Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei
Huawei General Huawei phones and tablets help
Old 08-28-2015, 12:54   #1 (permalink)
Member: 2385681
Thanks Meter: 11
HUAWEI Y300-0100 how to flash
Hi
Downloaded HUAWEI Y300 firmware (Y300-0100, Android 4.1, Emotion UI, V100R001C00B175, General Version)
from Huaweidevice.com
But dont know how to flash it.
Kindly help
Old 08-28-2015, 13:00   #2 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
copy to dload folder sdcard then prees Vol up & vol down press power flash it
Guide All Huawei (Android) Stock Rom Installation Guide
Step one : Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G.
Step Two : Formatting SD card (optional).
Step Three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP.
Step four : Check the root directory of the SD card you dload UPDATA.APP.
Step Five : SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade.
Step Six : The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart.
OR
Step one: Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G.
Step Two: Formatting SD card (optional).
step three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP.
Step four: Check the root directory of the SD card you dload UPDATA.APP.
Step Five: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure
Step Six: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery.
The Following User Says Thank You to ch wajid For This Useful Post:
Old 08-28-2015, 14:54   #3 (permalink)
Member: 2385681
Thanks Meter: 11
Not clear. Can anyone explain with good english please
♦ Tanvir Tanju ♦
Old 08-28-2015, 16:46   #4 (permalink)
ch wajid's Avatar
Member: 2203737
Sonork: 1656500
Thanks Meter: 462
♦ Tanvir Tanju ♦
Your Document is Ready
Old 08-28-2015, 16:50   #5 (permalink)
Member: 2385681
Thanks Meter: 11
Originally Posted by ch wajid View Post
What?
♦ Tanvir Tanju ♦
Old 08-28-2015, 18:21   #6 (permalink)
Member: 2385681
Thanks Meter: 11
Thats how i did it
- put "dload" folder from archive on formatted micro-sd card's ROOT
- put micro-sd card into phone
- start phone in download mode = Press the VOLUME UP and VOLUME DOWN key, and then press the
POWER key to power on the phone and enter the Software Upgrade Mode
(taken from upgrade manual - which is found in archive, pdf ... )
- wait for finish ...
p.s. if not accepting firmware - means it's not international version ....
♦ Tanvir Tanju ♦
Page generated in 0.19839 seconds with 9 queries
