Huawei General Huawei phones and tablets help |
04-02-2014, 10:17 | #1 (permalink) |
Major Poster Join Date: Feb 2011 Location: philippines
Member: 1508116 Status: Offline Sonork: none Thanks Meter: 21 | IDeos S7 Slim Model S7-201w Update Failed HELPp Problem: stuck in pldt logo. I tried to update Firmware.. To follow this guide but no luck. Code: Version introduction 1.1 Upgrade prerequisite The Slim software should be updated with the Micro-SD card. 1.2 Upgrade files Upgrade file consist of a software image along with a configuration file, which are put in a directory named dload. The directory should be like this: dload/ |--- unlmt.cfg |---UPDATA.APP 2 Upgrade preparation 2.1 Check current upgrade environment Make sure that the Micro-SD card is available and can be read and write. 2.2 Get and check the software package Copy the dload folder to Micro-SD card, after copying, the directory is “ /sdcard/dload/” 2.3 Make sure the battery is fully and connect to Charger during upgrading. 3 Upgrade operations 3.1 Package upgrade Step 1. A Micro-SD card of 256MB or more should be available. The Micro-SD card made by *******, Kingstone, or Kingmax is recommended. Step 2. Format the Micro-SD card (This operation is optional). Step 3. Right click your mouse and select „Extract here‟, unzip the customized S7-201w Software Upgrade Guideline Secret 2012-2-16 Huawei confidential, no spreading without permission Page 4, Total6 package. Step 4. Obtain the unzipped folder and files (subdirectory: \dload\*.*) File in Micro-SD card like this, Micro-SD card ┗dload ┣UPDATA.APP ┗ unlmt.cfg Step 5. Copy the entire dload folder to the root directory of the Micro SD card. Insert the Micro SD card into the device. Step 6. Plug in battery, unplug the charger and plug-in again, the device will power up and check the Micro-SD for upgrading automatically Step 7. LEDs of device will flash every 2 seconds if it has detected the upgrade software and do the real upgrading. There will be an process bar to be shown in the LCD screen . Step 8. After upgrade is over, LED indication light and LCD screen will both show the upgrade. I repeat this procedure many times until my set is dead now. Please please help me. Is there any chance to revive and alive again.. |
