Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM / HSDPA Modems and Routers
GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares
Old 12-19-2016, 17:49   #61 (permalink)
Member: 514552
I've successfully done all of the above steps, but as of now, it's just one light that is on on the E5573Cs-322 and it's neither connecting nor broadcasting wifi, but the device manager shows Huawei 3g application Interface and other, as shown below:
Please how do I get the mifi working back? Thanks
Old 12-20-2016, 07:20   #62 (permalink)
Member: 130828
Thanks Meter: 4
i also get same error
Old 12-20-2016, 11:22   #63 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 24
go thought all the post cos we have talk about it !!!!! start all over again
Old 12-20-2016, 11:33   #64 (permalink)
Member: 514552
After going all over again, it does come up, unlocked, connecting and browsing, but the moment it is powered off and powered on back, the 2 lights will be blinking as if if is still in that Balong stage, it won't stop until I instal the 21.318.03.00.00 firmware. It is currently using the web UI version 17.100.15.01.356. Please wht could be wrong?
Thanks
Old 12-20-2016, 15:14   #65 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 496
the battery most be charge up to 50%
@sech444
Sir Battery Charged 100% But Same
Dead When Flashing With
E5573cs_Update_21.318.03.00.00
Old 12-21-2016, 08:07   #66 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 24
Originally Posted by shoaibrao View Post
@sech444
U HAVE TO START ALL OVER AGAIN
If ur boot shot is successful ,
Ur mobile wifi two light will go off as if it is DEAD but it is not!!!
All u need to do is to flash it with the correct files and ur mobile wifi is unlock!!!
U most first of all flash it with this E5573cs_Update_21.318.99.03.00!!!
Now for the second file to flash must be this Update_WEBUI_17.100.15.01.356_MRE5!!!
Then the last file to flash is the E5573cs_Update_21.318.03.00.00!!!
And ur mobile wifi is unlock!!!
U can use the dc-unlock to see ur mobile wifi and rewite ur IMEI
Old 12-21-2016, 08:24   #67 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 496
I Tried Each Any Every Thing More Than 10 Times
Every Thing Ok Except Of Last Step >>>>Then the last file to flash is the E5573cs_Update_21.318.03.00.00!!! <<<<<
Modem Dead On This Step
The Following User Says Thank You to shoaibrao For This Useful Post:
Old 12-21-2016, 10:59   #68 (permalink)
Member: 514552
Exactly the same problem I encoutered before I was able to revive it back. Its been unlocked and working fine, just that the moment it is powered off and powered on back, the 2 lights will be blinking as if it is still in that Balong stage, and it won't stop until I reflash it again.
The Following User Says Thank You to wilfem For This Useful Post:
Old 12-22-2016, 09:01   #69 (permalink)
Member: 130828
Thanks Meter: 4
Same thing happening to me as well
Old 12-22-2016, 12:40   #70 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 24
try this files........ https://drive.google.com/open?id=0B_...25FM3hRUElQUlk ........
Old 12-22-2016, 16:45   #71 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 496
Result Still Same
Dead When Flash "E5573cs_Update_21.318.03.00.00"
Old 12-23-2016, 13:36   #72 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 24
Result Still Same
use the dc unlocker to read it and post it let me see it
Old 12-24-2016, 13:28   #73 (permalink)
Crazy Poster
Member: 2661546
Thanks Meter: 9
Result Still Same
Yes same happened with me here, i followed every step exactly
Old 12-24-2016, 18:02   #74 (permalink)
Member: 1970813
Sonork: kofi
Thanks Meter: 24
All the files u will need
The problem is that u are using the wrong files or the right files with the wrong mobile WiFi so i want u to take a good look of ur mobile wifi or u can use dc unlock to know ur mobile WiFi by using USB to connect to ur pc. then u follow the step by step that i have mention in the past post and u can also get some files from here to GOODLUCK
DOWNLOAD LINK
Download Huawei Firmware Update / Upgrade / Downgrade Download Driver Update
The Following User Says Thank You to sech444 For This Useful Post:
Old 12-24-2016, 22:01   #75 (permalink)
Crazy Poster
Member: 2661546
Thanks Meter: 9
DOWNLOAD LINK
Hello bro, thanks for your reply but E5573Cs-322 won't start after flashing with 21.318.03.00.00 it stays in dead mode and the link you provided dont have firmware for e5573cs-322 so bro i think nothing could be done, any ways thanks for ur support.
The Following User Says Thank You to shah95 For This Useful Post:
Page generated in 0.21916 seconds with 8 queries
