Micromax General Micromax phones discussion, firmwares, solution, root, help |
06-06-2013, 08:15 | #106 (permalink) | |
No Life Poster Join Date: May 2007 Location: INdIa
Member: 517316 Status: Offline Thanks Meter: 185 | Downloading Problem.....! Quote: Bro downloading problem from given link every time stops on 18 mb . Im not able to download after several tries please give alternate working link........! Thanx........ | |
The Following User Says Thank You to guru4gsm For This Useful Post: |
06-06-2013, 09:04 | #107 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
simple solution just use any download like Internet Download Mannager your problem will be solved 10000%. Br, azam | |
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post: |
06-08-2013, 09:44 | #108 (permalink) |
Junior Member Join Date: Apr 2011 Age: 33
Member: 1549891 Status: Offline Sonork: ippu khan Thanks Meter: 0 | Micomax A25 flash file not warking 4shared - My 4shared - shared folder - free file sharing and storage |
06-08-2013, 10:08 | #109 (permalink) | |
try to download from here Welcome to the ./downloads/Micromax/A25/ folder of the support area for your service center Br, azam Last edited by moulnisky; 11-02-2013 at 20:41. | |
06-09-2013, 13:31 | #110 (permalink) |
Junior Member Join Date: Jun 2013 Location: salem , tamil nadu
Member: 1951689 Status: Offline Sonork: aj Thanks Meter: 1 | hii tanxx for the flash files for mmx a72 . will this rooting method would end my warranty ?? and these updates are they updates for 2.3.6 or any other os ??? if so pls provide me guide to perform flash pls rply coz i need to upgrade my mob .. |
The Following User Says Thank You to ajaisandy For This Useful Post: |
06-11-2013, 09:15 | #112 (permalink) |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Member... how to remove phone lock in modu-t. it asks for phone lock code when mobile switch-on. unable to connect to hub service suite and how to remove this code... |
06-12-2013, 07:06 | #113 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Odisha India
Member: 1770085 Status: Offline Sonork: 100.1639467 Thanks Meter: 43 | use flashing box for unclock your mobile or other wise 1. do you have service suite of modu? if yes connect your modu then tick the simlock 2. put the unlocking code on this 3. then run the service suite if you don't have service suite you can try this 1. insert different sim which is not lock to the operator 2. switch on the phone 3. the phone ask for restriction code 4. enter the restriction code 5. then wait for few second the phone will reboot 2x after that the phone is unlock |
06-12-2013, 07:14 | #114 (permalink) | |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
Dear Member... before answering to a post, read the post carefully. i asked for for for phone lock, not the simlock.... | |
06-21-2013, 15:49 | #120 (permalink) | |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | Quote:
The Following User Says Thank You to tarunvishal For This Useful Post: |
