Micromax General Micromax phones discussion, firmwares, solution, root, help |
04-29-2017, 09:05 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | a311 mtk 6592 flash file need- a311-v1-111114-its got-but it for qualcom-not for mtk details as below Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00110000 help me for mtk firmware |
04-29-2017, 09:20 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Jodhpur India
Member: 48238 Status: Offline Sonork: 100.54361 Thanks Meter: 397 | Please study before posting such things There is only MTK A311 mobile made by Micromax WBR Jyoti |
The Following User Says Thank You to ~:Sujyot GSM Zone:~ For This Useful Post: |
04-29-2017, 09:37 | #3 (permalink) |
Member: 48238 Status: Offline Sonork: 100.54361 Thanks Meter: 397 | You have to flash this set via YGDP tool by selecting the cpb file You can get the scatter file of this set from the folder where it gets extracted WBR Jyoti |
04-29-2017, 14:59 | #5 (permalink) | |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Quote:
for scatter file need select CPB file and apply on ygdp tool then go to C:\YLXZGJ\YGDP\DownFiles here you get scatter file | |
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post: |
04-30-2017, 04:02 | #6 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
"""""""""""""""for scatter file need select CPB file and apply on ygdp tool """"""" help me | |
The Following User Says Thank You to zone3 For This Useful Post: |
04-30-2017, 06:21 | #7 (permalink) | |
http://forum.gsmhosting.com/vbb/f606...-file-2082047/ | |
04-30-2017, 08:19 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: UAE
Member: 330460 Status: Offline Sonork: (Off Line) Thanks Meter: 6,479 | Quote:
I upload for you but try your own risk Try flash with some pro. tools File Info : Platform ID : MT6592 version : 2 Custom name : CUST BLOADER HEADER: MTK_BLOADER_INFO_v13 Preloader: preloader_yulong92_cwet_kk.bin System Info: id:4.4.012.P1.141110.A311 version:4.4.2 model:Micromax A311 Note : Untick preloader then flash for safe flashing Download : Micromax-A311 MT6592_SW_44012_HW_101114 SP_Flash_Tool_v5.1712_Win | |
The Following 4 Users Say Thank You to swapan For This Useful Post: |
05-01-2017, 05:31 | #9 (permalink) | |
why above error? help Last edited by Deepesh Sharma; 05-01-2017 at 05:51. Reason: remove quote image | |
The Following 2 Users Say Thank You to zone3 For This Useful Post: |
06-13-2017, 14:13 | #11 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1552893 Status: Offline Thanks Meter: 6 | micromax A311 unable to detect in ygdp (entring download mode) solve open properties setting of ygdp tool then go to compatibility tab then click change setting for all users and select (window xp service pack 2) Abhishek Mobile Solution Burari |
The Following 2 Users Say Thank You to ghant For This Useful Post: |
02-09-2018, 11:48 | #13 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Perfect way to flash micromax a311 without any problem 1ST ) DOWNLOAD THIS FILE ****************************/file/ddoyg..._V1_111114.zip 2ND) CONNECT PHONE WITHOUT BATTERY AND NO NEED TO PRESS ANY KEY 3RD) THIS ONE IS IMPORTANT , WHEN YOU CONNECT USB , DRIVER WILL LOAD , NOW TAKE NOTE THAT DRIVER LOAD MUST BE "preloader usb vcom driver" , THEN ONLY TOOL WILL DETETCT YOUR PHONE . IF OTHER DRIVER LOAD UNINSTALL IT AND INSTALL "preloader usb vcom driver" DRIVER . THIS METHOD IS TESTED BY ME ON MANY PHONE . IF IT HELP LIKE THE THANKS BUTTON. |
The Following 2 Users Say Thank You to djj007 For This Useful Post: |
