Micromax General Micromax phones discussion, firmwares, solution, root, help |
07-16-2016, 08:43 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | aq4501 flashed sucessfully , but problem when i type *#06# it says unfortunately it say unfortunately google dailler has stopped . that i have problem with aq4501 hang on logo , i flashed with three different firmware which is good file already tested other phones , but now the problem is i have got three phones i flashed it sucessfully with sp tool {download ,firmware upgrade , format + download } all but problem is when i try to check imei *#06# it say unfortunately google dailler has stopped ..... then beep tone unitill press ok need help what may b the problem unit working fine only imei might b faulty no network |
07-16-2016, 11:07 | #2 (permalink) |
Banned Join Date: Dec 2015 Location: Temp@
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Use Flashing_Guide & Latest Firemware & Flash-Tool Which I MentionD In This Post.... Firemware Latest : sprout_reference_pack_1783956-LMY47O_ALPS.L1.SPROUT.SP.p76_user_4g-mmx.zip Flash-Tool : AQ4501_DownloadTool_SP_Flash_Tool_exe_windows_v5.1 424.00.zip Flashing_Guide.Pdf : AQ4501_Flashing_Guide.Pdf Thanks.. |
07-18-2016, 21:21 | #3 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend @masimobilecare, First Of All Next Time Don't Post Like This With Big Fonts. (Everyone Can Read Normal Fonts Including Yourself). Solution, Select "Format All + Download" In SP Flash Tool Then Flash Cellphone, If Still Same Then It's Bugy eMMC Problem. |
07-18-2016, 21:29 | #4 (permalink) |
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Here Is Flashing_Guide & Latest Firemware & Flash-Tool Which I MentionD In This Post.... Firemware Latest : sprout_reference_pack_1783956-LMY47O_ALPS.L1.SPROUT.SP.p76_user_4g-mmx.zip Flash-Tool : AQ4501_DownloadTool_SP_Flash_Tool_exe_windows_v5.1 424.00.zip Flashing_Guide.Pdf : AQ4501_Flashing_Guide.Pdf Thanks |
07-19-2016, 19:47 | #5 (permalink) | |
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | Quote:
but problem didn't solve by format & download also dear Every thing is working fine in unit except imei invalid , when I dail *#06# A beep sound come & it says mobile dailer has been stopped Is it a bad buggy Emmc bro 😞 | |
07-21-2016, 20:59 | #6 (permalink) | |
Member: 2508657 Status: Offline Sonork: 100.1623070 Thanks Meter: 380 | Quote:
Its EMMC Problem Clearly Try To Re-Ball Emmc Ic Thank U. | |
The Following User Says Thank You to .::Advance::. For This Useful Post: |
