Huawei General Huawei phones and tablets help |
12-03-2016, 12:52 | #4 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1261483 Status: Offline Sonork: 100.1644685 Thanks Meter: 124 | |
The Following 8 Users Say Thank You to Mc.Manik For This Useful Post: |
01-26-2017, 09:21 | #7 (permalink) |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | download this firmware, no password 100 % worked Needrom | No Login ROM install : Step one: Prepare an SD card, it is recommended to use Sandisk, Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step 5: SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade. Step Six: The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart. or Step one: Prepare an SD card, it is recommended to use Sandisk, Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step Four: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure Step Five: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery. |
The Following 3 Users Say Thank You to appsworlmardan For This Useful Post: |
01-26-2017, 12:47 | #8 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
and how to do this method in those mobile which are dead condition ? | |
The Following User Says Thank You to malka4u For This Useful Post: |
04-22-2017, 06:48 | #12 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan Age: 24
Member: 2488001 Status: Offline Sonork: 100.1669288 Thanks Meter: 295 | Last edited by ...:::::NP™:::::...; 10-21-2021 at 10:09. Reason: inactive link has been removed |
The Following 8 Users Say Thank You to Salman725626 For This Useful Post: |
06-14-2017, 09:08 | #13 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india kerala,MALAPURAM EDAKKAR
Member: 1224654 Status: Offline Sonork: jaheer Thanks Meter: 61 | after flash set is done ...thanks but noservice imei ok....any nv file correopt? |
The Following 2 Users Say Thank You to jasheer For This Useful Post: |
