Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Micromax
Micromax General Micromax phones discussion, firmwares, solution, root, help
Old 01-03-2013, 17:19   #1 (permalink)
Member: 221464
Thanks Meter: 6
HOW TO FORMAT MICROMAX a57 NINJA3
how to format Micromax A57Phone is ok phone is pattern lock phone give
USER NAME( E MAIL)---------------
Password ---------------------------- please give good idea whithout Sofware format Same LIKE SAMSUNG GALAXY Y FORMAT
Old 01-03-2013, 19:08   #2 (permalink)
Umesh_Arora's Avatar
Member: 1792140
Sonork: 100.1618782,gaba
Thanks Meter: 6,002
Press & Hold Volume UP + Power On/Off
It'll Show Android Logo With Exclamation Mark
Select Wipe data/factory reset By Volume Up Key
Then Press Power On/Off Key For Select
Then Press Volume Up Key For : Yes -- delete all user data
Then Again Press Power On/Off Key For Select
It'll Show Like This
--Wiping Data...
Formatting /data...
Formatting / cache...
Data wipe complete.
Then Select reboot system now & Press On/Off Key
After Rebooting Cellphone Will Start Without Any Problem.
UMESH GABA
Old 01-04-2013, 02:20   #3 (permalink)
Member: 221464
Thanks Meter: 6
I have micromax mobile not samsung I try it but not good result plz good idea
Old 01-04-2013, 07:52   #4 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: 100.1650339[OFFLINE]
Thanks Meter: 995
Micromax A57 Home screen Disappears after application moved to SD card - Android Forums
try to
WBR ; tejaram
Old 03-26-2013, 11:20   #5 (permalink)
unlockers555's Avatar
Member: 547368
Thanks Meter: 242
If your phone not support hardreset,you have to flash it.
go here for flashtool/files : Unlockers555
The Following User Says Thank You to unlockers555 For This Useful Post:
Old 04-15-2013, 09:49   #6 (permalink)
Member: 1285436
Thanks Meter: 6
--Wiping Data...
Formatting /data...
Data wipe complete.
UMESH GABA
Yes This is the right sollution for Pattern lock or password entered wrongly so many times... Thank u Umesh
Old 04-20-2013, 07:15   #7 (permalink)
Member: 1701545
Thanks Meter: 100
Smile thank
--Wiping Data...
Formatting /data...
Data wipe complete.
UMESH GABA
yes this is tested hard reset my set is done
The Following User Says Thank You to dineshd For This Useful Post:
Old 04-30-2013, 11:12   #8 (permalink)
Member: 1107485
Thanks Meter: 70
MICROMAX A57 pattern lock remove
--Wiping Data...
Formatting /data...
Data wipe complete.
UMESH GABA
sorry to say but sir......your method is not working in micromax a57..... i have many time try but..........
please cheq it......
Old 04-30-2013, 14:10   #9 (permalink)
Member: 547368
Thanks Meter: 242
you can do post #5 .
Old 05-01-2013, 08:40   #10 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,215
where is home key ..........only three keys in moble vol+ - power.....
it is not samsung......it;s micromax a57 brother.........o
try post #2
br,
azam
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Old 07-07-2013, 12:21   #11 (permalink)
Member: 1974165
its not working by pressing(hold) volume + poweron/off button,can you help to unlock pattern lock
Old 07-07-2013, 12:30   #12 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 426
  • Press and hold Volume UP + Power key
  • Select Wipe data/factory reset By Volume Up Key
  • Then Press Power On/Off Key For Select
  • Then Press Volume Up Key For : Yes -- delete all user data
  • Then Again Press Power On/Off Key For Select
  • now reboot device.
Old 09-08-2013, 11:32   #13 (permalink)
Member: 67260
Thanks Meter: 144
please tell me any one know the solution .. how to entered fastboot mode option in micromax a57 model ?
Old 09-08-2013, 12:05   #14 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 426
fastboot mode= switch off your phone. Press and hold vol- and power key.
Old 09-08-2013, 13:58   #15 (permalink)
Member: 67260
Thanks Meter: 144
automatic mobile power on bro........
Page generated in 0.49052 seconds with 7 queries
