Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei
Huawei General Huawei phones and tablets help
Old 04-12-2019, 16:31   #1 (permalink)
Member: 18577
Thanks Meter: 4
Huawei P10 Plus Bricked -Need Help w/Flashing
Members,
I surely can use some help to resurrect this phone.
Current State:
Phone is in Huawei USB 1.0 Mode (after creating DC-Unlocker testpoint)
If testpoint is removed, phone is completely dead.
Background:
Was trying to debrand.
Somehow ended up with no erecovery, no TWRP, no Boot.
Phone would stay stuck at Huawei logo.
Bootloader was accessible, phone and FRP were unlocked.
Phone was on November 2018 security path running Android 8.0
Efforts:
Tried flashing various firmwares using DC-Unlocker but all failed.
Finally created testpoint and flashed bootloader and new Oeminfo. This step was successful.
However, flashing matching stock rom always failed.
After writing new oeminfo, FRP also got locked.
Requirement:
Of course, I want to restore the phone.
My plan of action is to find a flasher / box that can help successfully flash board software and bypass FRP.
I've seen a lot of Huawei flashers available, but I would appreciate any advise on which one I should try. I only have this one phone to fix so I also don't see a point in buying lots of hardware.
Log from DC-Unlocker is available here:
https://forum.dc-unlocker.com/forum/...with-testpoint
Old 04-13-2019, 05:29   #2 (permalink)
Member: 1677509
Thanks Meter: 4
All boxes do the same thing. Try to write in support of DC Phoenix.
If you don’t find a solution, I can help for a fee through Teamviwer
Old 04-13-2019, 05:38   #3 (permalink)
Member: 18577
Thanks Meter: 4
If you donít find a solution, I can help for a fee through Teamviwer
Thanks for the revert. I'm okay with Teamviewer, would you be able to use your own credentials for DC Unlocker as I don't have any credits.
Old 04-13-2019, 05:45   #4 (permalink)
Member: 18577
Thanks Meter: 4
@.::ARD::.
@VC_INDIA
Can MRT Dongle help with this situation?
Old 04-13-2019, 07:04   #5 (permalink)
Member: 1677509
Thanks Meter: 4
Originally Posted by Ayush View Post
@.::ARD::.
@VC_INDIA
I think not. Not sure.
MRT is very unstable and has bugs...
Old 04-13-2019, 08:51   #6 (permalink)
Member: 1822958
Thanks Meter: 36
i dont think MRT will help, DC is by far your best bet, Octoplus is ok but buggy, i believe sigma may be able to help but again DC is arguably better. ive sent you a message with some advice that may help
Old 04-18-2019, 00:11   #7 (permalink)
Member: 18577
Thanks Meter: 4
Finally the phone has been resurrected by using belam00r's help. Special thanks to stabbinbaz as well for offering his help.
It took over 6hrs to get this nonsensical device up and running.
The process remains simple, but sourcing and subscribing to all services is key.
Steps:
1. Flash bootloader from DC Unlocker to enter Fastboot
2. Flash board software in XML format using IDT (good luck finding that XML)
3. Phone should boot with no IMEI but access to ADB would be available
4. Use HCU to repair IMEI
5. Flash stock firmware through DC Unlocker in fastboot mode
The Following User Says Thank You to Ayush For This Useful Post:
Old 04-18-2019, 12:38   #8 (permalink)
Member: 2900876
Steps:
Flashing bootloader is via DC Phoenix ? What is IDT? In point 5. i should use board firmware in .dgtks file format?
Old 05-21-2019, 16:37   #9 (permalink)
Member: 659285
Hi Ayush!,
Can you explain a little more about the XML and IDT step?. If you can share the XML used can be very helpful!.
I try with different versions and DC Unlocker without success, I belive get the best results after:
1. shortcircuit the testpoint.
2. Upload bootloader for Kirin 960 V4.
3. After fastboot is enabled, I do the fastboot oem unlock <key>, press the volume up one time and then the power button.
4. I upload bootloader again. Now the key is all unlocked.
5. Upload different versions, with the .dgtks, without, with a Nougat and Oreo images...
Do you have any sugestion?.
Thanks and best regards!,
Sebastian
Steps:
Old 05-22-2019, 03:51   #10 (permalink)
Raskalito's Avatar
Member: 543296
Sonork: 1653004
Thanks Meter: 40
Steps:
i have same problem
can u post board software in XML?
thx
Old 05-22-2019, 21:39   #11 (permalink)
Member: 18577
Thanks Meter: 4
Sorry you guys are going through this trouble.
@belam00r is the person to ask for the XML.
Old 05-24-2019, 22:24   #12 (permalink)
Member: 1879471
Thanks Meter: 4
It is ok to use xml ( board firmware ) from Huawei VKY-AL00 to VKY-L09 ?
Old 08-03-2019, 14:24   #13 (permalink)
Member: 2116073
Thanks Meter: 8
i have same proplem. vky l09 c432 dead i flashed board after flashing firmware but after again dead
please explain step by step
Page generated in 0.37973 seconds with 7 queries
