how to hardreset micromax a116 ? [Solved] how it ?.......................... |
this way.................. Hard Reset Micromax Canvas HD A116 Switch Off your phone. Press and hold Power button together with ‘volume +’ and ‘volume –’ buttons on the side of phone until you get two options. Now, press the ‘volume +’ button to enter into the recovery mode. This will make a Android icon appears on screen, press power button. This will get you the menu options, use the volume up and down button to choose the option. To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds. Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage. Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. :):):):):) |
already posted in stikcy thread How to hard Reset Micromax A116 Canvas HD br, azam:) |
this key work for me Quote:
:mad: |
not working after recovery mode.. pls show any video guide or pic how to select wipe option. wbr |
http://forum.gsmhosting.com/vbb/9231329-post14.html Br, azam |
not working for me all procedures |
fake not working ..................... |
try again it's tested many times. Br, azam |
Hard Reset Micromax Canvas HD A116 Switch Off your phone. Press and hold Power button together with ‘volume +’ and ‘volume –’ buttons on the side of phone until you get two options. Now, press the ‘volume +’ button to enter into the recovery mode. This will make a Android icon appears on screen, press power button. This will get you the menu options, use the volume up and down button to choose the option. To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds. Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage. Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. 100% working for me thx |
all u need for enter key is here |
its working when show android logo press on/off button ....10000000% working thanks............... |
100% working method to hard reset the device.:) |
**** chaar baar aisa karenge hojayega |
Canvas A116 Hard Reset Done !!!!! Canvas A116 Hard Reset Done !!!!! Thank u SIr And Thanks For GSM-Forum |
