Micromax General Micromax phones discussion, firmwares, solution, root, help |
06-07-2014, 09:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | 1st in the world micromax a94 imei repair successful with original tool:) Code: [2014-06-07 13-22-20] BRCM Number Tool Simplified Ver1.4.6 start [2014-06-07 13-22-20] Loading settings... [2014-06-07 13-22-20] Project:CapriTK [2014-06-07 13-22-20] Write IMEI:True [2014-06-07 13-22-20] Dual IMEI:True [2014-06-07 13-22-20] Read IMEI:True [2014-06-07 13-22-20] IMEI relation:0 [2014-06-07 13-22-20] Write BT MAC:False [2014-06-07 13-22-20] Write WiFi MAC:False [2014-06-07 13-22-20] BT MAC bind IMEI:False [2014-06-07 13-22-20] WiFi MAC bind IMEI:False [2014-06-07 13-22-20] Read BT MAC:True [2014-06-07 13-22-20] Read WiFi MAC:True [2014-06-07 13-22-20] Scan BT MAC:True [2014-06-07 13-22-20] Scan WiFi MAC:True [2014-06-07 13-22-20] Write SN:False [2014-06-07 13-22-20] Read SN:True [2014-06-07 13-22-20] Checking setting valid [2014-06-07 13-22-46] Writing thread started [2014-06-07 13-22-46] Waiting for IMEI input... [2014-06-07 13-22-52] Get input IMEI:911343702013980 [2014-06-07 13-22-52] Waiting for IMEI2 input... [2014-06-07 13-23-02] Input IMEI2:911343702013998 [2014-06-07 13-23-11] Phone connection detected [2014-06-07 13-23-16] Waiting for IMEI input... [2014-06-07 13-23-22] Get input IMEI:911343702013980 [2014-06-07 13-23-22] Waiting for IMEI2 input... [2014-06-07 13-23-29] Input IMEI2:911343702013998 [2014-06-07 13-23-54] Connect phone timeout! [2014-06-07 13-23-59] Waiting for IMEI input... [2014-06-07 13-24-08] Get input IMEI:911343702013980 [2014-06-07 13-24-08] Waiting for IMEI2 input... [2014-06-07 13-24-16] Input IMEI2:911343702013998 [2014-06-07 13-24-26] Phone connection detected [2014-06-07 13-24-31] Waiting for IMEI input... [2014-06-07 13-32-54] Get input IMEI:911343702013980 [2014-06-07 13-32-54] Waiting for IMEI2 input... [2014-06-07 13-33-35] Input IMEI2:911343702013998 [2014-06-07 13-33-53] Phone connection detected [2014-06-07 13-33-53] Reading OEM info ... [2014-06-07 13-33-53] Read OEM info OK: A94_Ind_R05_20140305 '$5 [2014-06-07 13-33-53] SW version:A94_Ind_R05_20140305 [2014-06-07 13-33-53] Writing IMEI... [2014-06-07 13-33-53] Send write IMEI request command OK [2014-06-07 13-33-53] Get write IMEI confirmation and write IMEI to phone [2014-06-07 13-33-53] Get write IMEI finish command [2014-06-07 13-33-53] Writing IMEI OK [2014-06-07 13-33-53] Read IMEI... [2014-06-07 13-33-53] Send read IMEI request command to phone... [2014-06-07 13-33-54] Get read IMEI result: [2014-06-07 13-33-54] IMEI1: 911343702013980 [2014-06-07 13-33-54] IMEI2: 911343702013998 [2014-06-07 13-33-54] Read IMEI OK! [2014-06-07 13-33-54] Operation completed successfully! [2014-06-07 13-33-57] Waiting for IMEI input... WBR sahil2000ind |
The Following 3 Users Say Thank You to sahil2000ind For This Useful Post: |
06-24-2014, 10:35 | #3 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | next time search after post hare it Welcome to the ./downloads/Micromax/00_A Serie/A94/Tools/IMEI Writing Tool/ folder of GsmHosting support area |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
06-28-2014, 21:04 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Just use the usb cable instructions here : http://support.moulnisky.com/index.p...50%2021663.pdf BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
06-28-2014, 21:39 | #7 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | what says in the log window? could you, please, post the logs here? BR Alex |
06-28-2014, 21:57 | #8 (permalink) |
Junior Member Join Date: Jun 2014 Location: india
Member: 2197374 Status: Offline Sonork: 100.1656221:luck Thanks Meter: 0 | [2014-06-29 02-25-31] BRCM Number Tool Simplified Ver1.4.6 start [2014-06-29 02-25-31] Loading settings... [2014-06-29 02-25-31] Project:CapriTK [2014-06-29 02-25-31] Write IMEI:True [2014-06-29 02-25-31] Dual IMEI:True [2014-06-29 02-25-31] Read IMEI:True [2014-06-29 02-25-31] IMEI relation:0 [2014-06-29 02-25-31] Write BT MAC:False [2014-06-29 02-25-31] Write WiFi MAC:False [2014-06-29 02-25-31] BT MAC bind IMEI:False [2014-06-29 02-25-31] WiFi MAC bind IMEI:False [2014-06-29 02-25-31] Read BT MAC:True [2014-06-29 02-25-31] Read WiFi MAC:True [2014-06-29 02-25-31] Scan BT MAC:True [2014-06-29 02-25-31] Scan WiFi MAC:True [2014-06-29 02-25-31] Write SN:False [2014-06-29 02-25-31] Read SN:True [2014-06-29 02-25-31] Checking setting valid [2014-06-29 02-25-41] Writing thread started [2014-06-29 02-25-41] Waiting for IMEI input... [2014-06-29 02-25-43] Get input IMEI:35572202 [2014-06-29 02-25-43] Waiting for IMEI2 input... [2014-06-29 02-25-43] Input IMEI2:355722050 [2014-06-29 02-26-08] Connect phone timeout! [2014-06-29 02-26-13] Waiting for IMEI input... |
07-02-2014, 12:49 | #10 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | PHONE MUST BE IN OFF CONDITION WHEN CONNECT TO CABLE WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
07-13-2014, 06:02 | #11 (permalink) |
No Life Poster Join Date: Aug 2011 Location: all device sell hear
Member: 1627323 Status: Offline Sonork: WhatsApp+8801763009154 Thanks Meter: 481 | need this driver setup this driver but notwork BRCM_WinUSB_ADB_Jungo_MTP_RNDIS_Driver_1.02 also try this but not work |
10-02-2014, 07:07 | #13 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | [2014-10-02 11-30-26] SW version:A94_Ind_R03_20131220 [2014-10-02 11-30-26] Writing IMEI... [2014-10-02 11-30-26] Send write IMEI request command OK [2014-10-02 11-30-26] Get write IMEI confirmation and write IMEI to phone [2014-10-02 11-30-26] Get write IMEI finish command [2014-10-02 11-30-26] Writing IMEI OK [2014-10-02 11-30-26] Read IMEI... [2014-10-02 11-30-26] Send read IMEI request command to phone... [2014-10-02 11-30-26] Get read IMEI result: [2014-10-02 11-30-27] IMEI1: xxxxxxxxxxxxxxxx [2014-10-02 11-30-27] IMEI2: xxxxxxxxxxxxxxxxxxxxx [2014-10-02 11-30-27] Read IMEI OK! [2014-10-02 11-30-27] Operation completed successfully! finally done its all about pc and driver problem |
