Thanks Meter: 6
To Debrand your Huawei b593 click http://forum.gsmhosting.com/vbb/f804...nding-1865253/
Old 08-05-2015, 03:15   #13 (permalink)
Member: 476626
Thanks Meter: 6
Old 08-05-2015, 03:15   #14 (permalink)
Member: 476626
Thanks Meter: 6
Old 08-05-2015, 03:16   #15 (permalink)
Member: 476626
Thanks Meter: 6
Page generated in 0.29876 seconds with 9 queries
