Micromax General Micromax phones discussion, firmwares, solution, root, help |
04-20-2017, 08:25 | #16 (permalink) | |
Freak Poster Join Date: Jan 2005
Member: 107499 Status: Offline Thanks Meter: 8 | Quote:
Am currently using No Dashboard firmware, and have SD Card in it with Micromax Dashboard. | |
04-20-2017, 11:01 | #18 (permalink) |
Member: 107499 Status: Offline Thanks Meter: 8 | New Update links are below and will be updated soon on the main page MMX444L LTE USB Manager https://mega.nz/#!nxpGhCyT!3sooyquVL...cuDPAQG43oi7iE Airtel Official v0.3 https://mega.nz/#!eh5DTJLb!RHsu8Mz5G...yrMQFQrd9Jvd68 Unlock Airtel Firmware v1.0 https://mega.nz/#!q5wwyapK!TyMnP7R_4...tXxsvsRkAkJU0k Unlock+Remove Airtel CD-ROM v2.0 (NEW UPDATE) https://mega.nz/#!jwRSmIIZ!dxjfY1yDu...JzfnviJ3s--s6I |
The Following User Says Thank You to ronak_p2006 For This Useful Post: |
05-04-2017, 15:44 | #20 (permalink) | |
I will PM you the command to change IMEI Generally IMEI error doesn't shows if you fallow the instructions and disable auto-update by Airtel sailer, hope your using MMX444L | |
05-05-2017, 07:49 | #21 (permalink) | |
but anyways here is the fix e.g: If my 15 Digit IMEI is 988601513828997 Then i will first connect the dongle in PC Launch DC UNLOCKER and Select Longcheer WM 72 and select autodetect, Once detected i will type ATI and hit Enter once the device is detected correctly there will be some hardware info displayed along with IMEI Only then i will use the given commands below AT+LCTSN=1,7,"988601513828997 *NOTE: The above information is reference purpose only to help you fix your problem, Please don't use the above IMEI its a random numbers and dont misuse the commands, its very much recommended that you use your Original IMEI mentioned on the hardware/box, to avoid loosing the devices authenticity/warranty, and i shall not be responsible for any damage done to your hardware during this process. Last edited by axecom; 05-11-2017 at 07:00. Reason: user requested to change | |
05-08-2017, 12:49 | #23 (permalink) | |
But the Firmware you gave has fallowing files modified files compared to the one i have.. booot9615.img msmcdprootfs.yaffs2 sbl2.mbn 9615imageusrfs.yaffs2 efs.mbn there are minor changes in them so my guess is that in hurry they didnt load the nlist properly in it due to which your getting signal error, basically its due to difference in hardware, flashing lower version of sw firmware for higher version of hardware, then its was originally designed for. Best suggestion is Try to Flash Micromax Original v3 Firmware MMX444L_MICROMAX_INDIA_V03.200515.444L.rar LINK BY DEEPESH SHARMA You have to wait while i cant guarantee that i can provide solution as i work and do this in my free time, so better contact Mkey send them the device they can fix it. Last edited by ronak_p2006; 05-08-2017 at 12:55. | |
05-10-2017, 11:35 | #24 (permalink) |
Member: 107499 Status: Offline Thanks Meter: 8 | New Update: ----------------------------------------------------------- Airtel Unlocked Firmware with Micromax Dashoard ----------------------------------------------------------- This was Originally Airtel Firmware, Now I have Unlocked and removed Airtel Dashboard, replaced it with Micromax MMX444L Dashboard. Download : MMX444L_MICROMAX_INDIA_V03.200515.444L.rar |
12-09-2017, 11:38 | #25 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2667097 Status: Offline Thanks Meter: 0 | Not Working [QUOTE=ronak_p2006;12491714]New Update: ----------------------------------------------------------- Airtel Unlocked Firmware with Micromax Dashoard ----------------------------------------------------------- This was Originally Airtel Firmware, Now I have Unlocked and removed Airtel Dashboard, replaced it with Micromax MMX444L Dashboard. I have run this, it goes through without error but the Airtel dashboard remains. My dongle is already unlocked and was working on a TP link WIFI adapter using IDEA sim without issuses Help |
12-09-2017, 13:54 | #27 (permalink) |
Member: 2667097 Status: Offline Thanks Meter: 0 | As soon as I insert the dongle the Virtual CD pops up. If I run it during the installation it says driver installation failed. Then when I restart the computer and insert the dongle I get a green wheel saying initialzing device and its going in circles. I had flashed the following Airtel Unlocked Firmware with Micromax Dashboard |
12-16-2017, 19:24 | #28 (permalink) |
Junior Member Join Date: Mar 2009
Member: 986664 Status: Offline Thanks Meter: 0 | I had unlocked my MMX4L device successfully. But now when i connect it to my pc it is not detected and it shows all colors starting from blue, green, orange, yellow, white and then red. After sometime only red led light is flashing. Any solution to this issue or my device is dead. Thanks! |
03-10-2018, 10:21 | #29 (permalink) | |
03-10-2018, 10:28 | #30 (permalink) | |
Edit: Am glad you did mentioned, to me in personal chat that the firmware worked fine and one day suddenly the device isn't getting detected in pc, its hardware issues i have send you the photos of disassembly, ill try to see if i can get the detailed hardware schematics. I took down most of all the links because i thought it was due to the firmware by me. | |
