Huawei General Huawei phones and tablets help |
08-28-2015, 12:54 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Sylhet
Member: 2385681 Status: Offline Thanks Meter: 11 | HUAWEI Y300-0100 how to flash Downloaded HUAWEI Y300 firmware (Y300-0100, Android 4.1, Emotion UI, V100R001C00B175, General Version) from Huaweidevice.com But dont know how to flash it. Kindly help |
08-28-2015, 13:00 | #2 (permalink) |
Freak Poster Join Date: Jun 2014 Location: United States Of Islam
Member: 2203737 Status: Offline Sonork: 1656500 Thanks Meter: 462 | copy to dload folder sdcard then prees Vol up & vol down press power flash it Guide All Huawei (Android) Stock Rom Installation Guide Step one : Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G. Step Two : Formatting SD card (optional). Step Three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four : Check the root directory of the SD card you dload UPDATA.APP. Step Five : SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade. Step Six : The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart. OR Step one: Prepare an SD card, it is recommended to use Kingstone, or Kingmax, size is recommended that more than 1G. Step Two: Formatting SD card (optional). step three : copy a large package path UPDATA.APP to the SD card dload UPDATA.APP. Step four: Check the root directory of the SD card you dload UPDATA.APP. Step Five: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the upgrade in Figure Step Six: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery. |
The Following User Says Thank You to ch wajid For This Useful Post: |
08-28-2015, 16:46 | #4 (permalink) | |
Member: 2203737 Status: Offline Sonork: 1656500 Thanks Meter: 462 | Quote:
08-28-2015, 18:21 | #6 (permalink) |
Member: 2385681 Status: Offline Thanks Meter: 11 | Thats how i did it - put "dload" folder from archive on formatted micro-sd card's ROOT - put micro-sd card into phone - start phone in download mode = Press the VOLUME UP and VOLUME DOWN key, and then press the POWER key to power on the phone and enter the Software Upgrade Mode (taken from upgrade manual - which is found in archive, pdf ... ) - wait for finish ... p.s. if not accepting firmware - means it's not international version .... ♦ Tanvir Tanju ♦ |
