Micromax General Micromax phones discussion, firmwares, solution, root, help |
10-01-2013, 19:19 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 509348 Status: Offline Thanks Meter: 116 | canvas hd a116 touch problem i faced this problem in diffrent handsets of same model , and all touch i replaced r original , is there any software or method for calibrating or any other touch solving method for this problem i am sure tht new touches r not faulty , all r original |
08-26-2014, 07:00 | #3 (permalink) | |
No Life Poster Join Date: May 2009 Location: delhi
Member: 1030568 Status: Offline Thanks Meter: 67 | Quote:
03-09-2015, 12:15 | #4 (permalink) |
Junior Member Join Date: Mar 2007
Member: 459557 Status: Offline Thanks Meter: 0 | this problem is not a complaint of touch pad.. the complaint shown because touch fitting is not perfect setting use double side sticker 1 or 2 layer in the touch pade's BOARDER side |
03-28-2015, 16:08 | #6 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2370064 Status: Offline Sonork: 100.1663672 Thanks Meter: 1 | Some time display gets contact with the touch pad. fix the display properly to the panel and then stick the touch pad properly to the frame .YOUR PROBLEM MUST BE SOLVED I HOPE SO...... |
