Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 08-03-2011, 05:12   #1 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
[Guide] Micromax mobiles: Hard Reset Procedures
How To Hard Reset Micromax A60
switch off phone, hold the centre key,home key & power all at the same time .when u see a trangle on screen ,hit the call button.its done
here is image how to hardreset
Old 08-21-2012, 04:01   #2 (permalink)
Member: 1638066
Thanks Meter: 170
Hard reset procedures for Micromax mobiles
How To Hard Reset Micromax A45
> Press and hold Volume up + Volume Down + power on
> you will see 2 options (recovery mode / Factore mode) press volume up to select recovery mode
> select wipe data/ factory reset by volume down button then touch menu
> volume down to select yes--delete all user data then touch menu
> reboot system now
The Following 8 Users Say Thank You to a2zmobile_bhw For This Useful Post:
Old 09-13-2012, 08:49   #3 (permalink)
Member: 320205
Thanks Meter: 181
Micromax A100 HardReset
Use Vol Up+power key to go to the reset menu.
Use Volume keys to navigate.
Go to factory reset option.
*LONG PRESS* volume up key to select and leave.
confirm Yes by *LONG PRESS* volume up key and leave.
after that select reboot opiton.
factory set done
The Following 2 Users Say Thank You to sampat_shah For This Useful Post:
Old 09-16-2012, 07:48   #4 (permalink)
Member: 1355941
Thanks Meter: 10
micromax a75 hard reset
kepp pressing these two volume up + power button 3-5 seconds
with volume down select wipe data/factory reset
The Following 2 Users Say Thank You to vssy2007 For This Useful Post:
Old 10-08-2012, 10:59   #5 (permalink)
Member: 1079392
Thanks Meter: 444
Smile Micromax a45 hard reset
KARBONN A1 Hardreset
1.switch off mobile & put battery then press Home+center+power (see pic 1 )
2.After 10 sec Triangle symbol (see pic 2)
3.then Press call button (see pic 3)
4.press volume button select wipe data/factory reset
5.then press center button
6 wait & enjoy
Battery back up, user code reset, pattern reset
Old 10-08-2012, 11:13   #6 (permalink)
..:: SONY ::..'s Avatar
Member: 1528548
Sonork: 100.1613286(Offline)
Thanks Meter: 2,243
Micromax a44 hardreset
1. Volume down + power
it will show
recovery mode: Volume up
factory mode: Volume down
2. Press volume up
3. Select wipe data/ factory reset press menu button and select yes
it will done.
Old 10-10-2012, 08:02   #7 (permalink)
Member: 1273083
Sonork: 100.1619267
Thanks Meter: 36
micromax a25 hardreset
volumeup + center + power button
again center button
then click menu button
select yes
and enjoy
Old 11-06-2012, 10:38   #8 (permalink)
Member: 1120953
Thanks Meter: 3
thank u soo.........
hard reset micromax a57
vol up+home+pwr
recovery menu show
then wipe factory reset
Old 11-13-2012, 08:21   #9 (permalink)
Member: 217853
Thanks Meter: 13
MICROMAX A110 hard reset
1 volume up + volume down + power switch
2 volume up
3 recovery
4 wipe data/factory reset
Old 11-16-2012, 15:03   #10 (permalink)
Member: 601200
Thanks Meter: 142
MICROMAX A87 Hardreset
Old 12-01-2012, 10:17   #11 (permalink)
Member: 450402
Thanks Meter: 14
micromax-funbook-p300 hard reset
1. Hold and press (option + home + power button ) on the screen andriod symbol
2. Press option button on the sceen recovery menu
3. Use volume button select wipe factory reset (press power button)
4. Yes (or) no u select yes (press power button )
Job done
Old 01-03-2013, 16:49   #12 (permalink)
Member: 919695
Sonork: 111
Thanks Meter: 45
Thumbs up [Guide] Micromax mobiles: Hard Reset Procedures
MicroMax A25 Hard Reset Factory Setting
[IMG]http://2.bp.********.com/-zWkV05S5gpU/UOV8iU1uHkI/AAAAAAAAAOY/_gY1pCv0odE/s320/20130103_165818.jpg[/IMG]
Press volume up And home button & on/off shows the android logo
press home button one time
menu will appear android system recovery mode use volume key to slide down
select wipe data reset
use left menu button to select on touch
then yes to all data erase restore factory setting
phone factory settings finished
Old 02-27-2013, 17:35   #13 (permalink)
redrose2009's Avatar
Member: 1084993
Sonork: 100.1617420
Thanks Meter: 641
micromax a30 smarty hard reset done
MICROMAX A30 SMARTY HARD RESET
PRESS AND HOLD VOL (-) AND VOL (+) AND POWER BUTTON
WAIT FOR ANDROID LOGO
AFTER YOU SEE ANDROID LOGO
PRESS HOME BUTTON
YOU CAN SEE RECOVERY MODE
PRESS VOL DOWN BUTTON
SELECT FACTORY RESET
AND REBOOT
ENJOY
REDROSE2009
The Following 2 Users Say Thank You to redrose2009 For This Useful Post:
Old 02-28-2013, 16:49   #14 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
How to hard Reset Micromax A116 Canvas HD
. Now after talking complete backup just Switch of you MMX A116
. Now press power button (hold it) and also simultaneously press the Volume + and volume – button, keep pressing the 3 button until you two options
. Then Enter in recovery Mode by pressing the Volume up button
. There will be three android logo displayed. it wont change until you press any button hence press the power button once to proceed further
. Now you will see a Menu Option, now select it using the volume up and down button and press the power button to select it
. The enter button is bit difficult As we have seen in pother android phone that there is only one button but on Canvas HD it has Two. the power button will not work as enter button on A116 . For enter button you need to press the left (context menu) and the right (back) touch sensitive buttons simultaneously and hold for a sec.
. Now select Wipe Data/Factory reset and press the enter button as mentioned in above steps. after that you will see some more option press the volume up and down button to navigate through it and press the Enter Button again to confirm it.
. This will initiate the factory reset process and now choose Reboot now option using Volume Buttons and press the enter button to select it.
. Your Micromax A116 Canvas HD Will Reboot and you will see the phone same as you opened the box pack.
The Following 6 Users Say Thank You to .::EXTREME::. For This Useful Post:
Old 03-17-2013, 20:25   #15 (permalink)
Member: 936364
helo brother micromax a55 how to hardrest. help pls.
The Following User Says Thank You to zahid560 For This Useful Post:
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.31269 seconds with 10 queries
