Micromax General Micromax phones discussion, firmwares, solution, root, help |
03-13-2013, 11:18 | #1 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | [Guide] All micromax root and clockworkrecovery
03-14-2013, 08:07 | #2 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | how to root a90s steps Before you proceed Turn USB debugging on. Make sure you’ve more than 75% battery. Neither androidplus nor author is responsible for any kind of damage that may cause by following these steps. Rooting voids your device warranty. Download following Bin4ry’s Rooting Tool Root Micromax A90S Install the drivers for your device using pdanet. Connect the device to your laptop/ PC via USB cable. Unzip the root tool you downloaded from downloads section. Run the RunMe.bat file from there. Now do as you are instructed to in the command prompt window you just opened. Within no time, you will be having a rooted phone! Don’t disconnect your device until the command window shows that the process has been completed successfully. |
03-15-2013, 10:34 | #3 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | Clockwork recovery for a110 canvas2 How To Install Cwm Recovery on Micromax A110 Canvas 2 Note : you need to root first your device to flash clockworkrecovery in your phone #1. First of all Download the Recovery File #2. Rename that file to recovery.img #3. Transfer the renamed file to your phone’s SD card. #4. Download MobileUncleTool.apk from Google Play on your Micromax A110 and install it. #5. Open the MTK Tools App. #6. Select the Recovery Update option, now choose the recovery.img that you have just transferred to your Micromax A110 Canvas 2. #7. The app will flash CWM recovery on your A110 now. #8.Now Your phone will reboot in CWM recovery Mode. In future You can boot into CWM recovery anytime by turning your phone OFF, press and hold volume down + volume up + power buttons until the screen turns on. After which you could take Backup , install new stock v2 rom , install official update and reboot your device. |
03-15-2013, 11:32 | #5 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | bro,its little hard but you can do it.anyway Here We go To Root Micromax A87 How to root micromax a87 pre-requierments: #1.First of all Download Java from above link & Install it normally. #2. Now Download Android-SDK, & Install it.
#4. Now Install the Micromax A87 Driver . This Step 3 should be done very carefully, read the guide on How to Install Driver in Windows from my Forum. #5. Download & Install Unlock Root from the above link. #6.Open it & click on Green Big Root Button. 7) It will ask for the device, select Micromax a87 & you are done. Note: Though the preccess is little hard,so carefully read all article twice befor proced,nither gsmhosting nor me respondable about any damages if happens Last edited by unlockers555; 03-15-2013 at 11:38. |
03-16-2013, 07:16 | #6 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | how to root micromax a89 how to root micromax a89 Download and extract this zip file: Root_script_by_Bin4ry_v17.zip Enable USB debugging on your Micromax A89 Ninja. (Go to Settings > Developer Options > Check mark “USB Debugging” and then tap OK button. Now connect your Micromax A89 Ninja to your computer using your USB cable. The drivers should be installed automatically Change the mode of your device from USB storage to Media Device and then proceed further. This option appears only when you connect your device to your PC. Go to the folder named “Root_with_Restore_by_Bin4ry_v18″ and run the “Runme.bat” file. Choose the Normal mode by typing ‘1‘ and hit Enter from your keyboard. Follow the on-screen instructions to complete the A89 Ninja rooting process. Your will reboot during the process after which Bin4ry will copy some files to your device. When your phone is back ON, you should find the superuser SU app in your app drawer. If it’s there, ( whoopee!!! ), your Micromax A89 Ninja has been rooted! But then, if you want to check and be doubly sure, you could download The Root Checker App and check it for yourself. |
03-25-2013, 15:52 | #7 (permalink) |
Member: 547368 Status: Offline Thanks Meter: 254 | A90s root How to root a90s Before rooting, please charge your A90S to at least 70% battery level. Also disable all antivirus programs (if you are using any).once done, you can proceed further with complete guide which is mentioned below:1. Download Bin4ry tool kit and all driver to your computer. 2. After downloading kits, connect your A90S with computer via USB cable. 3. Unzip Bin4ry kit and open the extracted file. 4. Now check for RunMe.bat file in extracted folder. Run this file. 5. Now you will get an on screen guide which will guide you through a prompt window. 6. Simply follow all the instructions. 7. After following all the instruction, your device will get rooted for new recovery and ROMs. 8. Wait for the command prompt to show “Process Completed” message. Now disconnect USB cable and enjoy rooted A90S. Please note: that if you are facing any problems then simply remove OFF the battery and repeat all the steps again. |
04-26-2013, 14:38 | #9 (permalink) | |
Member: 547368 Status: Offline Thanks Meter: 254 | how to root a30 How To Root A30 Quote:
The Following User Says Thank You to unlockers555 For This Useful Post: |
05-12-2013, 13:52 | #10 (permalink) |
Junior Member Join Date: May 2013
Member: 1935811 Status: Offline Thanks Meter: 1 | Root micromax a65 Dear unlockers555, please help me root micromax a65. m stuck without the root preety badly. Thanks in advance. |
The Following User Says Thank You to kingmachinee For This Useful Post: |
05-13-2013, 07:05 | #11 (permalink) | |
Member: 547368 Status: Offline Thanks Meter: 254 | how to root a65 Quote:
The Following 2 Users Say Thank You to unlockers555 For This Useful Post: |
