GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-11-2016, 06:47 | #46 (permalink) | |
Major Poster Join Date: Jul 2013 Location: Nigeria
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | Quote:
1. Run Balong tool. 2. Click “Detect” button. It will show COM Port with “BOOT_3G”. 3. Locate the “Loader” file which you have got in the email. 4. Click on “Load” 5. Once progress bar reaches the end, you will again notice something is installing on your PC. Note: You can check in COM ports, you will see two Huawei ports. | |
12-11-2016, 07:01 | #47 (permalink) |
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | if u are having problem loading the usb loader , then take a look of this link https://s28.postimg.org/79ig30obh/ba...01_696x604.jpg |
12-11-2016, 14:57 | #48 (permalink) |
Junior Member Join Date: Sep 2007
Member: 592519 Status: Offline Thanks Meter: 0 | i have done all the process successfully. but browser doesnt open but can open manually by entering ip address. now let me know how to rewrite the imei........? i tried putty it shows cme error 0. kindly help |
12-11-2016, 18:45 | #49 (permalink) | |
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | how to write imei e5573 Quote:
so u have to rewite it with dc-unlocker like this u will run dc-unlocker as an administrator then Click “Detect” button if the dc-unlock it, then ur will copy this : AT^DATALOCK="00000000" at the bottom of the line and click enter on ur key broad, if all things goes well it will ok then u can now rewrite ur imei by pasteing this with ur imei AT^DATALOCK="ur imei" then click enter on ur key broad and it will say ok then u write RESET , now u have ur imei back but ur s/n is still missing but u can follow this link to rewrite ur s/n https://gadgetgurumelville.wordpress...illefernandes/ | |
The Following User Says Thank You to sech444 For This Useful Post: |
12-12-2016, 09:31 | #50 (permalink) | |
Junior Member Join Date: Dec 2016
Member: 2659271 Status: Offline Thanks Meter: 0 | Quote:
12-18-2016, 11:23 | #52 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 496 | @sech444 Sir Need E5573CS-322 usbloader Plz Where To Mail To Get Usb Loaders? In E5573CS-322 WORKING FILES Folder Available E5573cs-323_usbloader.bin Error Is Here Need Help Plz Thanks Anticipation |
12-18-2016, 12:17 | #53 (permalink) | |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 496 | Quote:
After Writing E5573cs_Update_21.318.03.00.00 Now Modem Is Dead | |
12-18-2016, 21:02 | #56 (permalink) | |
Member: 1970813 Status: Offline Sonork: kofi Thanks Meter: 24 | e5573cs-322 usbloader only for e5573cs-322 Quote:
https://drive.google.com/open?id=0B0...Xhpb1gzcVlaQ1U | |
The Following 4 Users Say Thank You to sech444 For This Useful Post: |
12-18-2016, 21:09 | #57 (permalink) | |
Now At Home Will Try Tomorrow And Will Post Result Here Best Wishes For You Sir | |
