Huawei General Huawei phones and tablets help |
02-13-2014, 23:51 | #19 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Brother I repair same problem before wid zip update through card by 1 by 1 putting Update files wid key combination u also need to repair imei after repair is gone after repair.......use sigma for free repair or zz bt it need some credits thanks........ |
02-14-2014, 07:01 | #20 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1776947 Status: Offline Sonork: 100.1659966:tjjxxs Thanks Meter: 74 | guys just download official huawei firmware from there website here is the link Support - Downloads - Huawei Consumer BG then take a memory card unzip the downloaded file then put it to memory card and boot your device with volume down and power then the update will begain make sure that your battery is fully charged for backup plug your charger then update will finished but your imei will be 0 but dont worry your handset will work fine if u want to repair your imei u can do it with sigmakey box correct me if im wrong |
The Following User Says Thank You to tjjxxs For This Useful Post: |
05-14-2014, 17:11 | #24 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IN GSM
Member: 304574 Status: Offline Sonork: 100.1593675 Thanks Meter: 72 | 100% working with u8800 pro Quote:
thanks realy help ful | |
09-27-2014, 14:32 | #26 (permalink) | |
Cheater -Don't Deal with him- Join Date: Feb 2007 Location: Palestine
Member: 452256 Status: Offline Sonork: 100.1651051 Thanks Meter: 587 | Quote:
03-10-2015, 17:36 | #27 (permalink) |
Freak Poster Join Date: Aug 2014 Location: France Age: 34
Member: 2235775 Status: Offline Thanks Meter: 351 | i am success HUWEI U8800 PRO BLUE SCREEN FLASHING. IT IS VERRY EASY SIMPLE. 1... COLLECT A MICRO SD CARD & FORMAT IT. 2... YOU PASTE FLASH FILE IN YOUR SD CARD but follow under text & then start work. MAYBE YOUR FLASH FILE FOLDER NAME: U8800Pro V100R001C00B572G001(Gingerbread) OR ANOTHER NAME. AND THIS FOLDER IN THREE FOLDER FILE:step 1,step 2 & step 3. 3... OPEN YOUR 1ST "step 1" FOLDER & COPY "dload" & PASTE IT ON SD CARD. 4... INSERT SD CARD ON YOUR PHONE.REMOVE BATTERY & DONT INSERT BATTERY. PRESS & HOLD VOL UP & DOWN. THEN INSERt USB CABLE NOW SHOW UPDATING... 5...WHEN COMPLEATE 1ST STEP.COPY & PASTE "dload" FROM STEP 2 & DELET 1ST STEP dload FILE FROM SD. THEN THIRD dload... HAVE ANY PROBLEM CONTACT ME... [email protected] ...msn |
