Huawei General Huawei phones and tablets help |
04-12-2019, 16:31 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Age: 39
Member: 18577 Status: Offline Thanks Meter: 4 | Huawei P10 Plus Bricked -Need Help w/Flashing I surely can use some help to resurrect this phone. Current State: Phone is in Huawei USB 1.0 Mode (after creating DC-Unlocker testpoint) If testpoint is removed, phone is completely dead. Background: Was trying to debrand. Somehow ended up with no erecovery, no TWRP, no Boot. Phone would stay stuck at Huawei logo. Bootloader was accessible, phone and FRP were unlocked. Phone was on November 2018 security path running Android 8.0 Efforts: Tried flashing various firmwares using DC-Unlocker but all failed. Finally created testpoint and flashed bootloader and new Oeminfo. This step was successful. However, flashing matching stock rom always failed. After writing new oeminfo, FRP also got locked. Requirement: Of course, I want to restore the phone. My plan of action is to find a flasher / box that can help successfully flash board software and bypass FRP. I've seen a lot of Huawei flashers available, but I would appreciate any advise on which one I should try. I only have this one phone to fix so I also don't see a point in buying lots of hardware. Log from DC-Unlocker is available here: https://forum.dc-unlocker.com/forum/...with-testpoint |
04-13-2019, 08:51 | #6 (permalink) |
Registered User Join Date: Oct 2012
Member: 1822958 Status: Offline Thanks Meter: 45 | i dont think MRT will help, DC is by far your best bet, Octoplus is ok but buggy, i believe sigma may be able to help but again DC is arguably better. ive sent you a message with some advice that may help |
04-18-2019, 00:11 | #7 (permalink) |
Member: 18577 Status: Offline Thanks Meter: 4 | Finally the phone has been resurrected by using belam00r's help. Special thanks to stabbinbaz as well for offering his help. It took over 6hrs to get this nonsensical device up and running. The process remains simple, but sourcing and subscribing to all services is key. Steps: 1. Flash bootloader from DC Unlocker to enter Fastboot 2. Flash board software in XML format using IDT (good luck finding that XML) 3. Phone should boot with no IMEI but access to ADB would be available 4. Use HCU to repair IMEI 5. Flash stock firmware through DC Unlocker in fastboot mode |
The Following User Says Thank You to Ayush For This Useful Post: |
04-18-2019, 12:38 | #8 (permalink) | |
Junior Member Join Date: Mar 2019 Location: Poland
Member: 2900876 Status: Offline Thanks Meter: 0 | Quote:
05-21-2019, 16:37 | #9 (permalink) | |
Junior Member Join Date: Dec 2007
Member: 659285 Status: Offline Thanks Meter: 0 | Hi Ayush!, Can you explain a little more about the XML and IDT step?. If you can share the XML used can be very helpful!. I try with different versions and DC Unlocker without success, I belive get the best results after: 1. shortcircuit the testpoint. 2. Upload bootloader for Kirin 960 V4. 3. After fastboot is enabled, I do the fastboot oem unlock <key>, press the volume up one time and then the power button. 4. I upload bootloader again. Now the key is all unlocked. 5. Upload different versions, with the .dgtks, without, with a Nougat and Oreo images... Do you have any sugestion?. Thanks and best regards!, Sebastian Quote:
05-22-2019, 03:51 | #10 (permalink) | |
Freak Poster Join Date: Jul 2007 Location: UnLoCkGsM-Bogota
Member: 543296 Status: Offline Sonork: 1653004 Thanks Meter: 44 | Quote:
i have same problem can u post board software in XML? thx | |
